Question about Sewing Machines
My machine doesnot stich zigzag or Three Points anymore. Model 3500 made in Sweden?
  • Sewing Machines Master
  • 7,365 Answers
Could be a part or the zig zag cam may be worn and needing replaced..
Posted on Oct 11, 2013
SOURCE: Kenmore sewing machine model 15817740
I rooted around and finally found the manual and all the attachments for the buttonholer. Thanks anyway.
Posted on Apr 12, 2008
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
Maggie_B
  • 3 Answers
SOURCE: Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Posted on Oct 31, 2009
  • 1116 Answers
SOURCE: appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Posted on Feb 21, 2010
SOURCE: stitches not catching with zigzag stich only one side catches.
how do you adjust the tension on the bobbin?
Posted on Jul 06, 2010
Bernina virtuosa 153 doesnot maintain stitch lengh selected and throws a zigzag in with a buttonhole stitch.
any machine I ever used sews button holes with zigzag and very short ones at that .
Jan 05, 2017 | Bernina Sewing Machines
Why won,t my memory craft 4000 sew on straight stich setting it will sew a straight stich only on zigzag
sounds like the machine needs a adjustment, it would be a good idea to have the machine checked
Dec 07, 2014 | Janome Sewing Machines
My Bernina 830 sewing machine will not do a zigzag stich
We are assuming that the zigzag width dial is at the widest position but the needle will not move laterally for zigzag... The following logic should be applied for Bernina machines 530, 730, 830, 930 machines with a guided motion zigzag cam.
1. The switching pawl (lever on the top cover that switches from zigzag to cam patterns) may be engaged in the cam or automatic pattern side. Check that first.
For zigzag application, the lever must be engaged in the zigzag side (lever pulled back toward the operator). The stitch width dial is then used to provide your choice of width.
2. It is common, due to oil varnishes, that the switching pawl that is actuated by this lever is stuck between the zigzag and the automatic position, thus preventing the transmission of power to either the zigzag cam or the automatic pattern cams and to the needle.
The best way to detect this is to remove the top cover. You can then switch the lever back and forth to observe if the switching pawl engages firmly into either of the receiving forks. If the switching pawl is sticking, a few drops of certain solvents are applied by a technician on the switching pawl support. The switch lever can be rapidly switched back and forth until you see the switching pawl engage into the receiving forks and you hear a crisp clicking during each engagement. This repair can be permanent or it may create only a temporary fix due to the amount of oil varnishes on the parts.
If the machine is heavily varnished, it suggested that the parts be disassembled and cleaned for flawless performance. If the machine had been sprayed with WD-40, petroleum based solvents like mineral spirits will not break down these varnishes.
A caution regarding solvents...DO NOT USE (WD-40) as your solvent. WD-40 is a marvelous product for its intended application as a water displacement device. It is not to be used for lubricating a sewing machine. Note: "Bernina Technical Information bulletin #1" issued in 1982, forbade the use of such spray lubricants and solvents. SewTechnical Home
Sep 28, 2014 | Bernina Sewing Machines
Not zigzaging stays in straight stich
which model? if a cam machine is the zigzag disc fitted?
Jan 07, 2014 | Singer Sewing Machines
Appearence of loop and no zigzag stich on ls-2125i brother
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
It stay on zigzag
you do not mention what model machine you have.
play with the stich length, this should clear it up.
Aug 28, 2009 | Kenmore Sewing Machines
Sewing machine problems
Having the exact same problem, oiled the machine, but I still can't change stitches...any advice?
Jun 29, 2008 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
