Question about Motorola Mobility DROID RAZR MAXX HD
Green led indicator light flashes with no new mail
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Check you indicator light settings you might have set it.. make sure you check even your junk or spam mail
Posted on Oct 11, 2013
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
    From the installation guide for this AP, I find the following:
    LED Indicators
    The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
    802.11a Activity LED Amber
    The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
    The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
    802.11b/g Activity LED Green
    The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
    The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
    From this, it appears that the 802.11A radio is malfunctioning.
    Here is the Motorola support web page for this device.
    Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
    No wireless connection for laptop. Linksys router - model #wrt160n v2
    you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
    SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
    lights up and will stay orange when the Router is powered on. The color orange indicates that
    the Router is not using the SecureEasySetup feature, while the color white indicates that the
    Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
    mode, the Cisco logo will turn white and start flashing. After the Router has generated
    the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
    To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
    The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
    indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
    it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
    Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
    Power (Green) The Power LED lights up and will stay on while the Router is powered
    on. When the Router goes through its selfdiagnostic mode during every boot-up, this
    LED will flash. When the diagnostic is complete, the LED will be solidly lit.
    DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
    remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
    the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
    receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
    Internet (Green) The Internet LED lights up when there is a connection made through the
    Internet port. A flashing LED indicates network activity over the Internet port.
    Good luck
    Nov 26, 2010 | Computers & Internet
    Screen will not come on hard drive light no light checked power supply is ok
    Things to check:
    1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
    2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
    3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
    4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
    Feb 05, 2010 | Dell Dimension 4600 PC Desktop
    One light is out on my linksys usb200m
    It depends on which light is OFF: Below are the LED indicators:
    100/ACT Green. The LED lights up when there is a connection to a 100Mbps network. It flashes when the computer is transmitting or receiving data at 100Mbps.
    F/H Green. The LED lights up when the Adapter is operating in fullduplex mode. The LED is off when the Adapter is operating in half-duplex mode.
    10/ACT Green. The LED lights up when there is a connection to a 10Mbps network. It flashes when the computer is transmitting or receiving data at 10Mbps.
    Dec 04, 2009 | Linksys USB200M USB 2.0 Network Adapter
    Dell inspiron 2200 green LED battery Indicator flashing
    sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
    Jun 21, 2009 | Dell Inspiron 6000 Notebook
    Digimax i5 problem charging battery
    ■ Charging LED
    Charging LED
    Red LED is on = Being charged
    Red LED is blinking = Charging error
     Green LED is on = Charging is complete
    ● If the charge indicator blinks as red, it indicates a battery charging error.
    - The battery is not properly inserted
    - The terminals of battery are dirty or damaged
    If the battery is inserted properly and the charge indicator continues to blink, contact the
    nearest Samsung Camera Service Center.
    If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
    Jul 06, 2008 | Samsung Digimax i5 Digital Camera
    Motorola Mobility DROID RAZR MAXX HD Logo
    37 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    Rami Obeid
    Level 1 Expert
    D. E. Hev
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
