The orignal CD/DVD drive on my insprion 530s will not open, i cannot open it by the button on the tower and its not listed on my computer. How do i fix this?
    Sergeant:
  • 252 Answers
First Remove it from desktop. And reconnect the SATA on other SATA Port and start the PC and check it in BIOS , is it detecting ?
if yes then check it in MY COMPUTER also. otherwise check with amother SATA cable and if it is not detecting with another SATA cable then ur dvd drive have some proble.
Posted on Oct 11, 2013
4 Suggested Answers
cinek79
  • 320 Answers
SOURCE: I can't eject the optical
hi check the connection between your drive and motherboard also check power connector . Between connectors on the optic drive you need set up a jumper(s) on master or slave. if you can`t open drive in your OS there is a small hol on the front panel of the drive use needle or something similar to open it manualy
Posted on Oct 06, 2008
  • 3 Answers
SOURCE: Problem with Inspiron 530S Desktop Reading CD's
If your computers are relatively old then they may not be able to burn CD's or read CD's that were burned. A new CD/DVD burner is relatively inexpensive and easy to install.
Posted on Jan 02, 2009
  • 68 Answers
SOURCE: dell dimension 8400 does not recognize my dvd/cd
The data cable may have come loose.
Posted on Jan 12, 2010
Dell insprion 530s won't start up just amber light on the motherboard comes on
hello, you will have to remove power cables, and leave for a while then reconnect it and try again. check out my blog for more tips ;
http://diyshelf.blogspot.com/
Oct 18, 2012 | Dell Inspiron 530 Desktop Computer
I want to restore my dell desktop insprion 530 to the original factory .In the F8 there is no restore option any longer. what should i do?
Go to the Dell WEB site and get a Recovery CD for your model Dell computer.
Boot up your computer with the Recovery CD to get your computer back to the out of the box condition.
Mar 23, 2012 | Dell Inspiron 530s Desktop Computer
Insprion 8500 cd drive problem
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 10, 2012 | Computers & Internet
I have a dell inspiron 530s desktop and my cr-rom dvd player does not work. It does not recognize any disc inserted!
HI,
If the drive was working fine earlier , and has suddenly quit working , Remove all media from the drive. Download and run the following patch from micorsoft . If it doesnot fix the issue the dirve would have to replaced.
Microsoft Fixit
Once you are on the above link. click on the green button that says run now.
Thanks for using fixya
Proton
Sep 03, 2010 | Dell Inspiron 530s Desktop Computer...
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
DVD/CD Drive will not open on the tower.
on your dvd drive there is a small pinhole. get a pin or stapler and push it through that hole. this pinhole is used for emergency situations like yours. your dvd drive will not be damaged
Jan 26, 2010 | Microsoft Windows XP Home Edition
I have an dell inspiron 530s desktop what types of cd/dvd burner do i have
Go to "My Computer" - this should be an icon on the desktop. Right click on the icon. Choose "Properties." Click on the Hardware tab. Click the "Device Manager" button. Navigate to the "DVD/CD-ROM" drives + sign. Click on the plus sign. Read about your hardware.
Mar 29, 2009 | Dell Inspiron 530s Desktop Computer
Dvd / cd rom not recognized on my computer list
1) Go to Control Panel. Open the System Icon.
2( Click on Hardware Tab, then click on Device Manager.
3) The device manager will list all of your hardware that is on your computer.If you see a yellow? mark oryellow ! mark next to your DVD/CD rom drive,simply click on it then click Repair. It also may tell you that it is not recognozied. Follow the directions.
4) If you do not see this in your Device Manager go to Add Hardware in your Control Panel which is next to your Add/Remove Programs icon. Click on Add Hardware and it will scan for all hardware.
** This should take care of your problem.If not then somehow the actual connection in your tower has come loose. If so you must open your tower and look for a loose wire going to your DVD/CD rom drive.
*** Please let me know if this corrects your problem.Simply email me(Phil) at: philw19642002@yahoo.com
Jan 01, 2009 | Gateway GT5468 Desktop PC
Computers & Internet Logo
David Payne
David Payne
