Question about Wolfgang Puck WPTPCM010
Need plastic basket that holds the mesh filter
Few days ago, the brewing light on my Aroma Seaco coffee machine does not turn on anymore. I could still make coffee but I noticed that the water took a longer time than usual to warm up. Yesterday, I had...
Clean the porta filter mesh by sm all pin.if you have pressurise filter basket then you have open it.because pressureise filter basket contain 2nos mesh .one mesh is multihole and another is single hole .you have clean both.
Jan 28, 2015 | Aroma Coffee Makers & Espresso Machines
Leak around seal
Srry i dont have an answer , it took me 4 hours to set mine up , It sucked in air so bad , i took it apart like 8 times before the air bubbles stopped , i hope i dont have this issue every time i take it apart
Feb 05, 2014 | Marineland C-360 Aquarium Canister Filter...
Fluval u2 aquarium filter will not restart after tank maintenance
Firstly ensure that the impeller is in the motor house.
If so make sure the well the impeller sits in is clear of debris.
If so try running the motor out of the water and removed from the filter, if the impeller doesn't move try giving it a nudge with a pencil.
If none of this works the sealed motor may be broken and will need to be taken to the supplier for repair or replacement.
Oct 20, 2012 | Fluval U2 Underwater Aquarium Filter...
I need to buy filters for the spout. Where in the San Jose area are they available?? Melitta MEK 17W electric kettle.
If you can no longer find this scale filter online or from the manufacturer, then you can still repair your original one and make it better than new! This fix has worked perfectly on my MEK17W kettle and it turns off properly when the water boils.
Buy a piece of 3"x3" 100 mesh (150 micron, must be stainless) on Ebay - under $3 inc shipping. Carefully cut the old plastic mesh out of the original filter frame with an exacto blade and very lightly sandpaper the triangular face of the plastic frame that faces into the kettle. Then temporarily hold the stainless mesh to this inside face of the filter frame with a couple of clothes pegs and use a pencil to mark the
triangular outline of the mesh so that it will fit flush against the plastic and also be no wider than the frame. Carefully cut the triangle of mesh to size with scissors. Thoroughly mix up a small portion of 5-minute 2-part epoxy glue (Loctite or JBWeld) with a thin wooden coffee stir stick and apply just a smear of glue to the frame. As soon as the glue starts to get tacky, gently fit the mesh to the frame and clip it there lightly with 5 plastic clothes pegs, 2 on each side and 1 at the bottom. To ensure their release, you can first wipe the pegs (where they pinch together) with the faintest skim of Vaseline or sewing oil. Let the assembly set for 24 hours and then carefully ease off the pegs. You will now have a filter that will last longer than the kettle.
Oct 09, 2011 | Salton Melitta MEK17W Electric Kettle
HOw do i clean it?
flip down the lever to pull it all apart.
rinse out the lid, food pusher and base(that the mesh filter sits in).
scrub out the mesh filter with a dish brush or the included brush if you have it. be carefull the grater-like parts at the base are very sharp. make sure it's clean by holding it up to the light. if there are any particles left clinging to the mesh it will seriously interfere with the effectiveness of your juicing.
you can line the pulp collecting jug with a plastic bag so that you dont have to clean that out as well.
it's best to clean everything immediately. if for some reason you can't, at least rinse the plastic parts and leave the mesh basket to soak until you can get back to it.
if you have any dried food or staining on any of the parts then a soak in water with lemon juice in it (maybe the juice of 3 or 4 lemons) should help soften up particles and strip away stains.
hope this helps....
Jan 09, 2010 | Breville JE900 Juicer
Does this coffee urn require a paper filter, or is the basket tight enough to hold the grounds
No the steel mesh is your filter. The coffee should be groase enouph so it will pass thoigh the mesh
Dec 12, 2009 | West Bend 58030 Coffee Maker
HOw do I get the metal filter off, I can't remember and I cannot find my book
The crescent tool has two protruding metal “nubs”. After you open the juicer so you can see the mesh basket that turns around, and a flat grating disc that has two holes that match those nubs. Insert the nubs into the holes and turn counter-clockwise to loosen the disc. (you’ll have to hold the plastic edge of the mesh basket so it doesn’t turn). Once it’s loose, keep turning it until it comes off. You can then remove the disc, the basket and part containing the spout to clean them. Just reverse the process to remount the parts, making sure not to overtighten the disc.
Oct 26, 2009 | Jack Lalanne Power Juicer 250 Watts
Making Coffee
Ok lift the lid and inside you will see a brew basket (it will have a hole in the bottem middle of it) If this unit has a mesh type filter basket you will not need paper filters! you put the coffee in the mesh basket the replace before brewing! if you do not have a mesh basket you will need a paper filter to put down in the coffee holder!(the one with the hole in the bottom!) add coffee and waeter and brew!
I hope this fixes ya up!
Please rate my response!
THANK YOU!
Jan 16, 2009 | Kenmore DCC-KE12 Coffee Maker
Strainer and a Filter differences
Actually there isn’t any since a strainer is, in reality, a coarse filter. The question is then one of semantics. Generally it is assumed that if the particle to be removed is not visible to the naked eye, the unit is filtering, and if the particle is visible, the unit is straining. The average human eye can detect a specific particle between 50 and 70 micros. Most people cannot see anything smaller than 325 mesh, or 44 microns. Since 200 mesh is equivalent to 74 microns, a general rule would be that if the screening device is coarser than 200 mesh, it is a strainer and if it is finer than 200 mesh it is a filter. One of the best uses for a strainer is in conjunction with a filter. By installing a strainer directly ahead of a filter, the large heavy pieces which would quickly clog the filter are removed. The filter is then free to do its major job of fine particle removal and does not have to be cleaned so often.
Aug 27, 2008 | Brasstech Jr. Basket Strainer with washer...
Cleaning a Mesh Filter on my Juicer
The stiff brush that came with mine has worked well for me. Have you tried a fingernail brush or maybe some canned air?
Nov 19, 2007 | Juicers
Wolfgang Puck WPTPCM010 Logo
Top Wolfgang Puck Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wolfgang Puck Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
