Question about LG Washing Machines
Impeller has come lose from tub - LG Washing Machines
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Impeller spline worn out already
Posted on Nov 06, 2013
Pump hums but nothing happens
Sounds like the pump impeller is stuck. Shut off the power and check to see if the pump has a small round cover on the end opposite from the pump. Some pump motors have a slotted shaft that you can insert a screw driver and manually turn back and forth to loosen the stuck impeller otherwise drain the tub and remove the pump to access the impeller and attempt to free it.
Hope this helps.
Bob
Jun 01, 2014 | Crane & Co Crane Plumbing 2430W Whirlpool...
Great lakes hot tub humming sound
You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
Front loading washer, kenmore 417.42052100 won't completely drain and leaves a tub full of water. Has been getting worse over the last week and now won't drain at all. Took off front panel to try...
The drain filter/coin trap is blocked or the pump is no longer working. The filter/trap is located inside the big black hose that runs from the bottom of the tub to the pump and hence the name tub-to-pump hose. Clean the filter and inspect the pump impeller for damage or restriction.
Disconnect power then remove the screws attaching the bottom front panel to the cabinet then pull the panel down and off. Once the panel is off, you can now loosen the clamps securing the tub-to-pump hose to the bottom of the tub and the pump's inlet then take the hose out and clean the filter/trap.
You should find foreign objects such as coins, toothpicks, hairpins and the likes blocking the filter. Clear the filter from the foreign objects and inspect the pump impeller by turning it with your finger. The impeller may be restricted or damaged resulting in the water not being pumped out properly or none at all. Replace the pump if the impeller is broken or restricted and doesn't turn freely or if the pump is no longer operational. You can tell the pump is no longer operational if all are clean and the impeller is in good shape and turning freely. Reassemble the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
Jun 20, 2011 | Washing Machines
FRIGDAIRE WASHER FRONT LOAD MODEL#GLTF1240ASO DOES NOT GO TO HIGH SPIN . A CHECKED DRAIN PUMP REPLACED DOOR SWITCH AND REPLACED SPEED CONTROL CHECKED BELT
Hi, are you sure your pump is operating properly any little thing caught in the impeller will stop these pumps. You also say there water still in the tub it will definitely not spin fast with water in the tub. Remove the pump and inspect the impeller sometimes there are things caught in it and other times the vanes are broken right off.
Apr 21, 2011 | Washing Machines
The pump runs but the water is not flowing in my Oasis spa tub
Your impeller has spun the center out of it. Remove the pump and replace the impeller.
May 30, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Pump impeller rubbing on tub
Did or could have something get dropped on impeller?
Or a utensil get in it?
The metal shaft may have gotten bent or tweaked.
To adjust turn impeller till you see the rub.
Lift up side that is rubbing and down a little on the side that is not. Be very careful you are working with plastic.
Don't break it just a little at a time. Turn and check as you go.
May 18, 2010 | Dishwashers
Washer will not spin and drain water after washing. The timer will run thru it's cycle and you can hear it running but after the wash cycle it does nothing.
The water must drain away before modern electronic controls will allow 'spin' to occur. Check the hoses to and from the pump for kinking and the drain port at the bottom of the outer tub for any debris in the tub that can obstruct water outflow. If all looks ok, concentrate on the water pump itself--the motor must run, but the impeller in the pump may not be turning with the motor shaft. Impellers in these pumps are made of plastic and are lightly splined to the motor shaft. Sometimes these splines shear off and the impeller remains relatively motionless. It might be possible to 'super-glue' the impeller to the shaft or just replace the whole pump mechanism. Hope this helps!
Apr 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
Apr 10, 2010 | Waterway 1.5 Hp 115 Volt 2 Speed Side...
I had a water leak at the pump on my hot tub so I removed the motor and pump assy for repair. I removed and disassembled the wet end and determined I needed a new seal and impeller. Here's where the fun...
Here is your owners manual.
You have the correct impeller part number and the seal is a standard replacement part.
Please contact us thru www.arrowpools.net for a quote on the exact price and freight charges. Before freight, your parts would be about $20.
I can not help you with a whole wet end at this time but the parts should be available within a few days time.
Dec 04, 2009 | Home
WATER STANDING IN THE DRUM AFTER WASH CYCLE
can you see water in the tub, or do you hear water when you turn the tub? if you hear water when the tub turns, it is not water. the stainless drum has a liquid inside it for balancing loads. if this is the case, there is no problem. but if you see water in the tub that didnt drain, you need to check the pump and the hose from the pump to the outer tub. look for restrictions (coins, tooth pick, nail, ect.). also check the pump impellers to make sure none of them are broke, there are three plastic impellers. if any are broke, replace the pump. hope this helps you. let me know if you have any further questions. shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
