Question about Gateway MX6447 Notebook
Free disk space
In disk cleanup, there are "per user quered windows error report" which has sucked up to 54.7 MB. Can I safely delete this? What is this? Infact I don't well understand all those terms related to PC.
UNIBLUE SPEED UP MYPC 2013 LICENSE KEY
IT'S A SCAM, DELETE IT. SEE: http://answers.microsoft.com/en-us/windows/forum/windows_vista-security/uniblue-scam-and-very-harmful-virusesmalware/ecf044e8-9c5e-e011-8dfc-68b599b31bf5 Use Freeware MALWAREBYTES to remove, if necessary. Download at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL Scan, Delete ALL results, reboot machine. If you must , Boot to Safe-Mode with Networking and download, install, run.
Feb 08, 2013 | Dell Inspiron Mini 1012 Netbook...
Tip
How to perform a Disk Cleanup.
Disk cleanup
The Disk Cleanup tool helps you free up disk space by searching your disk for unwanted files and temporary files that you can safely delete without problems. It can remove all of the following:
Files in the Recycle Bin.
Temporary Internet files.
Temporary Windows files located in the Temporary files folder.
Optional Windows components that you are not using.
Installed programs that you no longer use or wish to use.
To launch the Disk Cleanup tool via Start menu go to Start > All Programs > Accessories > System Tools
A dialogue window should now appear enabling you to select the drive you want to clean up. Select the required drive and click OK.
The specified drive will be examined and the amount of space you can potentially free up is calculated and displayed.
The results, showing the amount of space that can be recovered by deleting files a secific type of file that is not needed is then displayed on the Disk Cleanup tab as shown below.
Select the files and click Ok to remove these un-needed files.
Now that a Disk Cleanup has been performed your hard drive should perform slightly faster and have less clutter lying around.
I suggest you perform the disk cleanup tool every once in a while to ensure that your hard drive has a greater lifespan, never has any need to crash or come up with errors caused by unnecessary files, greater performance and increased productivity especially where it is needed most, in the workplace.
on Mar 06, 2011 | Computers & Internet
Tip
Maintain Your Hard Drive.
Your hard disk drive is one of the most important parts of your PC. It's where all your system files, applications and user data is kept. Most people understand the issue of security, the importance of making regular backups of your user data as an insurance policy against hard drive crashes. Few people realise and appreciate the importance of having regular hard disk maintenance which is designed to keep it in good working order.
The ultimate way to revitalise and cleanse your PC is to wipe the hard drive, start from scratch and then reinstall the operating system. However, there is much you can do to avoid such a situation arising, simply by using utilities provided within the bundle of your Windows operating system.
Disk cleanup
The Disk Cleanup tool helps you free up space by searching your disk for unwanted files that you can safely delete. It can remove all of the following:
Installed programs that you no longer use.
To launch Disk Cleanup via Start menu go to Start > All Programs > Accessories > System Tools
The specified drive will be exampined and the amount of space you can potentially free up is calculated.
The results, showing the amount of space that can be recovered by deleting files that are not needed are then displayed on the Disk Cleanup tab.
Error Checking
Chkdsk.exe is a utility which verifies the logical integrity of a file system. In the event of the utility encountering logical inconsistencies in file system data, it will perform the necessary actions to repair the file system data. The same utility in earlier versions of Windows was called to as ScanDisk.
To Launch Chkdsk go to My Computer and right-click the hard disk you want to have checked. Then click Properties and select the Tools tab.
Click on Check Now.
A dialogue box showing the Check disk options is displayed.
Select the appropriate options and click Start.
You may get the following message.
If so click Yes and your computer will reboot and then perform the scan.
Disk Defragmentation
Since files are constantly being written, deleted and over written to the hard drive, files are likely to become fragmented and scattered all over the drive. The disk defragment tool takes these files and puts them in order by eliminating spaces between files.
To start the disk defragment tool go to Start > Programs > Accessories > System Tools > Disk Defragmenter
Then select the Tools tab and click Defragment Now.
It should now display the hard drives showing total capacity as well as the free space of the drive(s).
Now select the drive you want to defragment and click Analyse.
The drive is scanned and a visual representation of how it is currently fragmented is displayed.
Depending on the the results of the analysis, you will be advised as to whether or not the volume should be defragmented.
Even if it's not necessary, you can choose to Defragment anyway if you like.
The time it takes to defragment the hard drive is dependent on the size of the drive, how the fragmentation lies and how much free space it has.
As the drive defrags you can see how it is neatly repacking the files by looking at the bottem visual bar.
Once it is complete you will get the following message
You can choose to view the report which will show hard drive information such as free space, used space, cluster size and the free space as a percentage. Or you can just lick Close as the defragmentation is now complete.
Doing these checks frequently will prolong the lifespan of your hard drive and make sure it's running at maximum speed.
I have a Toshiba satelite laptop that runs slow and says that it is neary full. I need to free some some space but do not know what to delete. Everything on it seams to relate to microsoft.
You may have installed every softwares on your System Drive (typically C:/, where the OS is installed). Try to install them on other partitions, this will free up some spaces.
You may try with Disk Cleanup utility. To use it go to: Start> All Programs> Accessories> System Tools> Disk CleanUp. This will ask you which of the disk to be cleaned up. Select the desired System Drive Letter and click on OK. You may delete Windows Error reporting files, System error memory dump files from there. You can also delete older restore points by clicking on Clean Up System Files. Select System drive letter as before and click on more options. Under System Restore and shadow copies click clean up. This will remove all but the latest restore point.
Hope this helps, Mrityunjay
Jun 20, 2012 | Toshiba Satelite 2405-S201 Notebook
I have dell inspiron 5160 is very slow n getting problem in more time now problem is laptop wanted boot ,where is problem i dont know but stopped in unwanted time n after
5 ways to speed up your PC
By following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and http://www.microsoft.com/atwork/maintenance/speed.aspx#">XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
1. Free up disk space
The Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
Use Disk Cleanup to:
  • Remove temporary Internet files.
  • Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
  • Empty the Recycle Bin.
  • Remove Windows temporary files such as error reports.
  • Remove optional Windows components that you don't use.
  • Remove installed programs that you no longer use.
  • Remove unused restore points and shadow copies from System Restore.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
Window 7 users
  1. Click Start, click All Programs, click Accessories, click System Tools, then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.
  2. When Disk Cleanup has calculated how much space you can free, in the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.
  3. MORE INFORMATION GO TO THIS LINK: http://www.microsoft.com/atwork/maintenance/speed.aspx
Dec 06, 2010 | Dell Computers & Internet
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove Windows temporary files.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
I regularly use Disk Cleanup, as you should, to help clean some of the 'junk' out of my system and free up space. However, there are a couple things listed here I do not understand and am not sure I should...
1. Queued Windows Error files are files that are stored so that if you contact Microsoft for support it can be read or provided to them for diagnostics. They contain the error codes and information for boot errors or application errors.. THEY ARE OK TO DELETE IF SYSTEM IS RUNNING FINE.
2. Archived Windows Error Reporting are just accumulated reports from the first type of file above. YOU CAN DELETE THEM AS WELL BY CHECKING ALL THE BOXES IN DISK CLEANUP AND SAYING DELETE ALL.
May 13, 2010 | Computers & Internet
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
Computer Speed
ok what do you mean by slow the computer running slow or the internet?
Jul 14, 2008 | Computers & Internet
Gateway MX6447 Notebook Logo
69 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
