Question about Dell Inspiron 530 Desktop Computer
The DVD drive is not showing up on disk drive on my insprion 530s. i can't open it using the button either. how do i fix this?
    Sergeant:
  • Dell Expert
  • 504 Answers
It might be blown out, Try another DVD drive
Posted on Oct 10, 2013
4 Suggested Answers
pcdoctoraz
  • 38 Answers
SOURCE: i cleaned out my start up folder and now my cd-dvd
you will want to check the device manager to see if the drivers are not working properly.
Go to start then right click on my computer and go to properties
On the left side of the properties window you will see device manager click on that and find the dvd/cd-rom drives
click on the plus icon to the left of that and it will show you the drives right click and select update driver and then select search automatically for updated drivers.
Posted on Jun 08, 2010
GSPOT12
  • 75 Answers
SOURCE: Need Help, Dell desktop inspiron 530s, Code 10 CD
Hi!
I assume you are using Windows Vista. To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start , type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue .
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters , and then click Delete .
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters , and then click Delete .
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Thanks for reading my suggestion and I hope this helps.
Posted on Apr 17, 2011
Testimonial: "Great effort with detailed information, thank you!"
  • 114 Answers
SOURCE: dell insprion 530s won't start up just amber light on the motherboard comes on
hello, you will have to remove power cables, and leave for a while then reconnect it and try again. check out my blog for more tips ;
http://diyshelf.blogspot.com/
Posted on Oct 19, 2012
The orignal CD/DVD drive on my insprion 530s will not open, i cannot open it by the button on the tower and its not listed on my computer. How do i fix this?
First Remove it from desktop. And reconnect the SATA on other SATA Port and start the PC and check it in BIOS , is it detecting ?
if yes then check it in MY COMPUTER also. otherwise check with amother SATA cable and if it is not detecting with another SATA cable then ur dvd drive have some proble.
Oct 10, 2013 | Computers & Internet
Dell insprion 530s won't start up just amber light on the motherboard comes on
Oct 18, 2012 | Dell Inspiron 530 Desktop Computer
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
ARTEC DHM-G48R 5.xx (16x/48x) IDE DVD-ROM 16X is not showing up as DVD Drive it is showing up as CD Drive. What do I do to fix this???
If you insert a DVD disk, and then open "My Computer", does it now correctly show that a DVD disk has been detected?
Jun 26, 2011 | Artec DHM G48 DVDROM drive internal 16x...
Disk wont show in dvd rom
try puting your disk in another dvd player, in another computer that you know it works? if you can see
it then you know your dvd rom went out! you will have to get a new one ! I hope this helped !
Jun 03, 2011 | Dell Inspiron 530s Desktop Computer
I need to reset my Dell Inspiron 530S back to factory settings. Can someone tell me how to go about doing this?
  • Turn off the computer, wait a few seconds and then turn it back on. As the computer starts up, press the F8 key until you see the "Advanced Boot Options" menu appear.
  • Select the "Repair Your Computer" option and press the "Enter" key.
  • Click the "Next" button, log in with your Administrator username and password and click the "Dell Factory Image Restore" option.
  • Click "Yes, reformat hard drive and restore system software to factory condition" and click the "Next" button.
  • Click the "Finish" button. The computer will restart in its original factory condition.k
  • Note: Kindly back up all necessary documents before starting restoration as it would be deleted.
    Apr 08, 2011 | Dell Inspiron 530s Desktop Computer
    When i burn a disk on dvd,it will not play on my dvd player?
    Some DVD-players only read 'DVD-R' disks.
    Some DVD-players only read 'DVD+R' disks.
    Be sure that the "blank" disks you are using are compatible with your DVD-player.
    Sep 22, 2010 | Dell Inspiron 530s Desktop Computer...
    I have a dell inspiron 530s desktop and my cr-rom dvd player does not work. It does not recognize any disc inserted!
    HI,
    If the drive was working fine earlier , and has suddenly quit working , Remove all media from the drive. Download and run the following patch from micorsoft . If it doesnot fix the issue the dirve would have to replaced.
    Microsoft Fixit
    Once you are on the above link. click on the green button that says run now.
    Thanks for using fixya
    Proton
    Sep 03, 2010 | Dell Inspiron 530s Desktop Computer...
    I have a Dell Inspiron and the CD/DVD doesn't work. How can I fix it?
    Replace it with a new unit, or if you are clever enough remove / dismantle it and clean the optical reader with cotton bud / tissue, usually fixes them.
    Jan 07, 2010 | Dell Insprion 4F778 (4F779) DVD Drive
    Dell Inspiron 530 Desktop Computer   Logo
    mukhtar21 shaikh
    mukhtar21 shaikh
