Question about Lenovo IdeaPad Y510 Core-2 Duo: Y510 Series IdeaPad - Core-2 Duo T5750 Processor; 3072M Memory; 250G... PC Notebook
Easy capture it is showing a runtime error when i am opening it
When i am trying to open lenovo easy capture it is showing a runtime error .
so please send me a solution for this problem.
How to open easy camera in lenovo G560 using Windows7 Ultimate
Try the following suggestion from pcrayz at the Lenovo Community Forum:
Step 1: Download and install the Lenovo Easy camera driver for your version of windows here:
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=11
Step 2 : Download the Easy Capture SOFTWARE from that same driver site above.
Right click the install file and select Properties then select the Compatability Tab Check the box nex to Run this program in compatability mode for: From the pull down select Windows XP (Service Pack 3) then click Apply and OK and try running the install again.
If that doesn't help with your issue, then please post in the Lenovo Forum. Clickhere for a link to the forum.
Hope this helps.
Aug 17, 2012 | Lenovo Computers & Internet
Camera initialization failed, Lenovo easy capture closed. this message comes when i open lenovo easy capture .
Welcome to Fixya
This means that the software failed to load up. Try to reinstall the easy capture software by going to the lenovo site. You can try also to disable/enable the camera by pressing the Fn key + Esc key.
Thank you for using Fixya!
Feb 20, 2011 | Lenovo 3000 G230 4107 Laptop AC Power...
How can i use my web cam of oy lenovo g460. is there any software required?
Hi mbisht19,
Based on your concern, I suggest trying the following steps:
1. Make sure that the updated driver has been installed on your computer.
--> you can download it here:
--> go to camera section and make sure you download the driver that matches your operating system.
2. After downloading, install the driver then restart your computer.
3. Log back in then try pressing the FN+ESC to activate the camera.
4. Now try to use easy capture to check if the camera is working.
--> easy capture is a preloaded application in your system.
--> if you cant find easy capture, you can download it here:
--> go to software section.
--> again make sure that you download the application that matches your operating system.
5. repeat step 2 and 3 then open the easy capture.
Hope it helps,
Thank you for using FixYa.
Sep 29, 2010 | IBM LENOVO VIDEO ADAPTER-G450 32MB 22P6640...
When i open lenovo easy capture , it doesnot open and appear a message unknown error encountered, why?
This might be a software or a hardware issue.. If the computer gets passed the BIOS screen and then if you have this problem please reinstall the OS.. If its before the BIOS take the RAM out an reinsert it.. If you still face a problem it could be a faulty RAM or motherboard....
Sep 20, 2010 | Lenovo 3000V200 Laptop
Went to use my Lenovo Easy Captture after 4 months of non-use and this message came up ''failed to open camera''. Any insight?
try uninstalling and reinstalling camera driver and easy capture. go to this website www.consumersupport.lenovo.com enter your serial # which is located at the back, on the white sticker. it usually starts at ABU.
Apr 01, 2010 | Lenovo IdeaPad Y530-5243U
Microsoft Visual C + + Runtime Error
I just recently install Window 7 ultimate on my computer and then Acrobat 8 Pro start acting up. Try to open PDF file it will open for a little while then this thing pop up said Microsoft visual C++ Runtime Library and Runtime Error. Then it shut down.
Anyone know how to solve this problems please help.
Karoon Yip
karoon.yip@gmail.com
Jan 31, 2010 | Nova Development Photo Explosion Deluxe...
My lenovo y510 easy capture isnt working..
hi,
please uninstall all the camera using software (messenger,veriface) and then reinstall the easy capture first and also press fn+esc simultaneously to unlock the camera.
Mar 12, 2009 | Lenovo 3000 Y410 Notebook
Lenovo easy capture is not working
Please check out the device manager if not showing any problem with it. Try to run the Laptop in "Safe mode with networking" and then try it.
Let me know if you need further assistance.
Jan 05, 2009 | Lenovo 3000 Y410 Notebook
Web cam of lenovo 3000 y410 changes the desktop theme
did you try tools-options camera options you can adjust the brightness there, as for the desktop theme try tools again, unfortunately I cannot answer that bit since I unistalled the software, but for brightness adjustments I am sure... check tools-camera options-brightness and contrast are adjusted there
Nov 24, 2008 | Lenovo 3000 Y410 Notebook
Lenovo IdeaPad Y510 Core-2 Duo: Y510 Series IdeaPad - Core-2 Duo T5750 Processor; 3072M Memory; 250G...  PC Notebook Logo
151 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
