Philips sw8100 37
How do you install the sub woofer correctly
2 Suggested Answers
  • 58 Answers
SOURCE: my toshiba sw1000 has an
Replace the lead to the sub.
Thanks Guy9
Posted on Jun 16, 2008
How do I install my sub woofer on model hw-hm45c
You can't easily
your model has no Sub woofer output
http://downloadcenter.samsung.com/content/UM/201411/20141114104111740/HW-HM45_HM45C-ZA-1114_Bookmark.pdf
you could get a crossover and buy a powered sub if you want to run it that way
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 13, 2016 | Audio Players & Recorders
2009 Jeep Sahara sub woofer not working
if the wires are connected then you ether have a blown amp or sub. try hooking up a diff speaker to the wires if it works your sub is blown. if it doesnt your amp is blown
Mar 13, 2013 | Audio Players & Recorders
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
I need a wiring diagram from car stereo to 2 x 6 " x 9 " and a sub woofer please
You can connect the two 6x9 speakers to the two individual left and right outputs of the car stereo.
Connect each of the left and right channel with the correct polarity . Now the Sub-woofer requires an amplifier to be connected separately and so you need to use the car stereo to be linked to a sub woofer amp which powers the sub woofer.
Mar 26, 2011 | Car Audio & Video
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
Nov 01, 2010 | Audio Players & Recorders
Where should the sub woofer be placed?
The position of a sub woofer is not at all important. Low frequency sound (which is the main output from a sub woofer) is 'non directional' to the ear, so it doesn't make much difference where you locate it.
If it's convenient place it centre back of the room, but I've got mine to one side at the front and it really makes no difference.
Mar 26, 2010 | Philips MCD703/37 System
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
