Question about Locks & Locksmithing
Lseh 613 safe
How to program keypad
Only has keypad to access safe. batteries are dead
Leave it for a week. The batteries might have regenerated just enough to open the door once more.
Otherwise there may be a keyhole beneath the front plate.
If all else fails, you'll have to cut the back out of the safe.
Mar 10, 2015 | Home Security
My lagard lock safe won't open-no battery.
If internal battery is depleted and will not allow lock to open, hold a new9-volt alkaline battery on the contact points (large battery terminal to
large keypad contact, small to small) located on the front of the keypad.
Maintain contact, enter and valid code and turn keypad to open lock.
Lock contains a non-volatile
memory, even with batteries removed the lock will retain
all programming.
NOTE: You must maintain battery contact at all times throughout the
entire procedure.
Mar 15, 2014 | Safe International Digital Electronic Safe...
Common Issues with Mesa Safes MFL2014E Safe Depository Safe 09 Cubic Feet
The most common issue with the MFL-2014E is the keypad. We have 7 of these safes in our company and I had been replacing the keypads all the time. Which wasn't too terrible while they were under warranty but if I remember correctly they want $60 for a replacement keypad out of warranty.
I started replacing the electronic lock and keypad with Sargent and Greenleaf models. S&G 6120-305 or S&G Titan 2006-108 and haven't had problems since. Mesa said they had an engineer team from overseas go over their keypads to figure out what the problem was. The feedback was their design was fine but the components were cheap and under par. I still had a problem with their resigned keypads however.
The only other problem I have had is the bars getting bent from people shutting the door on them and bending them. This can be fixed by taking the panel off the door and bending the bracket back flat with your hand. The metal there in a bit too flimsy in my opinion.
Mar 04, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
How to program my viesat remote control
TRY THESE - TOSHIBA
112 313 413 419 506 510 512 517 613 902
Jul 04, 2010 | Toshiba Televison & Video
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
I have a sears garage door opener with an keypad. When the weather gets cold, below freezing, the keypad does not work. I have tried changing the battery. Any suggestions?
Sounds like you may have electrical breaks on the circuit board.
You could get a magnifier and look on the board to find any small cracks and perhaps get them soldered back together.
But it might just be cheaper to get a new keypad and program it to your garage door.
Good luck and be safe.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Locks & Locksmithing Logo
71 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
