Question about Livestrong Fitness LS10.0T-2 Treadmill
Getting a walking belt vibration and related noise when walking in the center of the track and close to the front roller. Vibration is not present when walking on the sides and at the rear. Machine is cleaned well and lubricated. It is 2 years old with very little use. Is it the front roller?
    New Friend:
  • 6 Answers
B) stretched the belt by turning half a turn at back allen of your treadmill
Posted on Oct 21, 2013
    Top Expert:
  • Livestrong F... Master
  • 12,223 Answers
See the video attached and lube too the rollers bearing front+back very well.
test the drive belt motor, and the motor for to see if the motor is loose the bolts, or loose the belt or replace the belt if is damaged and tight a little with deflection 1/4" max.
I f the problem persist you have to replace the deck belt completely.
God bless you
Posted on Oct 11, 2013
  • Jonh Ant
    Jonh Ant Oct 21, 2013
    A) lubrican the center of your tredmill belt with a silicone oil
  • ernesto cuadra
    ernesto cuadra Oct 22, 2013
    yes you must do it silicones or wax, depend from your instruction manual read it. God bless you
Belt stops at slow speeds
Check the walking belt is tensioned correctly.
Remove power from the mach.
Most machines you should be able to slide your hand under belt, only to about the center of your palm or maybe your thumb.
if walking belt tension is correct. make sure the delt has lube on it. Your owners manual will determine what type (wax or silicone) or manufacturer to use.
When inspecting the deck (laminated board under the walking belt, which it slides on top of), check for wear or damage.
Worn decks and belts should both be replaced at the same time.
Beyond a walking belt area issue, check the drive belt under the motor hood. connecting the drive motor to the front roller. try twisting the belt on its axis. about a 30degree deflection would be standard. If this belt is loose, the front roller is loosing its drive.
Sounds primarily like a belt/deck lube or wear issue.
Jan 05, 2013 | Nordic Track Nordictrack Track C3000...
Belt stops when you stand on it
Hi, yopu have a loose belt or a bad front roller, remove the hood(front cover), and start and run the treadmill. Get on it and watch to the left where the belt is, you are watching to se if the front roller is stoping when you walk on it. Most likley. you have a stripped plastic pully on the front roller. The belt and the pully turn fine, but where it is pressed on the steel drum (roller), it just spins. You need to replace the front roller.
Nov 30, 2011 | Nordic Track Nordictrack Exp 1000...
How do I change the walking belt on a Nordic Track EXP 2000?
First, remove the motor hood. There are 3 screws at the front, and 2 underneath. The screws underneath will have to be removed by tipping the treadmill over, or pulling the console towards the rear of the machine.
Next, remove the side rails. This is a little tricky because of the cushion adjusters on each side of the deck. If you look underneath the deck, you will see that the adjusters are on rails that are attached to the platform. Remove all of the screws from the side rail and push it toward the rear of the machine while also moving the adjusters rearward. You'll have to kind of move them together until the adjuster slides off the rail. Do both sides.
Remove the rear roller, by loosening the bolts. Don't mess with the front roller unless you intend to replace the motor belt. You don't need to remove the front roller or the walking belt.
There are 4 bolts holding the deck to the frame. The rear ones go through the frame to a lock nut. The front bolts screw into the isolators. Remove them and the deck will come loose. You can slide it out from the walking belt.
Place the new deck next to the old, and start moving the parts over. Make sure the safety decal is on the bottom like the old deck. All of the holes are pre-drilled except for the belt guides. You'll have to measure for these. Now do everything in reverse to reassemble the machine. I'm also attaching instructions on how to adjust the belt.
First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it's the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can't find it, a standard (not metric) allen wrench kit will work. It's helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you're tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn't necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I'm showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
The above instructions is a generic one for this series. A slight adjustment might be required.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 01, 2010 | Exercise & Fitness
How do you adjust or tighten the belt on the Nordic Track A2750 The belt is riding to one side of the platform
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 14, 2010 | Nordic Track NordicTrack A2750 PRO...
C2200 belt is slipping how to straighten and tighen belt
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
Good Luck!
Mar 11, 2010 | Nordic Track /proform Treadmill...
When running the belt is jerky and feels like it slips a bit Dan
Good Luck!
Mar 06, 2010 | HEALTHRIDER Pro H500i Exercise Workout...
I am having problem with the belt moving when i am trying to walk/run on treadmill
Good Luck!
Mar 04, 2010 | Proform 760 CrossTrainer Treadmill
My nordic track c2000 apears to start working but then the belt stops, if i step off belt it starts working again
Good Luck!
Mar 03, 2010 | NordicTrack Exercise & Fitness
How do you replace the walking platform on the Nordic Track A2250 Treadmill?
Good Luck!
Mar 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Livestrong Fitness LS10.0T-2 Treadmill Logo
109 people viewed this question
Top Livestrong Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Livestrong Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
