Question about State Water Heaters State / AO Smith WH10-A Upper Therm w/ECO Electric 9001954015
Water heater cleening - State Water Heaters State / AO Smith WH10-A Upper Therm w/ECO Electric 9001954015
No hot air comeing out of heater on my 1992 lincoln town car.blower and water or ok lust no hot air cimeing out of ducks?
Hi,if you are not loseing water the best thing to start with is a simple kit that will flush out the rubbish that bilds up in the water channels,all you do is put the aditive in to the system by way of exspansion tank or radiater cap then let the car idle untill recermended time is up,then flush system and refill with the the recormended amont of anti-freeze.
you should be able to buy the item at eney good car spares shop.
Hope this was some help.
ps sometimes things just need cleening or ajusting rather than renewing.
Dec 23, 2013 | 2006 Pontiac Grand Prix
The gray plastic around the top of the pan and the paddle gets burnt on greese want an easy cleening solution
Soak the paddle and ring in very hot water with some washing up liquid and a dishwasher tablet. Leave it until the water goes cold, then rinse and wash as normal.
Feb 06, 2012 | Tefal ActiFry Deep Fryer
1995 ford Econonoline still over heats after changing water pump , thermostat
did you check for circulation at radiater is radiator need cleening what about heater core is there a block in the flow of cooling system.when vehicle warms up and thermostat opens is there circulation at radiator.
Aug 21, 2011 | 1995 Ford Econoline
I have samsung champ 3303 recently.. its camera not working,, mobile is water damedge.. i will cleen them,,,plz.. give me solution.......
if your phones been in water put the phone into a bowl of dry rice and let it sit, should absorb the water
May 04, 2011 | Samsung Cell Phones
Cars stalls when A/C on only, radio went dead...
There is a lot of reasons for stalling but start with trying to find any vaccum leaks. Then cleen the throttle plates and if you know what the idle speed control is cleen that too. Also if it has a mass air flow sensor cleen that but be careful don't brake any of the fine wires. Thats a good starting point that the only thing it cost is a can of carb cleen or throttle plates cleener.
Jun 25, 2010 | 1993 Mazda Protege
Fire sense patio heater won't light...
you prob need a new theromocuple on your pilot or just cleen it with sandpaper this may help
Apr 14, 2010 | Fire Sense 01775 Patio Heater
Heater runs for 10 20 min shuts off. cleaned photo cell. how do i cleen fulem filter?
Wow... what kind of heater, what kind of fuel.... "photo cell"...LOL>...get some facts and I can get you an answer...derrrrrrrrr
Dec 08, 2009 | Reddy Heater RLP100 Portable Forced Air...
Water runing, but does not cleen- soap in tray
the circulation pump needs replacing cost around £100 for the part
may be best to buy new machine
Oct 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Wont turn on
u r phone is shortby water at first cleen it by ipa cleener dont use petrol& water than u have to flash it flash mcu and ppm if problem will still ther than give heat treetment to flash ic and cpu cleen all pins(cunector) chack battery voltage it should be min 3.7volt than put it in to phone properly and switch it on it wii on 100%
Aug 11, 2007 | Samsung SGH-d807 Cellular Phone
State Water Heaters State / AO Smith WH10-A Upper Therm w/ECO Electric 9001954015 Logo
267 people viewed this question
Top State Water Heaters Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a State Water Heaters Hardware and Accessory Expert? Answer questions, earn points and help others
