Question about OKI C3400n Laser Printer
I changed the administrator password OKI C3400n printer. So I'm not longer able to get the web to change the administrator settings. How do I reset everything to the factory defaults?
  • Jose Eduardo
    Jose Eduardo Oct 14, 2013
    Already figured out how to reset.
    Looking behind the printer, located next to the plug for connecting the network cable, there is a button. With the printer off, holding down this button and turn the printer on and waits for it to get online and releasing the power button.
    With this procedure the printer back to factory default, but does not reset the counters of pages printed.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Pull the power cord out, hold the NIC reset button in, then plug in power and turn on.
Posted on Nov 02, 2013
  • 139 Answers
SOURCE: Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Posted on Jan 23, 2008
SOURCE: oki printer 3320 micromline
change to letter
Posted on Feb 22, 2008
sys_admin
  • 829 Answers
SOURCE: font size
Probably the monitor-chip on the board is working inproperly.
Consult the vendor or manufacuturer.
But before this, you may download new monitor driver from the manufacturer.
Posted on Jan 11, 2009
SOURCE: oki c3400n all 3 lights are flashing amber 2 times a second
i suspect an ouput sensor actuator beeing dislodge in the process of paper removal
Posted on Mar 30, 2009
SOURCE: oki c5800L
If those don't work, try the last 6 digits of the network adapter hardware address.
Posted on Jun 10, 2009
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Installing OKI c3400n in Windows 7 32 bit
The c3400n does not have its own wireless capability. It must be connected to a wireless print server or to some wired network that has a wireless access point (WAP) connected to it. A third option is to use a home-networking wireless router.
Individual PCs must have wireless capability also, or they can't print over wireless.
Somewhere along the line the printer must get a local network IP address, i.e. 192.168.0.102. PCs usually use Dynamic Host Configuration Protocol (DHCP) to get an IP address.
But printers are usually manually set to a 'static' IP, because static IPs don't change over time.
Usually there is a security device called a 'firewall' to protect the wired network from unwanted wireless traffic.
So, you first require some form of wireless access.
The people who require wireless printing capability must have their computers configured to make an association to the WAP. Usually requires a passkey or password, depending on the wireless security method.
A port on the firewall must be forwarded to the port used by whichever network-printing protocol is being used to communicate with the printer. There are several possible protocols.
The printer must be set to an IP address unique within the private subnet, i.e. 192.168.0.0/16, used by the local network.
PC-based network-connected devices use IP (Internet Protocol) addressing, i.e. xyz.zxy.yzx.xzy
The printer must be connected to a network switch that is in some way accessible to the WAP. Residential/SOHO (Small Office Home Office) setups use a combination switch/router device, called simply: a router.
Most of the above is done automatically, but there are some set-up tasks that require user intervention. Electronic devices know how to configure everything, after they are given proper parameters.
All you need to do is check the above items. If the printer is found by MS Windows 'searching for network printers', the hard part is done. Then you just tell Windows to use the network printer.
Jul 22, 2012 | OKI C3400n Laser Printer
I can select the Okidata c3400n on my network but cannot print. Both computers are running Windows 7 and have latest drivers.
OK, on a network with windows 7, make sure you log on with 'administrator' rights and not the 'guest' account. The sharing works a little bit different than prior versions of windows.
Aug 02, 2010 | OKI C3400n Laser Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
Oki c3400n all 3 lights are flashing amber 2 times a second
Mar 18, 2009 | OKI C3400n Laser Printer
My oki does not like my new laptop
Chances are that the cd you are using is for windows 2000 or XP.  That cd will not work with vista.  But, you are in luck.  The Oki C3400N is compatible with Vista!  Go to this website and get the windows vista driver for it.  Install it and your printer should work.  Please rate!
http://my.okidata.com/dsdownWeb.nsf/(MOC-C3400n)/FD20231B3C802BE4852572DC005561C3?OpenDocument
Mar 03, 2009 | OKI C3400n Laser Printer
Toner Error
Check to make sure that the sensors are clean and play around with the lock arms. Reset the machine and also download the utility from the oki service website to get exact error message. http://www.okic3400.co.uk/library/downloads/utilities/c3300c3400smv1115.exe
Jan 27, 2009 | OKI C3400n Laser Printer
How do reset an oki c3400 printer
  1. Turn off the printer.
  2. Hold down the SHIFT and LF buttons, and at the same time turn the printer back on.
  3. Release the buttons.
  4. The printer should be reset to the default settings now.
Oct 11, 2008 | OKI Computers & Internet
Oki b6200 web-interface-login
As menttiones on Manual
The factory default of Administrator Name is “ADMIN” and Administrator Password is “xxxxxx” (the last six characters of the printer MAC address).
Alan
May 05, 2008 | OKI B6200 Laser Printer
How do I reset access password?
Thanks. I actually found out that it had never been configured - here is the standard factory access info: All Oki network printing devices support configuration changes via a standard web browser such as Internet Explorer or Netscape Navigator. When applying a configuration change to a device the user is prompted for a user name and password. The following details should be entered: User Name: root Password: last six digits of the MAC address* *You can find the MAC address on the network summary web page or by printing off a menu from the printer.
Nov 22, 2006 | Okilan 8100e Print Server
OKI C3400n Laser Printer Logo
151 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
