Question about Imperial Kitchen Appliances - Others
Cleaning flame sensor - Imperial Kitchen Appliances - Others
    Sergeant:
  • 216 Answers
Thanks for your question. Because you have posted this in the Deep Fryer Section I would like to ask if this is indeed a commercial quality fryer.
The answer to this question would be best answered with the make and model # of the unit.
However, Generally speaking unless the glass over the flame sensor is completely covered in grease, or has become obstructed by food the flame sensor is not a serviceable part as far as cleaning. If it's not obstructed or covered in grease than chances are that it is not functioning any longer.
If this is a 2 wire sensor you can use an ohm meter to test it. By turning off the power to the fryer, using a lockout take on the Electrical panel, and unplug the unit is recommended. Then remove the wires from the sensor. Using alligator clamps attach the ohm meter leads to the sensor, Color doesn't matter. One lead per connection. Make sure that any grease or flammable materials have been cleaned from the area prior to testing the sensor. Because you are going to using an open flame I also suggest a fire extinguisher be present ( Just in cause of a accident) Than using a propane mini torch or a bic lighter present the flame from the torch in front of the sensor and watch the ohm meter should have a 0.00 reading. U can also set the ohm meter to tone so that you can hear it instead of having to watch it.
If you get a tone or a 0 reading that will indicate the sensor is working. If the sensor is working than the next issue would be the ignitor or the gas valve circuit itself.
If you have further questions please feel free to contact me.
Posted on Oct 16, 2013
Gibson furnace blinking 4 times then pauses, flame won't stay on
The four flashes is failure of ignition. It could be the flame sensor dirty. The furnace tries to light four times before you get the four flashes. The board then locks out for one hour unless the power is removed and restored. You could try gently cleaning the flame sensor with fine steel wool. If you don't have fine wool you can use a crisp dollar bill.
with the burner firing the yellow flame sense indicator should be pretty much locked on or flicker briefly. If it just occasionally flashes on then the flame sensor rod needs to be cleaned.
hope this helps you.
Feb 04, 2018 | Gibson Heating & Cooling
My rheem conquest 80 furnace comes on and 5 seconds later the gas goes off, it just keeps trying to come on.
This typically sounds like a flame sensor issue. Now, just so we are on the same page, the flame sensor( flame rod), its the rod that is opposite of the ignitor. Now that we have confirmed that, try cleaning the rod with some fine sand paper, nothing too gritty. the goal here is to try to clean any carbon buildup on the sensor that has created all these years of being directly in front of the flame. carefully. So give it a good cleaning to make it look new again but care not to clean too hard so you don't break it. Its best to take the flame rod out and do it and re-install it. If that does't work, try replacing the flame rod. The controller isn't getting any signal back from the flame sensor signifying flame is present. Try this first. Always turn power off when working on electrical equipment.
Dec 03, 2017 | Heating & Cooling
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
Flame lights, then goes right out, and heateer blows cold air.
Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 07, 2011 | Heating & Cooling
Thermostat calls for heat, purge motor turns on, 15 seconds later hot igniter turns on, then gas turns on and burners are lit. Problem is, they only stay lit for 5 seconds then shut off and cycle repeats...
,Hello, Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. After cleaning reinstall it and turn power back on to furnace.
Mar 02, 2011 | Goodman Heating & Cooling
I have a Bryant furnace that is firing up then shutting right off.. The led is blinking green twice then yellow 4 times? What does this mean?
Feb 19, 2011 | Heating & Cooling
Hello i have a rudd furnace everything kicks on but the flames go out right away and a clicking niose comes on
Feb 09, 2011 | Heating & Cooling
I have a york furnace trhat when it initially ignites the flame comes on for a few seconds then shuts down. I can manually shut it off completely then restart it and most times it will come back on. I cant...
Make sure the flame sensor is clean near the burners, The flame sensor is a metal rod that is on the opposite side of the ignitor. To clean the flame sensor you will need some steel wool, turn off power to the furnace and remove the flame sensor and clean it with the steel wool. I will post a pic of a flame sensor.robhvac47_6.jpg
Jan 07, 2011 | Heating & Cooling
Furnace will run for couple of hours or day or two, then wont. honestly believe its the flame sensor, been watching it through panel..coil lights up, flame comes on, hence furnace runs..when it goes out,...
you will most likely break your flame sensor if you attempt cleaning it with sandpaper.
Make sure the sensor is cool and remove it. Clean the sensor with a dollar bill and clean the ground with sandpaper.
If it still fails, replace the sensor
Jan 17, 2010 | Goodman GMS90703BXA Heater
Goodman heating element does not light
The flame sensor is not sensing flame. Inspect the system as it is tying to start and see if the flames are traveling to all burners and hitting the sensor. If not, clean the burner flame rail (the trough the allows the flame to travel from one burner to the next) or if it is hitting the sensor, clean the sensor with steel wool and check all connections from the sensor to the control board.
Jan 20, 2008 | Goodman GMS90703BXA Heater
Kitchen Appliances - Others Logo
46 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Joseph Hoffmann
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
