Question about SanDisk Sansa E280 MP3 Player
I've sansa E280 problem is connecting to pc in mtp mode
I've sansa E280 my sister bought from us.when ever i'm trying to connect it my pc in mtp mode it's showing error code10.she has loaded some instrumentals in it.there are not seen in system.but they can be listened.i don't have the software provided by sandisk cd.where can i download it from.
    Sniper:
  • 54 Answers
You can download the software from this page, the options are on the right hand side of this page.
http://www.sansa.com/support/sansa_e200/faqs
In order to get your Sansa connected, I would change from MTP to MSC and see if your PC recognizes the player then, as it should.
If you go into the settings menu and choose USB Mode and from there you can change to MSC from MTP. If you have one of those models that don't have a USB Mode option, then do the following to change to MSC:
(The model number followed by v2 on the back-bottom require this method) you have to turn it on, put the hold switch on, then hold the LEFT button |<< THEN plug it into the PC.
Posted on Apr 23, 2009
I re-formatted my Sansa e280 and now my computer does not recognize it. I am wanting to transfer music files only, using Windows Media Player.
Try to reset the device and if there is any driver for it, install them before connecting it to the computer.
Feb 28, 2011 | SanDisk Sansa E280 MP3 Player
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
Sansa not starting in mtp mode.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 23, 2008 | SanDisk Sansa E280 MP3 Player
Restart sansa e280
Try this: Press and hold the center button and the start button at the same time for about 10-20 sec. it worked for, plus thats what the ppl at sandisk told me to do.
Feb 13, 2008 | SanDisk Sansa e250 MP3 Player
My e280 sansa mp3 player is not working.....help please....
There is a problem with the device firmware itself..you can try to reset the player by holding the power button down for 15-20 seconds or until it resets....the latest firmware for the e280 resolved much of the freezing issues....also there are two modes for you to use the e280 the msc and mtp.....try deleting in mtp mode....if that doenst solve it...just go to the sandisk site to get a firmware upgrade done...and that would solve the proplems..
Jan 02, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 wont play downloaded music
The device has 2 modes on it MSC and MTP, if you changed modes and uploaded songs in the other mode, they are only visible on the PC in that mode. But, the PC will show the total amount of free space on the device.
If this is not the issue, I would try formatting your device to remove everything and start over.
You can FORMAT thru My Computer>Device Name (e280)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
You can also add to this question for additional support.
Nov 22, 2007 | SanDisk Sansa E280 MP3 Player
Sana e280 not dtected
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Oct 24, 2007 | SanDisk Sansa E280 MP3 Player
Usb problem
With the device connected, check the Device Manager for errors (red or yellow) on Mass Storage Device and update the drivers on them.
FYI - you need to have Windows XP / SP2 and Windows Media Player 10 or higher for the device to connect to the PC.
You can add to this question for additional support.
Best of Luck.
Oct 10, 2007 | SanDisk Sansa E280 MP3 Player
E280 and my computer do not connect
-Tha Mp3 Doctor
Oct 03, 2007 | SanDisk Sansa E280 MP3 Player
PC won't detect sansa e280 please help me
I had the same prob with my e280 yesterday and i bought it 4 days ago. I'm using a vista o.s. and i found a way to transfer files this morning. if you are using a vista os you should first set your sansa to MTP mode so that your windows media player can detect your e280 then you can start synching. If you are using XP o.s. there shouldn't be any prob with that but you have to switch to MSC mode. you can find these settings on the setting menu of your e280 then USB mode.you can also open the E280 player if you see it on "my computer" there you can transfer the files.don't use your wmp player when you are doing this on vista cuz the wmp player will also synch at the same time and it will synch the same file.
Jun 12, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
149 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
