Question about Samsung Computers & Internet
My samsung s2 portable hard disk cannot be accessed, it tells me to format the disk before use, but cannot because i have some important files on it, please how do i back it up
  • 93 Answers
SOURCE: formated hard disk
Go to Computer Management
Then click Disk Management
You Will find Your Portable HDD without Drive Letter
Just Right Click and Assign a Drive Letter...
Thats all...
Enjoy..
-Rajkumar
Posted on May 19, 2009
  • 10406 Answers
SOURCE: samsung s2 portable 500 gb
Is it still under warranty?
Try connecting it to a different USB port on your computer.
Try connecting it to a USB port on a different computer.
If it still is not detected, then either exercise the warranty,
or disassemble the case, to find two major parts:
* a disk-drive
* a USB-to-disk-drive adapter
Disconnect the disk-drive and connect it as a "slave" disk-drive in some desktop computer, to see if it is recognized, i.e., if it was the USB-to-disk-drive adapter that has failed.
If it still is not recognized, then it is "dead". You could buy a similar disk-drive, install it into the enclosure, and thus create another external storage device.
Posted on Oct 20, 2010
drifterK
  • 4924 Answers
SOURCE: not able to copy /delete
take a look at the properties..by right click on its icon on my computer ..and see if it is not set to read only ...or right protected...cause this may cause the data not to be able to be changed or formatted ..If on properties the read only is ticked ..just clear the case ..and let it empty ...after that try to format it again in Fat32
Posted on Jul 05, 2011
CreativeTECH
  • 1719 Answers
SOURCE: i have a problem with
It is due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset. Just drag the files/ folder to the iReset and it would change the folder attributes to normal and you would be able to view the files normally.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Posted on Jul 20, 2011
SOURCE: Samsung S2 Portable no longer detected
same problem here, started happening just yesterday and now it's just flashing and is never detected.. I've tried emailing the Samsung support, will tell you if I receive any useful answer (as proposed by the very helpful person at http://www.fixya.com/support/t8050821-dear_fixya_trouble )
Posted on Oct 11, 2011
Samsung s2 portable
remove your hard and put it back or use a soft to restore your data files
Dec 15, 2013 | Computers & Internet
I tried to format my Samsung s2 Portable hard drive from NTFS to Fat32 and now my Toshiba laptop will not read my hard drive
Be careful, don't put anything new or do any operation on your drive no matter if your Samsung drive can be read or not because it can product your files, all of your files in your drive will not be overwritten or deleted. If you still cannot use it (means it can not be read), you can try to format it again and use the data recovery software to help you to recover lost data. Here is one for you uflysoft.com. But you should pay attention, make sure you can recover lost data first, then try, just try the software, OK? God bless you.
Aug 13, 2013 | Samsung S2 Portable HX MU010EA 1 TB...
Samsung s2 portable, folders are showed as shortcuts !
OK you harddrive is infected with Malware. This Malware creats shortcuts of each folder and Hide the all those your main folder.
You can scan your Hardrive with fully updated Anti Virus apllication .
To see all your original folder you can enable your Shown hidden File option from your Folder option--View--uncheck show hidden files and folder--and uncheck hide protected operating system files.
Here is the step to unhide your all files and folder in one go.
Step 1:
Click on the below link and download the file "AutorunExterminator"
http://en.kioskea.net/download/download-11613-autorun-exterminator
Extract it --> Double-click on "AutorunExterminator" --> Plug your Hard drive now.
This will remove the autorun.inf files from your flash drive and also from drives.
Step 2:
Click on "Start" -->Run --> type cmd and click on OK.
Here I assume your flash drive letter as G:
Enter this command.
attrib -h -r -s /s /d g:\*.*
You can copy the above command --> Right-click in the Command Prompt and
paste it.
Note : Don't forget to replace the letter g with your flash drive letter.
Now press "Enter".
this should solve your problem.
Jul 27, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
Samsung S2 1TB Hard Drive on my mac?
settings issue but more importantly the drive must be formatted for a mac. if that has not been done then that's what's on order.
back up data first though
Jun 18, 2012 | Samsung S2 - 1TB USB 2.0 Portable...
I have S2 portable 640gb external hard drive. Do not open the main folder with info and gives me only shortcuts and no way to my folders
Do you think my problem is a cable wear or the device itself
and how can get access to my data
can anyone hepl me
please
May 05, 2012 | Samsung S2 Portable 640 GB USB 30 External...
My daughter's new Samsung S2 hard drive appears on her mac (she has backed up her mac on it) but will not appear on PCs. She wants to use it to store files from PCs as well. Any suggestions?
It sounds like the hard drive is formatted for mac only. What you need to do is the following:
To totally reformat the hard drive go to your applications folder and then to the utilities folder and double-click on disk utility. In the left hand column select your drive then select the erase button once on the erase section select the format you want to format the drive in. For both mac and PCs select MS-DOS (FAT)) then choose the name you want to call your drive and then select erase (REMEMBER THIS WILL WIPE ALL THE FILES ON YOUR HARD DRIVE.)
You could also use a PC to format it, although as a mac user I do not know how to but the following webpage could be of use http://www.ehow.com/how_6026_format-hard-drive.html
Hope this helps.
Sep 15, 2011 | Samsung S2 Portable External HXMU010EAG32...
I bought a brand new samsung s2 320 gb external hard drive and use it for several months until consuming about 200 gb of its storage space, I started to have problems in accessing my data. I tried several...
Only store file on the drive not programs. Working program cause to much ware and tare on the external drives.And a partition on a driver that has programs running from it works real hard because it moving file from two sectors of the drive at the same time. Can you be in two places at the same time?
Feb 06, 2011 | Samsung S2 - 1TB USB 2.0 Portable...
May 27, 2010 | Samsung Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
