Question about Konica Minolta PS7000 Book Scanner
PS 7000 Konica Minolta is giving the following error: lamp failure
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
SOURCE: Konica Minolta Error Code: C14A3
Go to a Konica Minolta dealer and ask for assy, the part number is 4980 1001 01 and it is called CCD MODULE. I cannot find only the lamp, you'll have to replace the full assy in which the lamp is included.
Posted on Aug 25, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Konica minolta error C-9401 Help wiht picture
Exposure lamp failure. The light under the glass. Call a tech
Nov 10, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c 7000 error code c 2221 how to fix?
Any one of the following might cause that code,
AC drive board (ACDB)
• Printer control board
(PRCB)
• 1st transfer pressure
release motor (M19)
• 1st transfer HP sensor
(PS15
May 06, 2017 | Konica Minolta Office Equipment & Supplies
Bizhub 654e error code c9401
Exposure Lamp failure.
check if coming to home position to read white reference plate.
check the lamp/Tube for proper connection.
Nov 30, 2016 | Konica Minolta bizhub Office Equipment &...
Konica 3240 error code f35-1
Fusing failure check continuity of heater lamp and thermal fuse replace if busted if ok, go to tech. rep mode and reset the error.
Oct 22, 2014 | Konica Minolta 3240 Black Toner Cartridge...
How to reset error c3101 konica c352
C 3101 Fusing roller separation failure.Check the fusing retraction motor and clean the fusing roller retraction sensor PS 38
Jul 24, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c200 erroe codes c255c
Black Imaging Unit Failure.
remove-shake-and reinstall black IU
Replace IU-K, if not then PRCB faulty.
Feb 03, 2014 | Konica Minolta bizhub Office Equipment &...
C1508
Dear Madam/Sir
Our library at the Tel Aviv University is using the Minolta PS 7000 open book scanner for many years suddently a month ago the Scanner stopped working both lams are out of order -
We tried to change one of the lamps but didn't help
The message that appears on the screen is as follows:
Service call C1508
Call Tech Rep
We are helpless especially the there is no representative in Israel that can help
This scanner is cruciall to our work and we would appreciate your urgent help
Thank you very much for your prompt response and help
Sincerely yours
Mrs Merav Telraz M.L.S
Coordinator of the Medical Libraries Consortium
Head of InterLending and Document Supply Center
Tel Aviv University
Gitter-Smolarz Library of Life Sciences and Medicine
P.O.B.39345 Ramat Aviv Tel Aviv Israel 69978
E-mail: meravt@tauex.tau.ac.il
Phone: 972-3-6428086, Fax:972-3-6407592, Cellular:972-0522805163
Library's Home page address: http://medlib.tau.ac.il
IP address for receiving articles by Ariel: 132.66.226.98
DOCLINE:LIBID-ILXHSU
Mar 28, 2013 | Konica Minolta PS7000 Book Scanner
Our machine shows C9401 default, can you help us in solving this problem
Not exactly sure if the model is the same but on a C351 the C9401 & C9402 errors are as follows:
16.6.81 C9401 Exposure lamp failure to turn on
16.6.82 C9402 Exposure lamp turning on at abnormal timing
Parts to check:
Scanner Assembly
Flat Cable
Image Processing Board (PWB-C)
Step Action
Corrective steps in order of suggestion:
Check flat cable for proper connection and correct or change as necessary.
Change Scanner Assembly if necessary
Change PWB
Apr 29, 2010 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
Konica Minolta PS7000 Book Scanner Logo
50 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
