Question about Dell 922 All-In-One InkJet Printer
Prints perfectly most of page, then slips for one line only
The paper seems to feed perfectly for most of the page, but then slips/feeds wrongly so that one line of print is 'smudged' - not quite the right word, just prints as if cartridge has run out. Doesn't do this on the same line on every page! Very frustrating.
    Champion:
  • 214 Answers
Print feed in roller has a flat spot- needs replacing
Posted on Apr 23, 2009
Prints one page and jams, displays paper jam
so it does print and exit one page before it jams? if so you have something wrong with the exit sensor. if it does not feed it all the way thru it might not be feeding paper in to the machine fast enough. the feed tires might be dirty.
Sep 23, 2014 | Samsung Ml3312nd Black White Laser Printer
I try to print and the printer just prints the first of several pages and the online/error red led comes on.
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Oct 08, 2009 | Samsung ML1740 Laser Printer
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Paper missfeeding
seems since one side is working that you might have a bad motor in your printer. i would take it back to the store you bought it from, assuming your warranty is still within its validility .
Jul 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
I can't seem to control which tray the paper is fed from.
My idea is that you have the wrong printer for the job. Yes. It will automatically take anything that is put into the upper feed section, because it is actually the same feed section- it uses the exact same feed rollers to feed from the bypass tray as the main tray, this is designed only as a convenience for the occasion you want to print different size paper you may want to run, or for re-feeding for duplex
Mar 21, 2009 | HP LASERJET P1006 Printer
Okidata Microline 320 Turbo Printer - forms don't maintain registration
On older printers, tractor feed edges separate from the page while printing. Sometimes this can be a fluke, but other times it may point to a mechanical problem. Try taking the paper out of the printer and hitting the form feed button a few times. Watch the printer’s tractor feeds to make sure they are moving and are in synch with each other. Some printers use belts to move the tractor feeds and, over time, these belts wear, break, become smooth and slip, or become misaligned.
Environment can also contribute. Paper stored in a warehouse can weaken in intense heat or moisture. Carbon copy paper will especially cause this type of problem as one sheet's feeder edge can break away from the rest and peel slightly back. This will in turn slow the feed on one side as the edge buckles slightly under and may even skip to release pressure causing major alignment problems.
Sep 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
When printing Glossy paper 260gsm, on my HP 4280, the paper appears to be slipping in the feed roller and the image prints too far down the page. Any ideas ??
Take the back cover off, and you will see the feed rollers in there. Use a soft cloth and some all purpose cleaner and gently clean the rollers, not too much liquid on them, lat dry and clean again for couple or three times. You feed rollers have become soiled and are slipping on your paper. I have three hp printers and this must be done every couple months or so. I think I found these instructions on hp.com if I remember right.
Aug 16, 2008 | HP Office Equipment & Supplies
HP PSC 2355 won't feed photo paper
You can't use the photo papers in this kind of printers
Aug 01, 2008 | HP PSC 2355 All-In-One InkJet Printer
Feed problem
line gear has a broken tooth on it, possibly. or you have a sliver of paper stuck under the plenum (large black roller that paper wraps around to feed). you can pop the cover off, by pulling the front edge up and away from the base (clips in only, no screws). remove the plenum with tabs that pull up on either side of it. pull out the plenum, and check for any paper under that area. good luck.
chris
Apr 18, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
HP LaserJet 2100/TN
Replace toner cartridge drum/blade RS, slim faint outside chance it is a fuser (hot bit rear) problem, doubt feed issue
To confiirm to yourself it isn't a feed issue, try feeding A4 via manual bypass (envelope slot) and doing a print using manual bypass tray, just override size missmatch warning if it appears (tick i think when beeping). should do same fault as feeding via cassete
You can also print a test page from printer via operations panel to confirm it is printer problem not software.and you can do a paper path test from whatever feed slot
To eliminate it being fuser problem try printing and turning the power off when paper is 1/2 way threw print job, remove cartridge and exaimine unfused (still image rubs off) print, if image is fine then it is a fuser issue but be carefull to note how much of a page needs to be printed before image repeats so you know if it is right or wrong.
But thats just tecnical possibitys, Change cartridge should fix!
Odds are 95% cart 4% fuser 1% others i reckon!
Oct 19, 2007 | HP Color LaserJet 2600n Printer
Dell 922 All-In-One InkJet Printer Logo
115 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
