Question about HP Hewlett Packard CE399A 75-sheet Envelope Feeder For Accs Laserjet -
How does HP CE399A envelope feeder attach to printer? how well does it work?
checkitright
  • 1362 Answers
SOURCE: HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Posted on Oct 18, 2007
SOURCE: Cannot print odd-sized envelope with 4250 LJ
We are using standard size envelopes and the default used to be drawer one. Now if we have envelopes in the manual feed it wants to pull from there no matter what we select.
Posted on Aug 13, 2008
  • 105 Answers
SOURCE: 4250 HP. Loses settings. Correct to show envelope
In the paper-handling menu set the envelope feeder size to the size of your envelope and the envelope feeder type to *any type.
Then ensure you are printing envelopes from your application.
Posted on Nov 25, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: How do I install the envelope feeder tray on the
As long as you have the correct envelope feeder then it just locks into place on the front of the printer. Simply open the tray 1 feed door (the one with the model number 4050 on it) and your envelope feeder just "locks" in just above the open tray. If you look at the printer you will see a small square connector block. Now look at the envelope feeder and you will see where the 2 meet together. Then match up the 2 and "lock" it in place.
Posted on Dec 08, 2009
Ranglo
  • 1194 Answers
SOURCE: envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Posted on Feb 20, 2010
HP Laserjet 4200 with optional Envelope Feeder will not automatically pull #10 envelopes from Envelope Feeder?
Use a damp lint free cloth and clean the feeder rollers.
Print out a configuration page to make sure that the printer recognizes that the feeder is installed.
Usually the envelope feeder problems stem from age and/or dirty rollers.
Make sure that your software app sees that the feeder is attached.
Feb 08, 2011 | HP LaserJet 4200 Printer
Prints dirty only with evelopes
hp recommends purchasing an envelope feeder (part # CB524A.
when using an envelope feeder the speed at which the envelopes go thru the machine changes....this should solve dirty copy issues.
Jan 08, 2010 | HP LaserJet P4014n Printer
How do I install the envelope feeder tray on the HP 4050n printer I have the feeder tray but no instructions to put it in. thank you
Dec 08, 2009 | HP LaserJet 4050n Printer
Nov 25, 2009 | HP LaserJet 4350 Printer
Not sure how to feed the envlope into the printer
Follow these steps to use the photo/envelope feeder for single envelopes:
1. Insert the envelope into the photo/envelope feeder with the side to be printed on
facing down and the flap to the left.
Push the envelope into the printer as far as it will go without bending.
3. Slide the photo/envelope feeder forward as far as it will go.
Thank you for using Fixya
Oct 08, 2009 | HP DeskJet 6988 Printer
My printer willnot print envelopes.It states paper size or type is incorrect. On all sizes.
Some printers have an extra feeder under a door on the front or side which allows you to insert an envelope. These types usually will not rcognize an envelope when inserted into the sheet feeders.
If you are using Microsoft Word, you may be able to do it from the "Tools"/"Envelopes & Labels" tab, but you more likely need to find the envelope feeder on your printer, if it exists.
Good luck !!
Oct 10, 2008 | HP Office Equipment & Supplies
I got to HP tech support, and they tell me that the envelope feeder is intended only for a few standard envelope sizes. If we're trying to use a different sized envelope, as in this case, it must be fed manually, and the feeder bin will not work. So that answers that. Thanks for the help, though.
Apr 29, 2008 | HP 4250 Monochrome LaserJet Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Attach envelope printer & tips for using
On the 4039 model the manual paper feeder fits on the back of the printer. There are two arms that fit into the back of the printer and it just sort of rests there. It takes a little bit of trying to get it right if you've never done it before, but a little patience and you'll get it. If you have a newer lexmark than a 4039 the feeder attaches to the front on top of the lower door. Hope that helps.
Aug 24, 2007 | Lexmark 4039 Model 10Plus Laser Printer
Printer says it's out of paper but it isn't
Do you mean a real plug in envelope feeder or are you using tray 1?
Jan 19, 2007 | HP LaserJet 4 plus Printer
HP Hewlett Packard CE399A 75-sheet Envelope Feeder For Accs Laserjet - Logo
56 people viewed this question
Seeker5211
Seeker5211
