Question about HP Photosmart D7160 InkJet Printer
Memory card error
I am trying to print something and the process on my computer is doing fine but my printer doesn't do anything. I haven't used it for a long time and the last time I did I made a mistake and gave order to print a whole site. Now when I press "View & print" it says "Insert a memory card"
    Scholar:
  • HP Expert
  • 199 Answers
View & print button is used for viewing the content in the memory card if it is inserted in your printer. If you are giving job from computer and it is not getting printed try the following steps.
1. check the cable between computer and printer.
2. check the printer queue ( see a printer icon on the right bottom of the screen near time). if it is there double click and check whether any document is pending in the queue. if so cancel all pending job and restart the computer and try printing again.
Posted on Oct 16, 2013
rakeshpramod
  • 234 Answers
SOURCE: photo card inserted backwards error
Try a full NVM reset on the unit and check
Reset Steps are.
Unplug the power cord from the unit when there is still power in the All-In-One and press and hold the # and No 9 Button without releasing the buttons plugg the power cable back, it should come up with a message as reset
If the screen go's blank after you connect power cable, then release the keys and turn the power On, it will come up with a message as Full NVM Reset
Good Luck
Posted on Aug 29, 2008
rakeshpramod
  • 234 Answers
SOURCE: Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Posted on Sep 28, 2008
SOURCE: my HP laserjet P1006 won't print
free driver download
Posted on Apr 01, 2009
nalin_elliot
  • 224 Answers
SOURCE: Problems with HP Photosmart C6280 All-in-one Printer
Populate the destination list You must populate the destination list in HP Solution Center for the Scan To function to work. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center . HP Solution Center opens.
  2. Click Scan Settings .
  3. Click Scan to... Setup .
    NOTE: It might take several minutes for the list to populate. If the appropriate programs are already listed as scan destinations, discontinue this procedure. You must reinstall the software.
  4. Click each program to include on the Scan To Destination list. Figure 2: Add destinations c01404190.gif
  5. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  6. Click OK .
Posted on Jun 24, 2009
SOURCE: i have a hp psc 2355 printer everytime i insert
I had the same problem with my HP L7590 All In One. After trying a number of things to reset nothing worked. Then I tried this just as a last resort and it worked.
Insert the/a memory card( it will tell you that you can only use one card at a time).
With the card still in turn off the printer using the power button.
Wait for 30 seconds then turn power on again.
The screen should say reading card. So wait for it to finish reading and all should be fixed.
If this does not work, try again using a different card.
good luck
Send me Kudos if it works.
Posted on May 03, 2011
I received an Error Code 0x97 on my Epson 7620, how do I fix this?
These codes can be indicative of a faulty sensor or damaged part.
But let's try this:
I have had similar issues with my MACs and HP printers, however I have often fixed the problem by re-installing the printer software and/or deleted the printer from the printer list in system preferences.
If you have the Epson disc fine...if not, the OS should be able to "find" it for you via the internet. try re-installing the printer software.
BUT you say that the scanner works via the computer.
Have you tried shutting off the Epson and unplugging it from the A/C outlet and unplugging all cables? Leave the cables out for at least 30 seconds and try again. This is the procedure for a forced re-boot of many printers. Hopefully, this will help.
Jul 03, 2015 | Epson WorkForce WF-7620 Wireless Color...
I pressed format on my vivitar Digital Video Camera 410v3 and now all my videos and pics are gone. They are of a house that will be destroyed TOMOROW. HELP!
If they're on a memory card then you MAY be able to recover some of them. That's assuming you haven't done anything to the card since you formatted it.
If your computer doesn't have a card reader, get one. Get a card recovery program appropriate for your computer and operating system (do a Google search for "unformat SD card"). Follow the instructions for your chosen program.
Mar 20, 2012 | Vivitar ViviCam 5018 Digital Camera
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
try processing the file in the PC instead
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
My Printer has an Error Message saying "card slot not Initialized
Try this.
1. Turn the printer on.
2. When the memory count start Press and Hold the "Menu" button.
3. Release the "Menu" button when all 3 LEDs are illuminated.
4. Press the 'back' button.
5. The display will then show "Initialize disks".
6. Press the green "Check" button to start the process. This will take some time.
7. The printer will automatically come back to "Ready" after this procedure.
If the above doesn't work, you may have a bad memory card.
Jan 22, 2009 | HP LaserJet 4650 Color Printer Manual...
Error 30
I have the MFC 465CN - I was receiving two error codes:
Unable To Clean - Error 30
Unable to initialize
To fix, I first cleared the memory by unplugging the printer, then holding down the red stop/exit button, keep it held, power up the printer, and dont let up the button until it finishes the start up.
I then pressed the "ink" button and performed a cleaning, alignment, and quality check. After this, everything worked fine.
DO NOT try to print anything from your computer or have any pending print jobs while doing this - it appears that pending print jobs, or anything in the printers memory was interferring with the initilization and cleaning cycle it performs.
Hope this helps...
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Aug 21, 2008 | HP Photosmart C6280 Printer
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
Printer is out of memory is ther solution to this
Hi 92366, If your printer all of a sudden started giving you ?out of memory? errors while printing things you could print before, then you might have a problem. First thing to do is print out a copy of your printers configuration and verify how much memory the printer thinks it has. If it?s different from what you physically installed you may have issues with you memory. If you are trying to print large graphics they you simply may just need to increase you printers memory. If you?ve got plenty of memory, you haven?t changed or done anything to cause this error and you?ve been able to print this material before without errors here are some things to try: The 5P doesn?t have a display screen I?m assuming you?re getting this error in Windows. What is the status of the LEDs on the printer when you get this error? If you or anyone else with a similar problem is so inclined here is HPs LED code sheet: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl04302 Try deleting your existing printer queue, downloading a new copy of the appropriate driver and reinstall. Here is the link to the HP site, simply select your operating system, select and download the appropriate driver. I personally am more partial to the pcl 5e driver and avoid everything else, in particular the PostScript drivers. Here is the HP link for their LaserJet 5p drivers: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=15011&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25481&debug=Keynote If none of this works let us know what happened that seems pertinent. Good luck and please don?t forget to rate the posting.
Jan 12, 2007 | HP LaserJet 5p Printer
Camera does not recognise 1Gig SD Memory Card
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Dec 03, 2006 | Rollei Prego DP5300 Digital Camera
    HP Photosmart D7160 InkJet Printer Logo
    75 people viewed this question
    Seeker5211
    Seeker5211
