Question about Ryobi Garden
I HAVE A ZAMA CARB MODEL C1U W7D MADE IN CHINA
I HAVE A ZAMA CARB MODEL C1U W7D MADE IN CHINA ..IT WONT START CAUSE IT OVERFLOODS AND GAS COMES OUT WHERE AIR FILTER IS. SO I DICIDED TO CLEAN IT UP THINKING THAT DIRT MUST BE CLOGGING THE GAS PASSAGE WAYS AND THROTEL NEEDEL TO STAY OPEN .WHILE CLEAN IT I SAW A MINUSCULE RUBBER COME OUT FROM THE CHECK VALVES IN THE PRIMER BULB..OOOPS. NOW I THINK I HAVE BIGGER PROBLEM .. Q- CAN I JUST PUSH THE RUBBER BACK IN THE CHECK VALVE HOLE OR I MOST ABSOLUTLY BY ANOTHER THROTTLE BODY.
  • 8 Answers
SOURCE: replaced new gas line, new primer bulb, new
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Have you checked the spark plug?
Posted on May 20, 2009
  • 3600 Answers
SOURCE: the primer bulb does not draw fuel thru carb
you need to buy a primer bulb kit and replace it cost about $8.00 and is easy to put in, the check valve is damaged.
Posted on Jul 18, 2009
  • 54 Answers
SOURCE: Primer button on homelite gas trimmer
It's possibly the filter, can't help there. I would check for a split line or loose connection between the tank and bulb and even splits in the bulb itself.
Posted on Apr 26, 2010
  • 1746 Answers
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Posted on Jun 13, 2011
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
  • 173 Answers
SOURCE: diagrams of zama carb c1u
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf
click the link anf find the user guide and instructions
Posted on Jan 19, 2012
Car wont start when hot
Well, if it is getting too hot then you are looking in the wrong area. I would check the water pump and the thermostat. Thermostat first, it is cheap and easy to fix.
Mar 12, 2014 | McCulloch Zama C1u M35a Carb For Blowers...
Wont start when hot
wont run when hot or start, had this problem about 6 months ago they said it was a vacume leak,they never told me where it was
Jan 01, 2014 | McCulloch Zama C1u M35a Carb For Blowers...
Zama C1u M35a Carb For Blowers P/n 322410
Probably so. I recommend contacting your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 05, 2013 | McCulloch Zama C1u M35a Carb For Blowers...
Diagrams of zama carb c1u
Jan 19, 2012 | Ryobi Garden
My Echo SHC-212 will start and slow idle but when I give it gas it boggs and stalls. I've changed the spark plug and I'm using the proper mix. Any suggestions? I was thinking of trying to clean the carb...
The prior posters must be from the Briggs & Stratton era :0] This is an EPA carb. You can only adjust the idle speed. The Echo SHC-212 uses the Zama RB-K75 carb.
My SHC-212 had the same bogg/stall symptoms. I had to disassemble and clean the carb to get rid of it. There is an internal filter screen that sometimes clogs. I soak and use compressed air to blow out all orifices. But the real problem is leaving ethanol gas in the carb during storage. It warps the delicate gaskets/valves. So buy Zama rebuild kit.
Dec 24, 2010 | Echo Zama Carb Kit For Shc212 Hedge...
Need A parts diagram for a Sthil G65 Blower carb.
Unfortunately, Stihl won't release any of their illustrated parts diagrams to anyone except Stihl dealers. The dealers won't release them either. It is possible that the manufacturer of the carb will have a breakdown listed on their site. Stihl primarily uses either zama carbs (www.zamacarb.com) or Walbro carbs (www.walbro.com). Look on the carb for engraved numbers and letters to let you know what series and model to search on. The manufacturer is usually listed either on the bottom diaphragm plate or up on top. Walbro series usually start with a WT, or WA. Zama will usually have a C series (ex. C1U)
Nov 02, 2010 | Garden
.trying to get a reassambley diaigram for carb
Find out what model carb it is...eg...C1U...C1Q...and look at one here: http://www.m-and-d.com/zama_carburetor.html
Aug 31, 2010 | Poulan Garden
My weedeater lawn edger wont start. I get no gas in the primer bulb, but has fuel in both the main line and the return line. I blew out the fuel fliter and both lines but still no fuel in the primer...
There may be a malfunction in the check valves in the primer base assembly. Before attempting to get a new assembly, take the retaining screws at the bulb off, remove the bulb and spray the assembly liberally with WD-40 or an equivalent light lubricant. Sometimes this will free the check valves as they only let fuel flow one way and there are 2 of them in the primer base.
Do not use strong solvents, do not ever soak, and never use high PSI compressed air on these carbs. Sometimes, when the check valves in the primer base go bad, the carb floods and the reason is unclear. Zama doesn't list this as a reason for their carbs flooding, but they can. You may wish to view a parts breakdown list for your specific carb. You will need to know the type (stamped in side of carb body) and the model (stenciled in side of carb body). It will be something like a C1U type and a W-18A mode...thus its a C1U-W18A Zama carb. Here is a link to get you started.
http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
Yours will be listed under Poulan/Weedeater
Aug 22, 2010 | Garden
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Garden Logo
55 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
