Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
No spark on kohler generator 4ckm21 - Kohler CH25 PA-CH730-0040 Command Gasoline Engine
    Sergeant:
  • 417 Answers
I don't have any idea what Carl just said, but remove the little ground wire from the coil and try to start the engine. If it fires and runs ok, you have a grounding issue somewhere and need to follow the wires around to see if anything that shouldn't be touching metal, is.
Posted on Nov 21, 2013
3 Suggested Answers
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
SOURCE: 4ckm21 generator runs only if
I had same problem and to make a long story short, it wasn't any common problems like oil pressure switch, etc. Solution was the start stop coil/ ignition coil. Looks like a 1" ice cube behind the panel and it usually (not always) has a tattle tail indicating failure.
Posted on Jan 29, 2011
My 20kW Kohler home generator (nat gas) cranks but won't start. Definitely getting fuel. Everything checked in October with new spark plug. Maybe a setting?
Did you check the oil level? Some generators have a oil sensor that will now allow it to start if the oil level is too low.
Mar 14, 2017 | Kohler Electrical Supplies
My kohler 5750009 generator will run perfect for about 2 hours then shuts off. It will restart. What should I check?
See if there is a heat shield for spark plug. Make sure proper plug is installed and gapped.
May 19, 2015 | Kohler Electrical Supplies
My kohler 4ckm21 generator starts great but will run for 8 min. and shut down ?
If it runs that long, you may have a bad oil pressure switch, loose connection, or fuel pump. You didn't indicate whether the time was under laod or not
Aug 07, 2013 | Kohler Electrical Supplies
Kohler 12RES only starts on second try
Check gas pressure. Oc is over crank. Means tried to start but did not.
Nov 25, 2012 | Kohler 12 kW Emergency Power System -...
Kohler generator wont stay on
Check the oil pressure switch, and oil level first. Then check rotor brushes and rotor slip rings may need polishing. If the problem is still there check stator and rotor windings
Aug 25, 2012 | Kohler Electrical Supplies
4ckm21 generator runs only if holding down starter switch
Jan 19, 2011 | Kohler Electrical Supplies
I have a new Kohler 12kw res generator on propane - backfiring
Is the outside air temp cold. These generators will backfire if it is real cold and if the propane pressure is low. It is suppose to be 11 to 12 inches of water colume at the generator fuel input. drygwals
Feb 18, 2010 | Kohler 12 kW Emergency Power System -...
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
304 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
