Question about Toshiba Audio Players & Recorders
Toshiba 42cv600e, sound problem, sound not clear
Toshiba 57H84 has sound issues
reset to factory default and setup from scratch, that should clear any mis-set adjustments.
You will have to set up from scratch though.
Also, check all cables are secure
Jul 17, 2015 | Toshiba Televison & Video
Toshiba a665-s6086 with harman/kardon speakers has static sound
That could be a RAM or processing issue.
In the first instance, check the driver for the latest, (toshiba.com) and run a registry cleaner to help speed the system up.
Jan 20, 2014 | Toshiba Satellite L455D-S5976 Notebook
Toshiba rear projection television
this problem is solved from your remote or from your kit,, first u confirm from your remote setting,,
Apr 06, 2010 | Toshiba 42H81 42" Rear Projection...
No clear sound from speakers, even when volume is max out on toshiba model 30hf83 tv
Use a audio signal tracer to pinpoint the distorted sound location,you can use an amplified pair of computer speakers.Or request the complete 9mb 126pages schematic diagram from my personal server at computec40@hotmail.com
Nov 21, 2009 | Toshiba 30HF83 30" TV
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
Sound problem
It is possible that there maybe a speaker fault, ut it is equally possiblt that there is a motherboard fault. It would need to be checked by a qualified engineer.
Jun 21, 2008 | Toshiba Tecra A3 Notebook
Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
117 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
