My canon mf4350d is making grinding noises after crumpling a copy
4 Suggested Answers
SOURCE: cartridge jammed grinding noise
I just did a cleaning.
Posted on Apr 29, 2009
SOURCE: Canon PIXMA 530 grinds away
I had a persistant grinding noise about 30 seconds after the printer finished printing. It's been going on about 2 months. I did one thing which seemed to work. So try opening the cover on the back of the machine by lifting upward on the gray lever in the middle of the back of the machine. Leave this cover open during and after printing. The grinding noise went away.
Posted on May 25, 2009
  • 117 Answers
SOURCE: Is their a Windows7 64 bit driver for the Canon MF4350d
Yes. There driver is avilable on canon website try to download the driver from here”http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=17450
Posted on Oct 30, 2009
Canon mf4350d service manual
hello friend, you can find the canon mf4350d service manual in below link:
Canon i-Sensys mf4350d service manual:
http://goo.gl/JVio9z
thanks
Jun 28, 2012 | Canon ImageCLASS MF4350d Laser All-in-One ...
There seems to be a grinding noice coming from the bottom of the copier. It will feed paper from either source, the tray or the manual feed, and then the copy gets caught and shuts down the copier and you...
Diagnosing noises over the internet is an impossible task unless it is a known problem on a particular model. usually grind noises are casued by something trying to turn something that wont. It maybe something as simple as a siezed drum. As you have not stated what model of copier you have, i am sorry but i cannot proceed any further.
Jul 24, 2011 | Canon Office Equipment & Supplies
Canon mf6530 crumples paper and makes grinding noise when trying to print.
I pressume that paper is wrinkled in fixing section. Probably the fixing bushings are worn out. The grinding noise could be from paper when it stuckes, but also from gears.Call service.
There is a trick if paper is moisturized. Flip paper in cass. up side down, and try again.
Jun 14, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Sounds like there is a papper jam but I can not see papper. Copies are coming out crumpled.
These machines use a fuser film. When they get torn or go bad they make a paper crumpling sound. When this happens it also causes wrinkles and creases in your copies. There may also be areas of your copy where the print will rub off. This means it is time for a new fusing unit. They are not cheap and removal of the old unit and installation of the new unit is not easy so plan on having a service person replace it. Just do a search for Canon D860 fuser or fusing unit.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
I use a Canon ImageCLASS MF4350d Laser All-in-One (2711B001AA) Printer. When i want to photo copy, it shows system error -E225. What does that mean?
I think that error code means a problem with the scanner/lamp. Any type of Exxx code means the machine needs (repair) service. This is a fairly new product and should still be in warranty, so I recommend you contact your regional Canon service agency.
Nov 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon imagerunner 1310 loud noise
Hello sir; I suggest reinstall drum unit again ,you will find out what's going on.
Apr 28, 2009 | Canon ImageRUNNER 1670F Copier
Canon copier PC 420 making grinding noise during copying cycles
only two possibilities
1- fuser
2-gear stripped most likely with the scanning part
Oct 15, 2008 | Canon Office Equipment & Supplies
49 people viewed this question
jasbo
jasbo
