I have a Hugin Sweda Model 1575 with a dim display. I disconnected the ribbon cable and it seems to be disinegrating. Is this part available? What is the cost? Please reply.
Hi, I have the same cash register, would you happen to have the instructions manual? I would love if you would send me a copy of it
Posted on Apr 10, 2015
Fan is running, oven seems to still be heating, but no lights on display
If other electrical components are working, then you probably have a bad display module, or possibly even just a ribbon cable between the display and the main circuit board that got pinched and is no longer transmitting power or data to the display.
If you can remove the ribbon cable you can use an ohm meter to determine whether there is a broken wire by touching the two ends of each wire with the leads from your ohm meter. If the ribbon cable is working properly, then it's time to replace the display.
Indicating the make/model of the appliance would help others to identify replacement parts as well as provide instructions on how to remove panels to access those parts.
Mar 04, 2015 | Ovens
After changing the converter on satellite M305D-S4830 the backlight still very dim
i'm sure you ment inverter..if its working on external screen? it would seem. that you still need it replaced have u checked the ribbon cables?
Nov 23, 2013 | Toshiba Satellite M305D-S4830 Notebook
Hugin sweda 1800
aLOT OF OLD MICRO WAVES ARE LEFT IN TO CIVIC AMENITY SITES / RECYCLING CENTRES YOU SHOULD GET A PLATE THERE
Aug 08, 2013 | Microwave Ovens
My whirlpool dryer model- ygew 9250 pwo will not power up when I control on button. If I push the power on button and the pause button at the same time some times it will start and run and sometimes I may...
When this problem occurs are the small lights on very dim? If so I would turn off the power and remove the top off the dryer. Then re-seat the 4 ribbon cables on the display board. Alot of people replace the front panel or control boards when the problem really is the ribbon cables. If the LED's are not lit dim then you may need to replace one of the two boards.
Jul 24, 2009 | Whirlpool GEW9250 Electric Dryer
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
Dim numbers but oven seems to be working ok
A replacement clock unit is available but costs $150-200 and is rather simple to replace - I've replaced mine twice in the past 5 or so years.The original and replacement both began to dim at 3-4 years and eventually became so dim they were unreadable.
Someone here, I believe, suggested that one or more of the capacitors may have became defective due to the high temperatures above the oven. Replacements for the four suspect capacitors were very reasonably priced but it was difficult locating appropriate high-temprature capacitors.
The only trick to removing and replacing the clock unit is the ribbon connector on the clock circuit board. There are very small plastic ears or tabs at the extreme ends of the connector. Press toward the center of the connector and pull away from the board (about 1/8") to release the ribbon cable.
Replacing capacitors C3, 4, & 7 is straight forward EXCEPT the circuit traces are prone to pull from the board (use as little heat as possible, wick as much solder as possibe before trying to dislodge the capacitors, and watch polarity). C1 a BIG challenge since the solder side is under the display assembly. I used a VOM to locate alternate connecting points on the component side of the board and just let the leads support C1.
Total repair time was about 1-2 hours and savings around $150 - AND it now works perfectly.
Nov 19, 2008 | Whirlpool 71001872 CNTRL-ELEC
Blank screen goes in and out
My 2096 was doing the same thing with a blank screen. IF, your scanner is scanning normally and the dim button still dims your display, your problem could be the same as mine was. This worked for me and got my display working like new again. First thing to do is to take the covers both top and bottom off to expose your scanners insides.Next, once you can see the inside of your scanner you will see a ribbon cable connected to the main board and also soldered to the display. Take the ribbon out of its coupling connector and gently clean the contacts on the ribbon with a cuetip with alcohol on it, also clean the solder joints on the display face that connect the ribbon to the display with the cuetip and alcohol. Ii then reassembled everything, ribbon back into its connector and made sure the clamping mechanisim on the ribbon was securely holding the ribbon. I pluged the power supply into it and turned it on before reassemblig the case covers to see if it would work. Bingo, it worked like new again. Hope it works for you ! Jim
Nov 04, 2008 | Radio Shack Pro-2096 Base Scanner
Dark screen- No images- some shadows horizontally
If you get a blank LCD, dimly lightened by a whitish back light, then the LCD display eis either faulty, badly connected, or the ribbon connector to LCD is defective.
The camera must be taken apart, ribbon cable tested, and eventually replaced and adjusted.
If all contacts on ribbon cable return continuity (cable is fine), then LCD is faulty, and must be replaced.
Althought the job is not too difficult, an user without experience may damage the camera in attempting this repair.
My first suggestion is always taking the unit to a camera shop.
Aug 23, 2008 | JVC GR-D90U Camcorder
Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Nov 30, 2007 | Whirlpool GBD307PDS Electric Double Oven
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
