Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have several devices connected to a HDMI switch (Tivo, Bluray player, PS3, AppleTV) and then connected to the only HDMI connection (input 7) on the rear. Everything seemed fine last night but then when I turned the TV on, the Tivo gave an error about not being able to receive HDMI or something. It was a Tivo error but was showing on the HDMI input. Then the AppleTV would work and display correctly, but when trying to play Netflix videos, there would be an error about not supporting HDCP or something like that (sorry, I didn't take exact notes and not near the TV now). The Bluray player was just black. I didn't even try the PS3. I tried changing the HDMI cable. Removing the HDMI switch from the situation. Doing a power reset and a hard reset on the TV (power resets on everything). But the problem still occurs. It appears there are 6 blinks on turning the TV on, which sounds like a No Horizontal or audio problem (depending on the answer I've seen to other posts). I called a local TV repair place and they think it would need a new board and cost at least $250 to get started. Any thoughts or help? It still shows some video and audio through the HDMI input but is just acting buggy. Seems like it might be a setting but can't say for sure. The HDMI plug on the back of the TV does seem loose. I've tried moving the connection around when I plug it in, doing power resets and still get the problem.
  • Bill Easton
    Bill Easton Oct 10, 2013
    Sorry, there are 5 blinks when turning on, not 6 blinks.
  • Bill Easton
    Doing a bit more testing, I can get the Tivo to show video but no audio. A box appears that says "HDMI conection not permitted. Press SELECT for more information." And audio and sound off the AppleTV if it doesn't have content protection. But if I try something like Netflix I get the error "This content requires HDCP for playback. Either your HDMI cable isn't properly connected, or your HDMI connection doesn't support HDCP. Please reconnect the HDMI cable from your Apple TV to your HDTV and try again." So it seems that there is something going on with the HDCP part of the HDMI connection that isn't working on the TV end. Ugh.
    Problem Solver:
  • 19 Answers
I THINK YOU SHOULD JUST GET A NEW TV .Sorry that is all i have Can you solve my problem?
Posted on Oct 10, 2013
ctf1800
  • 4402 Answers
SOURCE: Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Posted on Jan 14, 2008
welcomejee
  • 10594 Answers
SOURCE: KP-51WS520 wont turn on - standby & timer lights on constantlly
You need to check supply volts on main micro IC702 on main board of Sony KP-51WS520 TV.
If you have experience of big TV repair then I would recommend to get service manual of TV from any online store and check above said IC supply volts. TV must give error by blinking light in case any problem in drive circuits and if main micro fried, no error signal will be there.
Posted on Dec 05, 2008
  • 108 Answers
SOURCE: ps3 sony grand wega (4 yrs old)
Press the input button on the tv itself to select the proper input you desire.
Posted on Jan 08, 2009
SOURCE: Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Posted on Jan 11, 2009
welcomejee
  • 10594 Answers
SOURCE: No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Posted on Apr 25, 2010
Picture all blurred when playing bluray
Connect the blu-ray player into the HDMI port that currently has sky on it. Does it work then? if so the port you were using has failed. If not the blu ray player has failed.
Dec 28, 2013 | Sony Televison & Video
How do I fix an HDMI input that has stopped working
This sometimes happens on my Samsung tv. With the tv switched on try unplugging the tv from the mains supply and leave for 3 minutes then plug back in and try. I hope this helps.
Nov 16, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Set up Sony Wega TV on Video 2 for a Wii system
In the set up screen: Video reset ports and activated them individually to allow the TV to recognize the game and the DVD players...
Dec 26, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
295 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
