Question about aldi.com
550w powercraft electric hoist won't lower. Will raise
Engine swap
. Assembling a vehicle the body is lowered down over the engine so if you have the correct equipment say a hoist where the engine / gear box unit can be lowered as you raise the body then I would take it out the bottom. you place the engine assembly on suitable stands and simply raise the hoist/ body up off the engine.
Jan 22, 2014 | Kia Cars & Trucks
Donde esta el termostato del 300 1999 chrysler
3.2L & 3.5L Engines
  1. Disconnect negative cable
  2. Drain cooling system.
  3. Raise vehicle on hoist.
  4. Disconnect electrical connectors from engine oil and power steering pressure switches.
  5. Disconnect radiator and heater hoses from thermostat housing.
  6. Remove thermostat housing bolts.
  7. Remove housing, thermostat, and gasket.
To install:
  1. Position gasket on thermostat and housing.
  2. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
  3. Install radiator hose.
  4. Install bypass hose.
  5. Connect electrical connectors from engine oil and power steering pressure switches.
  6. Connect negative cable.
  7. Fill cooling system.
  8. Inspect for leaks.
  9. Lower vehicle on hoist.
Jan 23, 2011 | 1999 Chrysler 300M
How to remove and replace radiator on 1998 ford taurus
  1. Disconnect battery ground cable.
  2. Remove the battery.
  3. Remove clip retaining constant control relay module and position module aside.
  4. Remove battery tray.
  5. Remove radiator cap.
  6. Raise vehicle on hoist.
  7. Remove radiator splash shield.
  8. Drain engine cooling system.
  9. Remove radiator mounting bracket assembly.
  10. Remove lower radiator hose.
  11. Partially lower vehicle.
  12. Remove upper radiator hose.
  13. Remove radiator overflow hose.
  14. Remove upper A/C condenser core retaining bolts.
  15. Remove upper A/C transmission oil cooler tube clips.
  16. Remove upper transmission oil cooler tube (7C410) using 3-8 inch fuel line disconnect tool 310-041 (T90T-9550-C).
  17. Raise vehicle on hoist.
  18. Remove lower transmission oil cooler tube clips.
  19. Remove lower transmission oil cooler tube using 3/8 inch fuel line disconnect tool 310-041 (T90T-9550-C).
  20. Remove transmission oil cooler bracket and position transmission oil cooler aside.
  21. Remove lower A/C condenser core bolts and position A/C condenser core (19712) aside.
  22. Remove radiator support bracket.
  23. Remove radiator.
May 07, 2010 | 1998 Ford Taurus
Alternator removal/ford taurus 1996
Generator Removal
  1. Disconnect the battery ground cable.
  2. Remove the accessory drive belt from the generator pulley.
  3. Remove the power steering line bracket and heater hose support bracket from the generator.
  4. Remove the upper generator bolts.
  5. Partially raise the vehicle on a hoist.
  6. Remove the right front wheel.
  7. Remove the lower fender splash shield retainers and position the shield out of the way.
  8. Remove the generator splash shield.
  9. Raise the vehicle.
  10. Disconnect the electrical connector and remove the battery positive cable from the generator.
  11. Position an adjustable stand to the subframe.
  12. Remove the right subframe bolts.
  13. Remove the lower generator bolt.
  14. Lower the subframe to provide clearance.
  15. Remove the generator
Generator — 3.0L (2V) and 3.0L (2V) FF Engines
  1. NOTE: The generator (GEN) (10300) is not internally serviceable.
    Disconnect battery ground cable (14301). Refer to .
  1. Disconnect the electrical connectors from the integral generator/voltage regulator.
  1. Loosen the generator pivot bolt. Remove the mounting brace bolt from the generator.
  1. Disengage the accessory drive belt (8620) from the generator pulley (10344).
  1. Remove generator brace.
  1. Remove the generator pivot bolt and generator/voltage regulator.
Mar 01, 2010 | 1996 Ford Taurus
I can't get the spare tire out of the rack? 2004 yukon
  • Rotate the hoist shaft counterclockwise in order to lower the spare tire to the ground. Continue to rotate the shaft until the spare tire can be pulled out from under the vehicle and removed. If the spare tire does not lower to the ground, the secondary latch is engaged causing the tire not to lower.
  • If the secondary latch is engaged and the cable end is visible, perform the following procedure: 3.1. Tighten the cable by rotating the hoist shaft clockwise until you hear 2 clicks or feel it skip twice. You cannot overtighten the cable. 3.2. Loosen the cable by rotating the hoist shaft counterclockwise 3 or 4 turns. 3.3. If the spare tire can be lowered, repeat steps 1 and 2 to see if the spare tire can be removed. 3.4. If the spare tire cannot be lowered, rotate the hoist shaft counterclockwise until approximately 15 cm (6 in) of cable is exposed. 3.5. Raise and support the vehicle. 3.6. Place a transmission jack, or equivalent, under the spare tire. 3.7. Position the center of the transmission jack under the secondary latch release button at the center of the spare tire. Arrange the arms of the transmission jack so they will support the tire after it has been released. 3.8. Raise the jack until the spare tire stops moving upward and is firmly held in place, releasing the secondary latch. 3.9. Lower the tire. If the spare tire is hanging by the cable, rotate the hoist shaft counterclockwise until the tire is low enough to remove.
  • Feb 28, 2010 | 2009 GMC Yukon XL
    Alternator removal 1998 ford taurus dohc
    3.0L (4V)
    Removal
    1. Remove the accessory drive belt from the generator pulley.
    1. Remove the power steering line bracket and heater hose support bracket from the generator.
    1. Remove the upper generator bolts.
    1. Partially raise the vehicle on a hoist.
    1. Remove the right front wheel.
    1. Remove the lower fender splash shield retainers and position the shield out of the way.
    1. Remove the generator splash shield.
    1. Raise the vehicle.
    1. Disconnect the electrical connector and remove the battery positive cable from the generator.
    1. Remove the right subframe bolts.
    1. Remove the lower generator bolt.
    1. Lower the subframe to provide clearance.
    1. Remove the generator.
    Installation
    1. NOTE: Do not tighten the lower bolt.
      Install the generator and the lower bolt.
    1. Raise the subframe and install the subframe bolts. Tighten the bolts to 90 Nm (66 lb-ft).
    1. Remove the adjustable stand.
    1. Lower the vehicle.
    1. Install the upper generator bolts and tighten them to 25 Nm (18 lb-ft).
    1. Install the power steering line bracket and the heater hose support bracket. Tighten the nut to 20 Nm (15 lb-ft).
    1. Install the accessory drive belt. Refer to Partially raise the vehicle.
    1. Tighten the lower generator bolt to 25 Nm (18 lb-ft).
    1. Connect the generator electrical connector.
    1. Install the battery positive B+ cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
    1. Install the generator splash shield.
    1. Install the fender splash shield and the retainers.
    1. Install the right front wheel.
    1. Connect the negative battery cable.
    Nov 08, 2009 | 1998 Ford Taurus
    The cable for the spare tire on my 2006 1500 works fine (it's all the way down) but the retainer did not lower at all so I cannot pick up the spare tire. Can anyone help? Thanks
    1. Rotate the hoist shaft counterclockwise until approximately 15 cm (6 in) of cable (1) is exposed.
    2. While holding the latch pin (3), fully depress the latch button (2) and release the secondary latch from the hoist assembly. Some side-to-side and/or up-and-down movement may be necessary to disengage the latch mechanism.
    3. Continue rotating the hoist shaft counterclockwise in order to lower the hoist the rest of the way.
    4. If this does not release the secondary latch, the spare tire hoist will need to be replaced. See the following procedure.
    Important: If the spare tire hoist has been fully raised without a spare tire in place, the secondary latch mechanism may have become engaged. If this has occurred the hoist will not lower and the following steps will need to be followed:
    Nov 01, 2009 | 2005 Chevrolet Silverado
    How to 1998 Taurus altenator R&R
    please rate highly if this helps
    Generator 3.0L (2V)
    Removal
    1. Partially raise the vehicle on a hoist. Refer to Section 00-02 .
    2. Remove the right front wheel. Refer to Section 00-02 .
    3. Remove the lower fender splash shield retainers and position the shield out of the way.
    4. Lower the vehicle.
    5. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
    6. Remove the power steering line bracket and heater hose support bracket from the generator.
    7. Remove the upper generator bolts.
    14. Disconnect the right hand stabilizer link.
    15. Lower the subframe to provide clearance.
    16. Remove the generator.
    Installation
    1. Connect the right hand stabilizer link and torque to 47-62 Nm (35-46 lb-ft).
    1. Install the accessory drive belt. Refer to Section 03-05 .
    1. Partially raise the vehicle.
    1. Install the battery positive B + cable and nut. Tighten the cable nut to 10 Nm (89 lb-in).
    3.0L (4V)
    Removal
    1. Disconnect the battery ground cable. For additional information, refer to Section 14-01 .
    1. Remove the accessory drive belt from the generator pulley. Refer to Section 03-05 .
    1. Remove the right front wheel. Refer to Section 00-02 .
    Installation
    3.4L (4V)
    Removal
    1. Disconnect the battery ground cable (14301). Refer to Section 14-01 .
    1. Remove the right side cowl vent screen. Refer to Section 01-02 .
    1. Raise the vehicle and remove right front wheel assembly. Refer to Section 00-02 .
    1. Remove right tie-rod. Refer to Section 11-02 .
    1. Remove accessory drive belt (8620) from generator. Refer to Section 03-05 .
    1. Disconnect electrical harness connector and output terminal wiring.
    1. Remove nut and position engine control sensor wiring (12A581) out of the way.
    1. Remove the two bolts and one stud bolt.
    1. Remove generator from vehcile
    May 12, 2009 | 1998 Ford Taurus
    Ford focus 05 model changing dip headlamp bulb?
    US Focus has one headlamp attachment that you have to raise car on hoist to remove it.
    Headlamp Assembly Removal
    1. Remove the fender splash shield lower retaining screw.
      • Push the fender splash shield to one side.
    1. Remove the headlamp assembly lower retaining bolt.
    1. Remove the radiator grille.
    1. Remove the headlamp assembly.
      • Disconnect the headlamp assembly electrical connector.
    Feb 25, 2009 | 2005 Ford Focus
    Got a 96 mercury sable with a transmission problem I would like to replace it but dont have any manuals to describe process. Can you help? Thanks Pat
    To replace the transmission you will need to:
    lift the vehicle
    support then engine using a hoist
    Support the transmission using a hoist
    Unbolt the motor mounts (There are 4 of them)
    Lower the engine 8 - 10 inches
    Unbolt the transmission
    Lower the transmission
    Raise up the new transmission and follow the steps in reverse.
    Trust me, this is NOT fun :( the top transmission bolt is REALLY hard to get to.
    Jan 03, 2009 | 1996 Mercury Sable
    aldi.com Logo
    Top aldi.com Computers & Internet Experts
    David Payne
    David Payne
    Are you an aldi.com Computer and Internet Expert? Answer questions, earn points and help others
