Cannot uninstall Belkin. The uninstall file could not be found
    New Friend:
  • 7 Answers
This thing happens when you delete the folder in which your files for the program are stored.
or in case you delete the uninstall.exe file.
the program has already been removed from your hard disk, what remains is just the entry in windows registry.
when you uninstall a program, the registry entry is also deleted, so its recommended to always uninstall the program rather simply deleting the program folder.
Nevermind, in your case you can delete the program folder in case you still have it, and the windows entry can be fixed by any registry fixing software like 'Advance System Optimizer'
Posted on Oct 10, 2013
Testimonial: "Thanks. I thought I will have to do that. What is strange is that I did not delete the folder or uninstall.exe file therefor the reason for my question. I loaded Belkin on another PC and now checked if the uninstall.exe file is there. It is not. Only uninstall.ico. I used the Belkin Wireless G USB Network Adapter CD.One I loaded on Windows 7 and the other on Windows XP Proffesional."
Using belkin f5d7051 and getting wlancfgg.exe error message
There are problems with the Belkin site. It may even be that someone has sabotaged it. I had problems using the Belkin drivers and discovered that two of the files (I needed version 2 files for my Wireless Adapter) were actually version 1 files and I found the correct files (all the same names, but different sizes) on the Drivers Guide site (do not download their download helper file - it messes up your computer and takes a lot of work to get rid of it). Also, searching for the drivers is made more difficult because one of them is actually misspelled on the Belkin site. Sorry I did not keep notes about which one I found.
May 01, 2014 | Belkin (F5D7050) 802.11a/g/b Wireless...
Safari won't access web page with my iPad air
There are problems with the Belkin site. It may even be that someone has sabotaged it. I had problems using the Belkin drivers and discovered that two of the files (I needed version 2 files for my F5D7050 Wireless Adapter) were actually version 1 files and I found the correct files (all the same names, but different sizes) on the Drivers Guide site (do not download their download helper file - it messes up your computer and takes a lot of work to get rid of it). Also, searching for the drivers is made more difficult because one of them is actually misspelled on the Belkin site. Sorry I did not keep notes about which one I found was wrong.
Mar 13, 2014 | Belkin (F5D7050) 802.11a/g/b Wireless...
Can't uninstall belkin wireless g mimo witreless adapter software. I've stried uninstall in the program, delete from add remove programs amd search to find and delete files. Nothing works.
was you try to uninstall from device manager?
go to device manager, then right click at mimo wireless network and chose uninstall, wait until process finish
usually after uninstall computer need to restart
i hope this helpful
thank you for using fixya
Feb 19, 2011 | Computers & Internet
Installing the driver
Check your device manager for your adapter-if the device status says your driver needs to be re-install. Re-install the driver manually-you might need to locate the proper file for your adapter's driver-most commonly a .inf file. Try browsing it in the cd itself under driver folders.
Jul 16, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
BELKIN G WIRELESS PROBLEM
yea this doesnt work i tried it on my destop you have to uninstall belkin program then install it back then run the usb and dont do the setup wizard pain in the @$$ and it will say new hardware found click it and then use the belkin wireless program put in the ssid, how manny ghz its runnin and the wep if there is any
Jun 20, 2008 | Belkin (F5D7230-4) Router (587009)
Setup assistant not copleting
Belkin programs sometimes have problems setting up. Use add/remove (control panel) and uninstall all the belkin programs. Goto the control panel - system - device hardware and uninstall the belkin device. Keep the hardware hooked-up. Reboot and us the belkin cd only to install the driver. Test the device and let windows control it.
May 25, 2008 | Belkin Computers & Internet
BELKIN MISCONFIGURED?
Uninstall the old installation of the driver and the restart the pc. disconnect the belkin and install the software of the belkin.After installation insert the belkin device and let the system detect it. if this act thesame then maybe you update the driver of your belkin here you can download: http://www.belkin.com/support/
Jan 24, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin wireless adapter
have you got the dongle on the stand thing it comes with ?
if you try it without the stand and see if it works
if it works the stand is goosed and if the dongle
is still intermitant i would return it as faulty
the usb if its goosed then it will keep poping up when the connection is made on a broken wire
hope this helps
Nov 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Sep 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
