Question about Sony VAIO VPCCW21FX Notebook
Changed lcd screen had 3 columns of random horizontal white lines checked connector on back of screen now backlight don't light. I also cannot get a external monitor to work on it sony vaio vpccw21fx
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 140 Answers
Defective video module on motherboard. Buy new laptop. Not worth buying a replacement motherboard and getting the same problem again.
Posted on Nov 04, 2013
JOHNNY2hotty
  • 41 Answers
SOURCE: lcd monitor has 3 pink
check theses out http://www.bizrate.co.uk/laptopcomputers/sony-vaio-vgn-ar61m-intel-core-2-duo-t7500-2.2-ghz-laptop--pid714583279/compareprices.html
Posted on May 13, 2008
Joed911
  • 4338 Answers
SOURCE: Sony Vaio VGN-NR120E cracked lcd screen.
You won't be able to see video if your LCD screen is cracked.
Connect a monitor to the VGA port , the hold the Fn key and hit F7.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 07, 2009
justin217
  • 85 Answers
SOURCE: white screen. what does it mean?
Your LCD might have gone out, call the sony support number for a service request or take it to your local computer repair shop. Hope this helps!
Posted on Jul 12, 2009
Geekman
  • 32281 Answers
You could have a faulty or loose video cable/connector.
Reseat the video cable/connector that attaches to the motherboard.
Posted on Jul 16, 2009
SOURCE: A blurred horizontal line (about 3 mm thick)
Please check this..
Posted on Aug 05, 2010
Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 30, 2015 | Samsung UN65C8000 TV
Vertical lines on my compaq cq61
Problem is;
1) Bad graphics chipset,
or
2) Bad Video Cable, or loose connections,
or,
3) Bad screen Inverter,
or,
4) Bad LCD screen.
A) Graphics chipset:
(Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The chipset, or I.C. used for graphics; is the graphics chipset.
More properly known as the G.P.U.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU )
Laptop OFF, monitor OFF, connect a VGA monitor; to the VGA connector on the laptop. (Port)
(Left side of laptop, if memory serves)
This is a General example of a VGA connector, (Port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
You have at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
Still no?
Hold the Fn key down again, and tap once more on the F4 key.
Same display on external VGA monitor (Red lines), suggests problem with the graphics chipset.
Good display on external VGA monitor means;
Problem with;
1) Video Cable
2) screen Inverter
3) LCD screen
http://tim.id.au/laptops/hp/hp%20g60%20compaq%20presario%20cq60.pdf
If you find it is one of the three stated above, post back in a Comment; and I'll guide you step by step, in diagnosing.
Will require partial disassembly of laptop, but not very far.
Will also require an ESD wrist strap.
Average cost is around $3 to $6.
Example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Needed to keep from Static shocking, the delicate hardware components inside the laptop.
[All power removed;
Loosen Keyboard, and roll over out of the way. Do NOT disconnect Keyboard Cable.
Remove Keyboard Cover.
Remove Display Bezel.
Remove screws that hold LCD screen to Display Cover, and check Video Cable connections to back of LCD screen.
The plastic frame in front of the LCD screen, is the Display Bezel.
Laptop closed the top cover is the Display Cover.
Just basic instructions. Like I said, I will step by step you through it, if you wish ]
[Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL (or more than one), or a series of LED's.
(Light Emitting Diode)
The Compaq Presario CQ61 series of Notebook PC's, uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
The screen Inverter converts the power (Electricity), from the laptop; for the LCD screen, and Backlight.
Backlighting that uses CCFL, uses a screen Inverter.
Backlighting that uses a series of LED's, May or May Not use a screen Inverter.
It seems when the LED technology first came out, they did.
Later designs do not seem to.
Regards,
joecoolvette
Mar 25, 2013 | Computers & Internet
What is the poblem of a laptop with the screen goes up and down...
1) Video Cable:
The Video Cable connects to the top of the motherboard, in an area under the Keyboard, or Switch Cover.
From there it goes under the left Hinge, and up into the Display Assembly.
Routing under the left Hinge, and normal repeated opening, and closing of the laptop, may cause the Video Cable to become pinched. This can cause loose connections, and/or damage to the Video Cable.
Average example of a Video Cable,
http://www.amazon.com/LotFancy-Notebook-Compatible-50-4AQ08-101-50-4AQ08-001/dp/B005GB9GT4
Click on the view to enlarge it.
The video cable connection may be loose at the motherboard side, and/or at the back of the LCD screen, in the Display Assembly.
Procedure for checking is to Physically, see if the connector/s is tight.
Visual inspection alone will NOT do.
The tiny wires inside the sheath of the Video Cable, may be damaged. Stretched/Broken. Could have an intermittent contact of the broken wires, and this causes a poor video signal.
2) Screen Inverter:
Primer;
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and Backlight.
A laptop that uses LED's for a Backlight, most of the time does not use a screen Inverter.
Primer over.
A failing screen Inverter will show the symptoms you describe, also.
3) LCD Screen:
If the Video Cable proves to be OK, (Continuity check with multimeter, and also have an assistant gently wiggle the cable while you are checking (OHM's), to see if there is an intermittent break), and the laptop's Backlighting is LED's, then the problem is the LCD screen.
What is the laptop manufacturer name, and model number?
Model number is on the bottom of the laptop. Most of the time in a sticker. (And close to the Windows product key holographic sticker)
Post back in a Comment.
Regards,
joecoolvette
Sep 10, 2012 | Computers & Internet
Samsung TV LCD horizontal line up
Have you tried changing the input device to something like a DVD player and see whether you have same problem?
Jul 31, 2012 | Televison & Video
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
White horizontal lines running across laptop screen
I did not see any white lines, Simon, in the screenshot.
Just sayin'.
(Glad you tried to post it though!)
The problem is caused by a faulty Video Cable, or it's in the Display Assembly.
However, you better start the diagnoses with using an external VGA monitor, and see if the lines show up on the external monitor, also.
This would indicate a bad graphics chipset.
For most people that would mean replacing the motherboard.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector, on the Left side of the laptop.
Example of a VGA cable, and VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
You can use a external VGA monitor that is a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
A1) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external monitor.
IF Not,
Press, and hold down on the Fn key, (Bottom left of Keyboard), and at the same time tap on the F5 key. (Top of Keyboard)
{The F5 key is the Display Toggle-Over key }
No?
There are at least 3 display options available.
3) External VGA monitor ONLY.
Hold the Fn key down again, and tap once more on the F5 key.
Graphics look good on external VGA monitor?
Your graphics chipset is good.
Problem is Video Cable, or in the Display Assembly.
B) Video Cable: (LVDS Cable)
http://www.insidemylaptop.com/disassemble-acer-aspire-7551g-laptop/
The above is for an Acer Aspire 7751G, but it is close enough to the 7750G models, and info should directly crossover.
Scroll down to Step 17.
The Video Cable connection to the motherboard, is shown by the yellow arrow at the Top Left.
Note, although the photo is less than, the routing of the Video Cable.
It goes through the Left Hinge.
(Then into the Display Assembly, and connects to the back of the LCD screen)
With normal opening, and closing of the laptop, the Video Cable could be pinched, or have been pinched. Could have been pulled on.
You close the laptop, the cable is slightly pinched in the Hinge, and it pulls loose from the motherboard connection, AND/OR the LCD screen connection.
Doesn't take much of a loose connection. In fact it's hard to discern with the human eye, sometimes.
Make sure this motherboard connection is tight.
You have to open the Display Assembly, and check the Video Cable connection on the back of the LCD screen.
Doesn't look loose? Try to plug it in tighter anyway.
Check the connection of the wire/s from the Video Cable, TO the screen Inverter.
The small circuit board behind the Display Bezel, (LCD Bezel), and mounted to the bottom of the LCD screen.
When on the motherboard side, the side of the Video Cable that runs through the left Hinge, is there any apparent damage? Damage to the sheath of the Video Cable?
If there is, chances are the tiny wires inside the Video Cable, are damaged also.
Check with a multimeter. Perform a continuity test of Each wire.
C) Display Assembly:
Video Cable checks out then the problem is in the Display Assembly.
1) Screen Inverter:
http://www.sparepartswarehouse.com/Acer,Aspire-7700-thru-9800,Laptop,Inverters.aspx
http://www.insidemylaptop.com/replace-broken-screen-acer-aspire-5745g-laptop/
Not your model, granted. Posted for the Display Assembly dis-assembly pictorial guide.
Primer:
A Backlight is a CCFL, or a series of LED lights.
Your laptop uses a series of LED lights for the Backlight.
A CCFL requires a screen Inverter.
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
NOT all LCD screens that use LED lights as a Backlight, use a screen Inverter. I suspect yours does not, as I can't find a listing for a screen Inverter, for it.
http://www.laptopscreen.com/English/section/FAQ/1245191276/Correct%20backlight%20type%20for%20your%20new%20screen/
This would mean that if the Video Cable proves to be good, the next step is to replace the LCD screen.
Shop around for the best price, AND make sure it is a direct replacement for yours.
Regards,
joecoolvette
Feb 12, 2012 | Dell Inspiron Computers & Internet
The screen is white >>>
Your inverter board is OK otherwise you will not get any light on the screen, there is only one inverter board, Check the flat ribbon cable connected to the LCD panel (locate behind the LCD panel), when this connector comes off you will get white screen.
Nov 06, 2009 | Sony VAIO VGN-CR510E/T 14.1" Laptop
Iphone screen white, clicks and turns on and off but cant see!
if is not water damage , apple should repair it. If not well open the iphone go to youtube see vid how to open it. turn off iphone open it just pull off #1 and put back in. that's the lcd connector. This should work if not take #1 then #2 and # 3 put all conector back that should work. #1 Lcd conectot #2 is the Digitizer #IS the ligth. If you got gray lines the lcd may be broken.
Apr 04, 2009 | Apple iPhone 3G
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Sony VAIO VPCCW21FX Notebook Logo
60 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
