Protron tv pltv 3250 schematic diagrams
Inverter FSP 139-3F01 I need schema
SOURCE: Protron PLTV-3250 fried
A possible solution would be to obtain a schematic for the power supply. If we're technicians, this should work out for most of us.
Keyword on schematics....OBTAIN! John
Posted on Jul 24, 2008
dsacco86
  • 1077 Answers
SOURCE: Protron PLTV 3250 Parts
Ask and you shall receive. Shopjimmy.com seems to have them in stock. And people sell TV parts on Ebay all time. I hope that helps you.
Posted on Feb 01, 2009
  • 6 Answers
SOURCE: No power to my Protron PLTV 3250. What can I do
My Protron PLTV - 3250 just went out yesterday. By this I mean it turned on and went out in a few minutes. I left it off and today it completely died. I opened it up because I always think I can repair things. So what I found is a burn mark on the curcuit board of the power supply which is located inside the tv. On the other side of the burn mark is a (zener diode), this diode is burned out and therefore the power supply is not working. I am going to Radio Shack tomorrow Monday Aug. 31, 2009. The diode is very tiny but should be easy to replace with a sauder gun because this diode has place holders to hold the tiny diode in. If this does not work at the top of this page is a link that says power supplies for your tv for sale. I am going to check it out. Anyway just so you all who know about computers= the tv power supply is similar to the power supply on a computer. Just like a computer power supply comes in a case that you install into your computer and then you just connect the connectors to your motherboard and drives. Well in the tv the power supply is stand alone also, you can disconnect the wire connections in the tv and replace the power supply. If you notice the power cable to your tv is the same as a computer power cable, so the power supply in the tv is much the same as a computer power supply. I hope this helps you.
Posted on Aug 31, 2009
dave1645
  • 834 Answers
SOURCE: I have a protron PLTV 3250 I was watching Tv and the TV went out.
no it is your power supply it may have primary power but if you look closely you will see several puffed up capacitors these blow because of the fet near by let go and is not avail you can get a new supply for about 60 bucks from ramplus.com get the fsp number off the supply ex fsp-194
Posted on Sep 18, 2009
  • 979 Answers
SOURCE: My tv just died no power
Hello Bkobert, hi, before going through the set, kindly check first the following.
1. Check your mains AC line.
2. Check your TV plug cable, they may be loose.
3. Also check if the plug has a user fuse.
If ok, then there is a problem with your TV's switching power supply, a fuse on the board may be open, or loose wiring inside.
The symptoms may go to the extreme, like a faulty switching regulator section, which include the power transistor, IC regulatorm dried up capacitors, and low value resistor.
You may also choose to replace the entire board. thats all. keep me posted
Posted on Mar 02, 2010
Just bought a used Protron PLTV-3250. No owners manual or remote. Could i find them? Do i need them? Thanks a million.....Pam
It is the same as Spectroniq 3250: Manual
http://www.retrevo.com/support/SpectronIQ-PLTV-3250-TVs-manual/id/926dj283/t/2/
Original remote is hard to come by, try EBAY, without orignal remote you may nat be able to access all the on screen setup functions. Watch out for the power supply module to go out on this TV.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Sep 30, 2010 | Protron PLTV3250 32 in. LCD Television
No power I need an ac adaptor for my 32 in protron Lcd TV
you can get ac adaptor for your TV at Shopjimmy.com,Ebay.com
Good luck
Jun 25, 2010 | Protron PLTV-32 Television
Protron pltv 3250 power cord
It is the same power cord as used for your PC, NEMA5-15P to IEC C13.
This TV has known problem with power supply, so keep an eye on it.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Protron PLTV3250 32 in. LCD Television
Dead set
http://www.shopjimmy.com/fsp-fsp194-3f01-power-supply-from-protron-spectroniq.htm
$94
Dec 28, 2009 | Protron PLTV3250 32 in. LCD Television
Sep 18, 2009 | Protron PLTV3250 32 in. LCD Television
Tv has no power - Protron PLTV 3250
Look at the othewr posts for Protron PLTV - 3250. You need a power supply.
Aug 16, 2009 | Protron PLTV3250 32 in. LCD Television
Connecting a Protron PLTV 3250 to a home theater system
Standard RCA cables are fine to connect both units. If home theater and tv has Component Video (Green-Red-Blue) connections, you can get better video result.
Sep 11, 2008 | Protron PLTV-32 Television
remove pwr board--inspect and you will find a heavy current diode which has eatin its solder pad area--if diode checks ok,repair it's connection.Install board and hook back up.Check for shorts in circuit.Cross fingers and plug her up------good luck
Jan 26, 2008 | Protron PLTV3250 32 in. LCD Television
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
