Question about Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc
Yardman chipper vac 24A 203C701 gas leaking through carb
  • 10865 Answers
SOURCE: Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Posted on Apr 23, 2009
  • 1129 Answers
SOURCE: How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
SOURCE: Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
The float may have a hole in it causing it to sink and not seal the needle. Look at the float and check it for holes. You can shake it and listen for gas inside it. if so replace float.
Posted on Sep 07, 2009
mickey813
  • 472 Answers
SOURCE: have a troy bilt that was just given to me - Clean
SONDS LIKE YOU NEED TO CLEAN THE CARD AND IT MAY NEED A KIT IN IT
Posted on Oct 21, 2009
rwvanlue
  • 486 Answers
SOURCE: I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
Posted on Nov 08, 2009
I have a Troy-Bilt 24A-06MM066 CSV060 shredder/chipper combo that won't start
Your carb is gunky up from bad gas most likely.
Anytime an engine will run for a bit after putting gas into the carb, you are pretty well assured that it's the carb.
Remove and clean the carb paying special attention that all the little orifices are open by spraying carb cleaner into them.
Aug 04, 2014 | Troy-Bilt 24A-06MM066 - CSV060 24" 173cc...
Tip
Fix the self-propelled function (MTD, Yardman, Troy-Built, others)
I just purchased a used Yardman 24A-203C701 which, as the title states, has similar variants among other brands.
If you remove either hubcap from the pneumatic drive wheels, you may see the drive pawls with thin pieces of nylon (like a wire ty-wrap) sticking out either side. This is what passes for the engagement spring for the pawls. The fix is to remove each pawl and modify them as follows: Remove the nylon piece. On the rear side of the pawl, under the short end which engages the axle shaft, there is a place where you can drill a 1/8" pilot hole. Expand the size to 5/32" (the drill will want to catch on the pawl's metal, so drill carefully) and tap for 8-32 threads. Buy four 8-32 Allen head bolts which are 5/8" long and four 8/32 hex nuts. Using Loc-Tite on the threads, install one Allen bolt and hex nut into the front side of each pawl. When the threads are flush with the rear side of the pawl, tighten the hex nuts to jam the fastener in place. Purchase four small extension springs which just fit over the Allen bolts and which have just enough tension to pull the pawls into engagement with the axle shaft. The machine will then pull with both wheels but can still be turned and even pulled backwards.
on Nov 24, 2008 | Troy Bilt Walk Behind...
24a-020d700 won't start, new gas & replaced air filter
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
Jan 02, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Having trouble with Mower...what to do?
Clean out the carburetor float bowl and main jet. Sounds like dirt or moisture in it
Sep 12, 2009 | Yard Machines 24a 021h700 4.5 Horsepower...
5hp chipper will start and run only with the choke on and has no power, please, help.
sounds like the carb is gummed up. You probably need to do a complete carb cleaning.
Aug 07, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Jul 10, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Yardman Chipper/Shredder won't run
I had this same problem after letting the machine sit for a couple of years with gas in it. What finally solved it for me was taking the screw out of the bottom of the carburetor bowl and cleaning it. I mean clean it. Carburetor cleaner or some other solvent helps but you've got to get the gunk out of that screw. It probably has an obvious "feed" that runs across the bottom part of the screw shaft. The "feed" that runs from this up to the carb is the tricky part. I needed something very fine and finally settled on a combination of strands of wire from a lamp cord. Try two or three strands twisted together and work it up and down with some carburetor cleaner.
May 06, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
May 01, 2009 | Troy Bilt Walk Behind...
Troy Bilt Walk Behind Chipper/Shredder/Vacuum 205cc Logo
69 people viewed this question
Top Troy Heavy Machinery Experts
Matt Olenzek
Matt Olenzek
donald boissonneault
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
