Question about Dell Inspiron One 19 (884116044949) 185 in PC Desktop
Inspiron One will not turn on? Power cord does show blue when plugged in but when I push power button it makes like a kill power sound is all. Please help....
  • Dell Master
  • 3,799 Answers
Try with the battery removed.
Posted on Oct 10, 2013
Joed911
  • 4338 Answers
SOURCE: Computer won't turn on unless I unplug the Ethernet Cable
Is the Ethernet built-in on the system board? I would go to BIOS (hit F2 while booting the PC) and disable the ethernet. then restart the PC. See if it stays on with or without the Ethernet cable plugged in. If it does. The built-in Ethernet circuit is the problem. I would buy a Ethernet adapter ($20).and install it. and leave the built-in ethernet disabled.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
  • 31 Answers
SOURCE: amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Posted on Nov 30, 2008
  • 17 Answers
SOURCE: computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Posted on Feb 15, 2009
  • 551 Answers
SOURCE: Dell Dimension 9150, flashing orange light on
kindly check your processor. isolate it by using other processor with the same specs.
Posted on Apr 14, 2010
  • 3940 Answers
SOURCE: dell 540s wont turn on
generally a no post, since the system will not stay on, you simplify the system configuration by removing all external connections except power, then see if the system will stay on. If it does, add items back one at a time till you ID the issue.
If no change with external items disconnected, then issue is internal. remove any expansion cards and try again, if issue resolved, the add one at a time to isolate fault. If still no go, try ram modules individually. if still no go, disconnect power to all drives, see if system will stay running with drives disconnected. if still no go, then it is either the power supply or the motherboard. replace the power supply 1st since it is cheapest to replace
Posted on Jan 01, 2011
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Dell inspiron 518 dsektop will not power on, power button is blue but fans and hard drive are not running?
It could be the Power Supply. I've seen times where there was enough power in them to make the power button light up, but not enough power to make the fans or disk drive run.
You can also check the tips below:
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 01, 2012 | Dell Inspiron 518 Desktop Computer
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Iiyama prolite e1902wsv white screen , no picture
From time to time, I've the same white screen problem with my IIYAMA E1902WSV.
I can resolve that issue with a reset to factory settings.
1- Turn ON power (blue led)
2- Push on the MENU button and keep the button pushed while
pulling out the power cord.
3- Plug the power cord back while keeping the MENU button
pushed.
You should see the picture again.
Oct 18, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
My dell inspiron B120 will not turn on! What
hi there, there are many things that could be wrong here. First, make sure that the battery is plugged in with the power cord. If that doesn't work, it may be that the computer isn't reading that the power button is being pushed. If you know a little bit about computers and how to disassemble them and put them back together, take apart the top of the computer where the power button is, carefully disconnect the wires and look to see that the power button is not damaged. If it is, then you need to bring it to a computer repair shop for them to fix it. If not, then it is something to do with the connection between the power cord and battery not sending power to the system.
Feb 15, 2010 | Dell Inspiron B120 Notebook
The television will not turn on, but the blue light on the front of the tv turns on. We have tried to power the tv by remote control or pushing the power button on the side of the tv, but it does not do...
How many time the blue lights blinks? That is a error code telling the serviceman what it is. A guess in the dark, sounds like the main board.
Aug 10, 2009 | Televison & Video
Dell Inspiron 5150. Will not turn on. While plugged in and pushing the power button the battery light turns orange flickers a few times and then nothing.
its not getting power from your power cord, if you have a friend that has a power cord, try theirs. If there's a light on your power cord it should be lit up but still doesn't determine if you cord is bad.
Jul 25, 2009 | Computers & Internet
No power or lights on my inspiron 2650 laptop
First you need to test your adapter first not the power cord.Check that your adapter can give out according to the adapter spec..maybe 16-19ou V.If it does and still you laptop don't turn on then you have motherboard problem.
takecare.
May 05, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron One 19 (884116044949) 185 in PC Desktop Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
