Question about Dell Computers & Internet
"drive 1 wdc wd10eads 00m2B0 fail return" Add more to question pc powers up goes into widows 7 then the arrow stays on screen , for ever . And I can not boot from cd reports it can not find device ?
  • 26 Answers
Sounds like the Hard Disk is failing. try booting into safe mode by Pressing F8 Before the Windows 7 Splash Screen. The run diagnostics on the C Drive. Open Recovery by clicking the Start button , and then clicking Control Panel. In the search box, type recovery, and then click Recovery.
You can use Recovery to restore the state of your computer's system to a previous point in time, or restore the contents of your hard disk from a backup. You can also reinstall Windows from a recovery image installed on your hard disk.
Posted on May 05, 2014
  • 998 Answers
SOURCE: Computer will not boot.
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 21, 2008
frcs68
  • 1605 Answers
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
Posted on Dec 10, 2008
appman67
  • 33 Answers
SOURCE: c0000218 error code.cannot boot dell 8400 to troubleshoot problem
It sounds like you've had a fatal error - you can reboot the PC back to factory setting - this is called a hard reset - but before you do that - unplug you tower and clean it out (dust & dirt) - once you're done with that - restart you computer and press &hold down the "Ctrl" and "F11" button at the same time - this will let you reset the PC to the original factory configuration.
Posted on May 03, 2009
  • 3940 Answers
SOURCE: Blue screen error with stop code 0 X 000000ed.
Unmountable Boot Volumes almost always indicate a failure of the hard drive. You can try running CHKDSK /R from recovery console or a clean installation of Windows. If those fail, replace the hard drive.
Posted on Oct 02, 2009
  • 1738 Answers
SOURCE: fail on hard drive diagnostices return code 7
Bad hard drive, sorry.
Posted on Nov 16, 2009
Drive 1 wdc wd10eads 00m200 fail return code 7 dell
looks like your drive is failing,go to safe mode on start up back everything up ,it could fail today or next year there is no time scale on the drives,just back up and replace it to be on safe side,make sure u get correct drive or bigger if possible ,then put your stuff back on good look.
Oct 09, 2013 | Dell Computers & Internet
Compaq 615 froze with no display and fan whirring.
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test reports pass then perform installation of OS
else hard drive has gone bad
Apr 16, 2010 | Compaq Computers & Internet
My hard drive is not working, but I think it may be the power source because the green light on the transformer only stays on briefly when I plug it in. How can I be sure if that is the problem?
If you look at the Power supply box there should be a green light. If you unplug the cord and plug it in again it might just blink then stay our.. it is a common problem with these WD Elements. If it is newer, then it is under warranty.
How to check the warranty on a WD drive or product
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=915&p_created=1047361575
Title: What would void the warranty on my drive?
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=916&p_created=1048294698
If not they will sell you another one.
A replacement or extra power supply for your external drive can be purchased from our phone support team by calling 1-800-275-4932. Any technical support representative will be able to sell this part. Please have the serial number or model number of the hard drive ready, as this is needed to determine the correct adaptor type for the hard drive.
I hope this helps,
Randy
FixYa Support Team
Jan 04, 2010 | Western Digital Elements powered by WD 320...
Any place to purchase a power supply for a WD element??
I hope this helps,
Randy
FixYa Support Team
Dec 28, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My computer fails to identify my WD 1tb external hard drive when I plug it in the USB. It also does not show up on Disk Manager. However, it still lights up and I hear it turning. How can I get the...
I fixed that problem with a WDC My Book Home 1TB in Windows 7:
The drive was recognized in computer management and in device manager but no drive letter was allocated while connected with a e-sata cable.
1.in computer management > storage > disk management
2.rightclick drive 1 or wathever the number of the WDC drive (which should be basic at this time)
3.select 'convert to dynamic disk'
4.drive should get a drive letter
5.format (warning: all data get lost, but you can download original software from wdc.com)
Succes!
Olivier
Oct 31, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Hard drive has just gone dead on me- corrupted files...Corrupted disk! Panic!!!
It is a common problem with power supply on these WD Elements drives. If it is newer, then it is under warranty.
I hope this helps,
Randy
FixYa Support Team
Oct 07, 2009 | Western Digital Elements powered by WD 320...
Blue screen error with stop code 0 X 000000ed. Also when test was performed I got a Drive 0: WDC WD1600JS-75MHBO-Fail Return Code 7
Oct 02, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
When turning on, all I get is a balck screen w/ a
Your hard drive may be dead, the partition/boot sector is damaged or the motherboard seiral ata chip is bad. If it is one of the first two you will need to delete the partition, re-create the partition and format the drive. Take the drive out and install it in another computer as a slave and see if the drive is recognized and files are all there. If it works in the other computer try backing up the drive and then re-install it in the problem computer and try to format and re-install the system either using the installation discs that came with the computer. If the system utility to restore the computer is located on the drive you might have an issue. You can try using that utility if you have it and it may or may not work.
Sep 25, 2009 | Dell OptiPlex GX270 PC Desktop
Compaq Presario CQ50-142US Notebook PC. Playing Jewel Quest III on PC. Arrow stopped working. Nothing else would work. Shut PC off by shutting power off. Turned PC on and screen saver appeared with...
no ops system stated,? windows 7? or VISTA\
circa 2008 to 2011 old.
every post with Compaq in it is long. why is that?
answer, it old and sux, tops list. sorry'
its dead. and the onboard recovery fails too.
reasons, all.\
1: its virus infected ,so up dates or startup fixes or refesh fails.
as expected with all virus. (dah)
so why not use the HP.com media fresh install kit
google that, and win or ask HP. they will help, for sure.
only that works every TIME. unless.......
2: bad HDD ( a 10 year old hdd, what is its chances.. up grade to SSD now, sure)
here try the test
get a live boot CD/DVD, windows PE 8 or 10 , or linux live boot anything, (google live CD and learn)
does PC run good now, off CD/dvd drive? booted ?
yes, good, there is hope, see? see you can boot off
DVD or Usb sticks now.(UDISK)
so do the full fresh install of w7? next> if PC is good.?
as seen here
http://support.hp.com/us-en/drivers/selfservice/Compaq-Presario-CQ50-Notebook-PC-series/3739787/model/3813492
here is the recover disk or stick page
http://support.hp.com/us-en/document/bph07143
there is no lack of HP help or documentation.
Mar 26, 2017 | HP Computers & Internet
Computers & Internet Logo
41 people viewed this question
Alun Cox
