Question about Dimplex DGWH4031 Heater
THE FAN MOTOR IS MAKING A LOUD NOISE CAN I REPLACE TH FAN MOTOR?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Yes, many parts on the web.
Posted on Dec 30, 2013
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Honda pilot 2007 blower fan making noise blower fan was replaced once still making noise
Either its developed the same fault or the fan motor bearing has failed, needs greasing or, if there's a belt, the belt is slipping.
Feb 22, 2012 | 2008 Honda Pilot
When th engine is running there is no noise but when my Engine fan starts a loud noise comes from it.
Is the fan hitting the radiator - then the fan bracket is either broken or loose. If it is not stricking the radiator then you have a bad fan motor.
Jun 25, 2011 | 2001 Ford Escape
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
Hunter ceiling fan that is 14 years old is making a load noise at times when it is on, especially when it's on high. It doesn't always make the noise. I've checked the blades to make sure they were tight.
Sounds like the motor bearings>? Sometimes this has a bit of a "squealing" tone. Either replace th motor or decide that the fan has had its life and replace it.
Jun 21, 2009 | Dryers
Makes a loud noise when it is turned on. Can't open it.
If it is making a loud humming sound it is probably getting weak and will have to be replaced. Is it doing it in all speeds? Motor replacement would probably not be worthwhile unless it is a very expensive unit. I'd opt to replace the unit.
May 16, 2009 | Bionaire BT45RC Tower Fan
Fan motor noise 2005 t bird
do you have a mechanical or a electric fan?
acording to your question seems to be electrical make sure the fan nut is tie and there is no cracks on blades
also wigle the ft shaft up and down and if you feel any play the replace the motor
Jun 01, 2008 | 2005 Ford Thunderbird
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Dimplex DGWH4031 Heater Logo
106 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
