Question about Electrical Supplies
Want to know if this is black mold or just mildew please help!!
Recently moved into a apartment and started noticing alot if water damage on ceilings and baseboards i do have a disability so i need to know if this is something serious or minor
    Filmmaker:
    Uploaded 5 video answers.
    Problem Solver:
  • 6 Answers
Looks like mold just because its black doesn't mean its " black mold" that is dangerous Want to know if this is black mold or just mildew  - 10_11_2013_8_26_21_am.png
Posted on Oct 11, 2013
What causes black streaks on walls and ceilings?and what do i do about it? Is it dangerous?
Typically depending where in the building this is happening it is usually oxidation and possibly mold from water or steam. Best way is to use some mold and mildew spray and scrub real good
Feb 28, 2015 | Dryers
My washing mchine has a mildew odour all the time for last month, its a year old WHY? please
this smell is caused by mold and mildew that has formed on the upper part of the outer drum -- the main cause of this is the suds in the wash tend to rise above the normal water line and never get rinsed away properly. so to get rid of the smell --- run a empty load of hot water ( hot/hot ) and when the cycle starts - add to the water 1/2 cup of white vineger and 1/2 cup of bleach, also add ( using a small container ) some more hot water to the machine to bring the water level up to a higher then normal height,,, let the machine complete the full wash cycle. now if the smell is still kinda there -- repeat the whole cleaning thing one more time,,, this should remove all traces of mold and mildew that has built up and you should notice a huge difference. to keep this from happening again,, try not to use so much detergent in the wash and after you wash your clothes - leave the lid wedged open slightly to let air into the unit so moisture can escape,, this will prevent mold from growing because the machine will dry out fully.
now at least once a month do this cleaning with the vinegar and bleach and you will never have this problem again.
c...
Feb 04, 2011 | Washing Machines
Do you recommend 'sealing' the bottom of a toilet with silicone?
no, it will yellow if p gets on it. Use a flexible acrylic caulk, but not an acrylic adhesive because it will make it hard to lift the toilet in the future without damaging the floor.
Sep 24, 2010 | Kohler Home
The inside of my air conditioner is full of mildew. When turned on, it spits out small pieces of black mildew. The odor is very obvious. I cleaned the louvers (as much as I could reach) with a Q Tip and...
Ruth this happens alot ive answered alot of questions so im going to make it short please give me a vote and rating the unit needs to be pulled out and taken out side sprayed really well with cleaner homedepot and lowes sells coil cleaner in their a/c dept. it isnt as good as what your local a/c man can get but will do what happens is the consensation stays in those systems cause the deposits and rust in the drain sometimes clogg the exit when your not useing it it has water that will set their for months at a time the mildew is the least of your worry in most cases theirs mold present as well and as brings spiders and misqitoes I dont know if you can install one in that unit or not but seach online uv lights for a/c systems I think you will like what you see
Sep 21, 2010 | Haier Heating & Cooling
Every time we use the shower there is a very pugnent smell [fishy] all drains been checked, all pluming been checked, all water is fine. shower is 11 years old could this be the problem. the shower we have...
Also check the following things:
The control unit, hose and shower head - depending on the type, some heads will hold water. Remove them and check to see if they are exhibiting signs of mold or possible failure. At 11 years old, the element could be on its way out. If your Mira unit has an auxiliary pump, it should be checked as well. If it's the shower head, you can try to soak it in white vinegar to remove the smell, or simply replace it. If you have well water, you should consider flushing the system to be sure water isn't being trapped somewhere. Also, if the iron content of the water is high, or if your water softener isn't operating properly, that could be an issue as well. The Mira control unit may need to be de-scaled or otherwise checked.
Check the shower stall walls (with no tub) at the bottom where they meet the basin, unless the shower enclosure is all one piece. There could be mold behind the intersection of the walls and base.
Look for any trace of mold growth around any other enclosure components.
If the shower is in a tub, remove the overflow cover on the tub and see if there is any trace of mildew or mold in that area. Follow your nose.
Finally, check for any excessive build up of soap scum, although this is less likely because you'd notice it more readily.
Things like this can be tough to diagnose, so just take things slow and one at a time.
Mar 08, 2010 | Home
Mildew and long dishwasher cycle
Get some household bleach and run a short wash.
Aug 22, 2017 | Kenmore 24 in. 16533 Stainless Steel...
MOLD
Hello Friend, Sounds to me like you have a problem with the quality of your water supply going into your washer. Water quality could be a possibility. If the water contains alot of micro-organisms this could be the problem. When you are not using your front load washer the door remains closed trapping in moisture causing mold and mildew to grow. If you just repeat the cleaning process once again with bleach you should'nt have this problem anymore if you leave the washer door partially open when not in use. Happy to help, Tim.
Jun 25, 2009 | Frigidaire GLTF2940ES Front Load Washer
Strong Musty odor
You will have take it apart, removing the wash tub and all top plastic parts. I just finished taking mine apart do to a mouse that chewed a larg hole in my water tub, and notice tons if old gunk mold and build up. It smells and will not go away unless you scrub it. Sorry to say it is all internal pouring clensers will only wash thru the tubes.
May 27, 2008 | Kenmore 15864/15862 Top Load Washer
MOLD building on inside of dishwasher
are your dishes comming out dry at the end of the dry cycle and during dry cycle do you see steam comming out of the vent
Dec 31, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Black film on turn dials and inside door and bottom of bin
I have a similar KitchenAid model and we always ran it in energy saver mode. Over time, there was a significant buildup of mold/mildew in the unit that was not easily noticed.
Since that time, I took apart the inside of the unit and thoroughly cleaned it with bleach.
Now, we never use the energy saver mode and we use the sanitizer to make sure it gets hot enough so that it kills the mold/mildew on every cycle. The mold has not come back in over a year.
Dec 15, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Electrical Supplies Logo
471 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
