Question about Alpine Swe-1000 8" Compact Subwoofer Built-in Amplifier Powered Car Sub Box
8" compact subwoofer not working it was installed
8" compact subwoofer not working it was installed by a car audio installer it worked fine for a few months after about 6 months it would take longer and longer for the sub to start working everytime i drove and now it only turns on sometimes. ive jiggled all power wires and checked all fuses everything is intact.. very clueless.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Post more information about your amp. its likely the vibrations moved something in the amps, or buttons.
Posted on Nov 15, 2013
  • 12 Answers
SOURCE: MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Posted on Jan 07, 2008
  • 74 Answers
SOURCE: Hi, I've just install an
If you have the RCA's running from the head unit to the amp, and the speaker wires running to the speakers then you have it hooked up right. Now If you still don't have any sound then you need to look at the amp to make sure that you have a green light. Still I would use 8 or 10 gauge power wire and then the same for the ground wire, make sure that you have a good ground.
Freakville03
Posted on Dec 22, 2008
  • 3 Answers
SOURCE: my sub quit working
first off you should have installed an inline fuse block that fuse will pop first an inline fuse is cheap go to a wall=mart it will run you around 10.00 that gets mounted under your hood cut your power cable in half the one part of the cable should be cut 12 inches that will tie into your possitive terminal on your battery after that is all tightened to your battery you will strip about an inch of coating offf of your power wire tie that into the end of your fuse block make sure it is tight than do the same to the other side just measure from there to your mounting spot for your amplifier and tie your power cable into your amplifier use 8 gauge power and ground cable... your problem with your amp is that you burned up a couple capasitors or even a resistor i just fixed an amp that both fuses were smoked just tear your amp apart look under the control board you will see were a sauder joint is cracked those capasitors and resisters are very cheap there made out of ceramic i just got done repairing my friends amp works like a new one.. good luck if you have problems or w you get it fixed email me.. gordo8785@yahoo.com best of luck buddy..
Posted on Jan 10, 2009
84chevypu
SOURCE: Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Posted on Apr 29, 2009
  • 3 Answers
SOURCE: hi ive got a alpine mrp-m1000 it lights up no
If your not getting any sound make sure the sub input is in the right spot on you radio. if not check the speaker wires on your harness
Posted on Feb 14, 2010
Tip
Car audio installation... important
when installing a sub woofer and amplifier to your vehicle always make sure that you also install a wired fuse in between your battery and amplifier without this problems may occur...
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
on Jun 03, 2010 | Car Audio & Video
Is the Wireless N 150 Ultra Compact USB 2.0 Adapter compatible with Windows 8 ?
Make sure you are on Windows 8 Desktop. Try download the Buffalo WLI-UC-GNM_E-105 driver and run setup.exe with XP SP3 compatible. After the installation, your Wireless-N150 Ultra-Compact USB 2.0 Adapter will be working fine in OS Windows 8.
Nov 03, 2012 | Buffalo Technology N-Technology...
Subwoofer pushing out problem
it sounds like one channel in your amp had shorted and letting dc go to the speaker...a speaker is an electromagnet and requires ac to make it pulse..the amp has a blown channel and would have to be repaired and a factory service center...there is no quick fix..
May 27, 2009 | Lightning Audio B1.10.4 Car Subwoofer
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
Phntom bass sounds
uhhh....try you change your wire setup
Sep 17, 2008 | Infinity BASSLINK Car Subwoofer
No Sound from Subwoofer
You should be able to check this yourself pretty easily, Just connect the power and turn it on. Connect an audio cable to the input. Make sure the level control on the sub is turned about halfway up or more. Now, touch your finger to the tip of the plug on the other end of the audio cable. You should get a nice hum out of the subwoofer. If not, then the sub is bad - if it has a user-replaceable fuse you might check that first. If you do get a hum out of it, then the sub is ok, and the problem is elsewhere. Might be a simple as a bad cable or an option on your amp/receiver is set wrong.
Feb 14, 2008 | Kenwood KSC-WA100 Car Subwoofer
Alpine Swe-1000 8" Compact Subwoofer Built-in Amplifier Powered Car Sub Box Logo
56 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
