Question about Toshiba DKT-2010 Corded Phone
How do I retrieve my messages after I have listened to them once and hung up?
  • jo dee aeschliman
    jo dee aeschliman Oct 10, 2013
    Figured it out myself.... called my own extension and left a message.
A red light is flashing in the corner of the handset. How do i shut it off?
If your charge light is flashing and you have no messages on your answering system, you may have voicemail. Voicemail is provided by your telephone company and they would be able to assist you with retrieving those messages.
Once you have listened to the new messages, the blinking light will stop. You may also be hearing a stutter tone before your dial tone when turning on your handset. This is also indicating you have a new voicemail message.
Sep 15, 2015 | Uniden DECT 6.0 Cordless Phone ID
How do I retrieve my messages on the Lucent 18D
Hello.
To listen to your messages
Press Intercom 777
At the prompt enter your extension number (Feature 00 before starting the procedure will tell you your extension number)
At the prompt enter your passworde (1234 is the default)
Listen for the instructions
Cheers
Jul 07, 2009 | Audiovox Corded Phone
Don't know how to retrieve messages. (Extension is main switch)
Is that like when she says you have no new messages, To receive the messages press "1"? Press 1.
Carl
Mar 20, 2009 | Panasonic KX-T7630 Corded Phone
Retrieve caller id once i have hung up
The ones we used to use at my office would not retrieve any call data, and it was that model.
Feb 27, 2009 | NorStar Meridian M7310 Phone
I need to turn off the "hold message" that is stuck on my phone when hung up
While you're listening to the hold message, press "1" on the keypad.
If that doesn't work, try *7510 from the intercom.
Carl
Oct 30, 2008 | Panasonic KX-T7730 Corded Phone
Retrieve messages
To connect with your answering system:
1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
Apr 01, 2008 | AT&T 1818 Corded Phone
How can I retrieve messages I have erased by accident (grandson's messages)?
unplug NOW before someone tapes a messages over the "deleated"one try plugging back to power after machine has had 5min downtime this may 'reset' so you can retrieve if this does not work call manufactor they may know a trick but do not reconnect because if someone tapes over its gone!
Mar 26, 2008 | Lands Phones
RETRIEVE MESSAGES
To retrieve a message from another location, dial the telephone number and when the greeting message starts punch in your four digit code. The default code is 0123 if you haven't set one. Follow the prompts to listen to messages.
Feb 14, 2008 | GE 29869GE2 Digital Answering Machine
How do you retrieve messages from another phone?
If you have not changed the code, it should be set to the default code 1-2-3. Call the phone with the answering machine, and as soon as your greeting starts press 123. You will then hear a menu. Press 1 to retrieve your messages. After listening to your messages, you can listen to the menu again, which will tell you that you can press 0 to delete your messages, among other choices. Cathy
Jul 15, 2007 | GE 29871GE3 Digital Answering Machine
Toshiba DKT-2010 Corded Phone Logo
41 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
