Question about Konica Minolta PS7000 Book Scanner
Lamp failure do I need to replace the lamp and how
Lamp failure do I need to replace the lamp and how do I do that if that is what is needed?
Need lamp failure Toyota canary me 4 cy
What does that mean?
Need Lamp Failure
If you do not know how to replace
a head lamp have a shop do it
Nov 27, 2014 | Toyota Cars & Trucks
Lamp Failure, Ballast, or color wheel?
The ballast board for sure. If the color doesn't come back, try cleaning all the lens elements in the box in front of the lamp. If that still doesn't restore the color correctly, then look at the color wheel.
Jul 29, 2017 | LG RU-44SZ63D Television
Error c1440
C1440 code means that your exposure lamp has failed or the circuit that powers it has failed. The exposure lamp is the light that comes on from under the glass and scans your original. Most likely failure is the exposure lamp itself. I would say between the 2 that 90% chance the failure is in the lamp. If you want to replace it yourself the part number you will need for the lamp is 1177-7801-01. If you can not locate one reply back to me here, as I have a parts machine I could find you a lamp.
Good Luck and Thank You for using Fixya.
Sep 14, 2010 | Minolta DiALTA Di181 Printer
Projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
May 06, 2010 | Hitachi EDX-3280 LCD Projector
HAve a 42 Sony Wega rear projection TV. Need to replace Bulb but dont know were bulb is. Do I need to take off back panel?
the lamp is located in front below the screen. there is a plastic panel to remove(full width of t.v.) the lamp is in the center held by allen head screws(replacement lamp will supply an allen wrench) be carefull not to get fingerprints or dirt on front of lamp(premature lamp failure will happen) hope this helps.
Jan 16, 2010 | Sony Televison & Video
Pfaff Tiptronic model 2030 LCD display panel went dark, no display. Now lamp burns hot. Told by local service shop that panel needed to be replace to correct lamp issue. Need replacement lcd panel.
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Jan 15, 2010 | PfaFF Tiptronic 2030
Lamp light is lit and TV won't come on
Change the whole housing, if you touch the lamp with your bare hands oil is deposited on it and it will cause premature failure. If the lamp light is lit it is a good bet the lamp needs to be replaced.
Aug 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have infocus sp5000 and the lamp has stopped working. I pulled it our of the unit and it looks perfect. I suspect it is the lamp counter, but I need a method to reset without being able to see the...
there isn't one. you need to see the menu. but what color is the led and is it blinking?
green- all is well
red blinking:
1 time- lamp not striking after 5x.
2 times- lamp has more than 3000 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fan failure. shuts down.
5 times- undiagnosed error. possibly ballast or colorwheel.
if the colorwheel won't spin, the lamp won't light. when you turn on the projector, do you hear a high-pitched whir? if not, the colorwheel needs replacing.
Aug 17, 2009 | InFocus SP-LAMP-017 Projector Lamp for...
Lamp failure
Lamp duty cycle is approx 2300 hours and you know how since long this projector is working with you.
Aug 22, 2008 | Dell 3300MP Multimedia Projector
Dell mp5100 " lamp failure"
Have you tried cleaning all air in-take spaces ? On mine the lamp failure was triggered by temperatur. Afetr hoovering the projector and removing all dust the same lamp worked flawlessy.
Jan 08, 2008 | Dell 5100MP Multimedia Projector
Konica Minolta PS7000 Book Scanner Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
