MOUSE PROBLEM My touchpad mouse on my laptop ( Toshiba Tecra M9 - OS XP SP 3) it moves by itself and sometimes doesn?t respond . First I update the driver whit the new driver from Toshiba website still same problem after I update the bios, still same problem?s, I restore the system from the Recovery disk com with the laptop and install SP3 still same problem . I made some adjustment from control panel and disable The track sticks are found in the centre of laptop keyboards after that the touchpad mouse work fine but now the problem is when i start the computer the mouse is froze for about half hour after that is work properly
    Sergeant:
    Champion:
  • 259 Answers
Run a virus checker through i had the same problem with the moving mouse thought i had a good virus checker but somehow it got through hope this helps regards Jim
Posted on Apr 23, 2009
Toshiba touchpad doesnt respond after 2 minutes
This issue could be a few things. 1. Make sure your driver for the mouse and keyboard are updated. 2. The mouse pad may be going bad. 3. There may be an issue with the motherboard. I would recommend checking your driver first. Then replace the mouse pad. You can also pick up a wireless mouse and plug the usb that comes with it into a usb port if you are not comfortable tearing apart your laptop.
Jan 11, 2014 | Toshiba Computers & Internet
I have a toshiba satellite and after the most recent windows update my external mouse stopped working and says driver malfunction when i plug it in... i have tried everything system restore driver...
Try opening Device Manager in Control Panel and deleting the driver. Reboot, plug the mouse in again and see if that works.
Alternatively try restoring your PC to before your last update.
Dec 30, 2017 | Toshiba Satellite Computers & Internet
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Mouse Pointer moves itself and hide in corner
You might want to try using an external USB mouse.  Or looking for touchpad driver/utility updates to install for your toshiba model such as http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2060181&rpn=PTMB3U&modelFilter=M10-S1001&selCategory=3&selFamily=1073768664&selModel=2060181|PTMB3U
Mar 16, 2009 | Toshiba Tecra M1 PC Laptops
Erratic cursor
It happens with both? Sounds like it may be a driver or motherboard issue.
Check the HDD for errors with Checkdisk (Start -> Run -> cmd -> Ok -> chkdsk /f
Try redownloading the touchpad/mouse drivers from the Toshiba site
Oct 22, 2008 | Toshiba Tecra M1 PC Laptops
Touch Pad Mouse not working unable to trouble shoot or properties for touch pad device to enable help please
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
Oct 10, 2008 | Toshiba Tecra 9000 Notebook
Lapptop touch pad not responsive
hii srm-mom ....
see jst fallow wat i m sayin....
go to start option>control panel>printer n other hardware>mouse
here u can set urs mouse speed n urs mouse pointer....
if u r not able to see ny mouse pointer choose diffrent pointer..
if irs mouse speed is slow u can increase it also...
try dis tell me.....
dis settting for windows xp nly....
if ur usin vista same as it but sm diffrent..
thanks...
Jun 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Computers & Internet Logo
399 people viewed this question
David Payne
David Payne
