Datacard SP55 Plus mag stripe error
Error Code MS-01410 Mag Stripe Error. Despite getting this code, I can swipe the card after running it through the machine and the Mag Stripe looks correct to me. The Image and text will not print do to this error.
3 Suggested Answers
  • 36 Answers
SOURCE: I recently changed from Preface to ID Works for
Most likely your Mag-stripe info is missing from the card project in IDworks.
If you imported your projects from preface, its likly the box to include mag-stripe config was not transfer d.
enter idworks designer and click VIEW then field connections, there should be some info tied you mag-stripe field 1,2, or 3 of not there is the problem.
Next check printer plug ins in IDworks admin to make sure the mag-stripe plugin is installed. Also i would check Datacard.com Download section make sure you have newest and correct driver for your OS
if none of this works, uninstall everything (exporting projects) and reinstall.
Mag-strpe encoders can become defective, the encoder may need to be replaced.
Posted on Mar 18, 2010
micromatikal
  • 2777 Answers
SOURCE: getting a command error on
What is the error exactly? It just says "command error"?
Thanks Tim
Posted on Oct 03, 2010
Error ms-01410
Error MS-014110 means that there is a Track 1 Start Sentinel problem.
Maybe
Dec 05, 2013 | Datacard Office Equipment & Supplies
Ingenico 3070
If the ingenico is communicating with the pos system and just not reading cards, the mag stripe reader might need to be cleaned. try to clean it with a mag stripe cleaning card ( plastic/cotton card with cleaning solution ), swipe that through a couple times and run a test transaction. **folded paper towel and some rubbing alcohol works too if you don't have a card** I've cleaned alot of them that way working for a major drug store chain.
Oct 04, 2013 | Computers & Internet
Datacard error PR 01739
Upgrade the printer firmware (Go Green firmware update) as you are likely using the newer eco friendly ribbons. The older firmware versions do not recognize this ribbon, which leads to the PR01739 error.
Download firmware here: https://www.datacard.com/id-card-printer-support-and-drivers/sp55-plus-card-printer
Dec 02, 2012 | Datacard SP55 Plus Printer
CHECKSUM ERROR ON VX570
It will remove through software tool then your Vx570 will working fine.
psoftware109@gmail.com
Jan 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
Datacard CP40 Plus printer with an error. Put a new ribbon in it and it does give us a error message: Error: PR-01739 Ribbon Error Please Help!
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Jul 22, 2011 | Datacard SP55 Plus Printer
Ms-01410 error
Having exact same problem, cleaned everything, right settings, right cards, new head and still having ms-01410 and ms-01424
Mar 03, 2010 | Datacard SP55 Plus Printer
I recently changed from Preface to ID Works for printing my cards. At the same time I installed the Datacard printer driver ver 4.0 from CD. I have a SP 35 with and optional mag stripe kit installed. Now I...
Jan 02, 2010 | Datacard SP35 Printer
When i try to print card it causes a paper jam all time. it used to print card but not now i feel this is a grat pity cause its a good printer. It doesnt matter which place i put card it just will not lift...
fter a clear card option has been installed in a Datacard card printer SP35 Plus or SP55 Plus, a card jam error my occur. The same error may occur when after replacing the main control board.
To clear this error the printer will need to determine the sensor type. For the printer to recycle through and make this determination, a power on test card is required using the appropriate clear or opaque card type to force the firmware to redetermine the sensor type. Each time the card is changed from clear or opaque to the other type, a power test card will be necessary to redetermine the sensor type.
For additional information about Datacard printers currently on the market, SP25 Plus, SP35 Plus, SP55 Plus and the SP75 Plus, contact our id card experts toll free at 888-485-4696.
Nov 19, 2009 | Epson AcuLaser C4100 Printer
KeyCard Types
There are several popular type of keycards in use and include the mechanical holecard, bar code, magnetic stripe, smart card (embedded with a read/write electronic microchip), and RFID proximity cards. The keycard is used by presenting it to a card reader; swiping or inserting of mag stripe cards, or in the case of RFID cards, merely being brought into close proximity to a sensor.
Aug 27, 2008 | DG Gold / Brass 98 Biometric Keyless...
140 people viewed this question
jasbo
jasbo
