Question about Dell Inspiron 530 Desktop Computer
The orignal CD/DVD drive on my insprion 530s is not working, i cannot use the button on the tower to open it and its not showing on the computer. how do i fix this?
  • Dell Master
  • 3,799 Answers
Check the cables inside the tower. If they are still connected, then buy a new drive, they only cost a few pounds(GBP)
Posted on Oct 10, 2013
  • 2427 Answers
SOURCE: IDE Drive not found on startup
I am assuming that the cd and DVD drives are on the Ide right ?? thats because one of the drives jumper is set wrong. If you take a look at the back you will find it saying master / slave / Cable select with eighter a 6 to 10 pins. basically one needs to be set to master and connected with the top piece of the cable and the other set to slave and connected with the middle of the cable. and the other jacks into the main board. If i misunderstood you please respond correcting me as soon as possible so i can be of further help.
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: Problem with Inspiron 530S Desktop Reading CD's
If your computers are relatively old then they may not be able to burn CD's or read CD's that were burned. A new CD/DVD burner is relatively inexpensive and easy to install.
Posted on Jan 02, 2009
pcdoctoraz
  • 38 Answers
SOURCE: i cleaned out my start up folder and now my cd-dvd
you will want to check the device manager to see if the drivers are not working properly.
Go to start then right click on my computer and go to properties
On the left side of the properties window you will see device manager click on that and find the dvd/cd-rom drives
click on the plus icon to the left of that and it will show you the drives right click and select update driver and then select search automatically for updated drivers.
Posted on Jun 08, 2010
joecoolvette
  • 5660 Answers
SOURCE: My internal CD/DVD drive and Burner quit working.
As I'm sure you are aware a CD/DVD drive is a mechanical device. It's 'lifespan' is rated in hours of usage. With the C521 being 4 years of age, I wouldn't think the DVD dual-layer burner drive would be defunct. Does depend on how much it's been used.
Ordinarily I would state cleaning the optical eye in the CD/DVD drive, and also reinstalling the drivers, if a disk is not recognized. However the, " Computer does not recognize it as a drive.", statement concerns me.
Suggest you try the software approach first of reinstalling the drivers, then if you wish go on to the hardware approach, of checking to see if the data, and/or power cable is loose on the DVD drive.
Reinstalling the Drivers:
The main method;
1) Left-click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) In the Device Manager list, left-click on the + sign next to Disk Drives.
7) Now right-click on the name of the DVD drive.
Here you will have the options of either Uninstall, or Update Driver.
I suggest you left-click on Uninstall.
Update driver seldom works.
A warning will come up, "Warning you are about to uninstall this device, ya-da, ya-da"
It's okay. Click on OK.
Close all windows, go back to your desktop screen. Shut your computer down normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute, turn your computer on.
After Windows has loaded you should see a pop-up out of your system tray, "Found new hardware".
Plus perhaps another one, "Found XXXX DVD writer"
Still no?
Then it's time to check the above mentioned cables.
Your Dimension C521 uses a SATA optical drive. (DVD drive)
The Data, or Interface cable looks like this,
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
(The color of the cable may not be the same, and it may not have a 90 degree elbow connector)
It is a 7-pin connector.
Make sure it is plugged in tightly to the back of the DVD drive, and also to the SATA header on the motherboard.
NOTE*
BEFORE you reach inside your computer!
Computer unplugged from power, observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static will Fry Out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, working on a table, open the computer case.
TOUCH the metal frame of the open computer case, to relieve your body of Static.
Should you get up, an walk away in the middle of working on your computer, upon your return be SURE to touch the metal frame again.
Computer unplugged from power, you're safe. TOUCH the metal frame of the open computer case, your computer is safe.
Here is a link to Dell Support, and the Service Manual for the C521,
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/index.htm
You will see - Removing the Computer Cover, and Replacing the Computer Cover.
In the main menu list you will also see - Technical Overview.
If you click on this heading, and then on - System Board Components, you will see the motherboard in an illustration.
Here you will see the Ram Memory slots. Below them is where the 24-pin ATX main power cable plugs in, (No.5), and to the right of the main power cable are two SATA headers, on the motherboard. (No.6)
Your SATA harddrive plugs into one of these SATA headers, and your DVD burner optical drive, plugs into the other one.
The SATA power cable going to your SATA DVD burner drive, comes from the Power Supply. It's a 15-pin connector. Looks like this,
http://en.wikipedia.org/wiki/File:SATA_power_cable.jpg
Be sure it's plugged in tightly to the DVD burner drive.
It could be a bad SATA Data cable.
More than likely your DVD drive is just toast. Seen the last of it's days.
Your Dimension C521 uses a regular size SATA DVD burner drive, even though it's a Slimline style of computer.
There are MANY drives available, should you decide to replace it.
You can also use one of these drives in an external enclosure. This way you just plug it's USB cable, into any available USB port on your computer.
If I were to recommend a SATA DVD burner drive, I would recommend one of the Lite-On models.
Cost less than most, but have features, and reliability of those that cost 3 to 5 times as much!
I'm using a Lite-On model that cost $48 from a large store, but could have purchased it for $28 online.
It's a DVD SATA burner drive that will support dual layer disks, and has LightScribe Technology.
Has lasted over 4 years now, and a clients computer that I installed the same model, has lasted over 5 years now.
Zero problems.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5204603&CatId=4
(I see they're cheaper now, sheesh!)
Barring you do not wish to open your computer, and replace your DVD burner unit, here is an example of a 5.25 SATA external enclosure,
(A laptop harddrive is 2.5 inches across in width. 2 and a half inches. A desktop harddrive is 3.5. An optical drive is 5.25 inches. 5 and one-fourth inches),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2414551&CatId=2784
If you have any questions please post them/it in a Comment.
Regards,
joecoolvette
Posted on Sep 08, 2010
GSPOT12
  • 75 Answers
SOURCE: Need Help, Dell desktop inspiron 530s, Code 10 CD
Hi!
I assume you are using Windows Vista. To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click Start , type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue .
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters , and then click Delete .
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters , and then click Delete .
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Thanks for reading my suggestion and I hope this helps.
Posted on Apr 17, 2011
Testimonial: "Great effort with detailed information, thank you!"
The orignal CD/DVD drive on my insprion 530s will not open, i cannot open it by the button on the tower and its not listed on my computer. How do i fix this?
First Remove it from desktop. And reconnect the SATA on other SATA Port and start the PC and check it in BIOS , is it detecting ?
if yes then check it in MY COMPUTER also. otherwise check with amother SATA cable and if it is not detecting with another SATA cable then ur dvd drive have some proble.
Oct 10, 2013 | Computers & Internet
Dell insprion 530s won't start up just amber light on the motherboard comes on
hello, you will have to remove power cables, and leave for a while then reconnect it and try again. check out my blog for more tips ;
http://diyshelf.blogspot.com/
Oct 18, 2012 | Dell Inspiron 530 Desktop Computer
I want to restore my dell desktop insprion 530 to the original factory .In the F8 there is no restore option any longer. what should i do?
Go to the Dell WEB site and get a Recovery CD for your model Dell computer.
Boot up your computer with the Recovery CD to get your computer back to the out of the box condition.
Mar 23, 2012 | Dell Inspiron 530s Desktop Computer
My Cd/ Dvd Thingy Isnt Working .. It Opens But Nothing Happens.!
sometimes you have to open ur computer and attach a thin long cable. There is normally one just loose in there for an extra drive. use that one as your main one and it should work
Dec 15, 2010 | Dell Inspiron 530s Desktop Computer
I have a dell inspiron 530s desktop and my cr-rom dvd player does not work. It does not recognize any disc inserted!
HI,
If the drive was working fine earlier , and has suddenly quit working , Remove all media from the drive. Download and run the following patch from micorsoft . If it doesnot fix the issue the dirve would have to replaced.
Microsoft Fixit
Once you are on the above link. click on the green button that says run now.
Thanks for using fixya
Proton
Sep 03, 2010 | Dell Inspiron 530s Desktop Computer...
I cleaned out my start up folder and now my cd-dvd drive will not recogonize or open any discs. dell inspiron 530s running vista.
Jun 08, 2010 | Dell Inspiron 530 Desktop Computer
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
DVD/CD Drive will not open on the tower.
on your dvd drive there is a small pinhole. get a pin or stapler and push it through that hole. this pinhole is used for emergency situations like yours. your dvd drive will not be damaged
Jan 26, 2010 | Microsoft Windows XP Home Edition
I have an dell inspiron 530s desktop what types of cd/dvd burner do i have
Go to "My Computer" - this should be an icon on the desktop. Right click on the icon. Choose "Properties." Click on the Hardware tab. Click the "Device Manager" button. Navigate to the "DVD/CD-ROM" drives + sign. Click on the plus sign. Read about your hardware.
Mar 29, 2009 | Dell Inspiron 530s Desktop Computer
Dell Inspiron 530 Desktop Computer   Logo
mukhtar21 shaikh
mukhtar21 shaikh
