Question about Home
My gerber toilet 1.6 gpf/60 lpf leaks at the back/bottom of the tank when I flush
3 Suggested Answers
  • 62 Answers
SOURCE: Toilet acts like it's getting pluged up as soon as you flush .
use a two gallon buck to flush your toilet - you pour the two gallons directly into the toilet bowl if it flushes fine you need to replace the flush valve, as it is not letting enough water through to properly flush the commode. either rebuild the flush system in the tank or install a fluid master and have a good nights sleep knowing that in the morning you will not leave a suprise for someone else in the family.
Posted on Mar 23, 2010
  • 5 Answers
SOURCE: Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Posted on Jul 22, 2010
AquaSource High-Efficiency 1.6; 1.1-GPF (6.06; 4.16-LPF) White WaterSense Dual-Flush Elongated Chair Height 2-Piece Toilet from Lowes that won't evacuate the bowl during a flush.
The flapper may be closing before the tank is dumped completely. You can verify this by observing flushing action with the tank open.
Apr 13, 2017 | Maximum Home
Toilet won't flush
If you lift the lid off of the back of the toilet, you will see a chain that will probably be laying on the bottom of the water tank. One end connects to the rubber stopper and the other end connects to the bac side of the flushing lever. There should be 3 or 4 holes in the lever that you can connect the chain to. Once you get the chain connected, try to flush. You may have to adjust the chain by placing it in different holes until it flushes properly.
Good Luck!
Jim
Aug 11, 2011 | Gerber Blades Gerber Ultra Flush 10" White...
Handicapp Toilet Bowl does not fill - up as high as regular toilet > very small amount of water in bowl after flushing ie> about 10 cuos of water.. JUST INSTALLED IT NEW YESTERDAY...
Wiith all due respect, the Drake toilet is not a regular toilet and doesn't sound the same as a regular toilet when you flush it. It is in the design that allows it use only 1.5 gpf instead of 3.5 gpf. A rather unique thing is that while it is scientifically calibrated to release 1.5 gpf, it does not empty the tank of approximately 1 gallon of water. Therefore if one feels the need for a little extra umph, simply hold down the flush lever when you flush until the tank is emptied.
Aug 04, 2010 | Toto DRAKE ELONGATED HANDICAPPED TOILET...
Jul 21, 2010 | Porcher Home
Toto Dorian toilet does not flush clean
Don't know if you have calcium build up problems. If you do you could pour a calcium cleaner into the tank to try and clear up the problem. This would be the only way to possibly clean the enclosed area. Good Luck. Jeff
Apr 05, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Mar 15, 2010 | Gerber Blades Gerber Ultra Flush 10" White...
How do I install a gerber 21-375 Toilet? It came with no instructions.
The Gerber Ultra Flush Back Outlet toilet, that uses 1.1 Gallons of water to flush?
Just like any common toilet. Install the tank to the bowl of the toilet, set the toilet, install the flush mechanism in the tank, attach the supply line.
1.MAKE SURE you put the two plastic U-shaped spacers on the back of the bowl!
2.Install the round rubber gasket in-between the tank and the bowl.
3.Set the tank down on the bowl. Make sure you have the round gaskets that go up under the bolt heads, then insert the two bolts into the tank, and through the bowl. NOT installing these will cause a leak!
Tighten these bolts down, until the nuts are JUST touching the tank. (There is a flat washer that goes under each nut)
DO NOT tighten one bolt all the way, then tighten the other bolt!!
These bolts MUST be tightened evenly. Tighten one turn on one bolt, then go to the other bolt.
DO NOT overtighten, or you will break the bowl, and/or the tank!
Make sure your toilet flange on the sewer pipe is in good repair, and clean, from the old beeswax ring. It can be messy, even using gloves. Use a flat painters stick to help remove the old wax ring. Scrape off into a old can. The wax thin residue on the floor and flange is fine.
Set the new wax ring in place, remove the plastic liner that comes with the ring. DO NOT leave that thin plastic liner! It's just to install that wax ring!
Install the bolts that hold the bowl to the floor, or reuse the old bolts if they are in good repair.
Tighten EVENLY, and don't overtighten! You can crack the bowl.
Now install the toilet mechanism in the tank.
Here is a 1 Page, Tank to Bowl Installation Guide from Gerber. It is a PDF file. Let it download ALL the way before looking at it.
http://gerberonline.com/fileLib/Toilets%20Ultra%20Flush%20IS.pdf
Should this direct link not work for you, here is the page it came from,
http://www.gerberonline.com/Catalog.aspx?categoryID=2204&itemID=3514
It's on the right side -> Installation Instruction (PDF)
Jul 02, 2009 | Gerber Blades Gerber Ultra Flush White ADA...
Flapper will not go down
Troy, the flapper otherwise known as the flush valve is easily replaced. They are also very inexpensive. Sometimes they can become distorted due to the clorine in the water and won't operate in the same way they did when it was new. I bet this will fix your issue and save you money as well.
Mar 20, 2009 | American Standard Prairie Field Single...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
