Question about E-Machines Computers & Internet
My blackberry 8900 says app error 524 then automatically resets.. help
  • 43 Answers
I'm sorry to say, that it has suffered an unrecoverable crash. All data is lost unless you had a backup on your computer. Typically the device is garbage but you can try to reformat the device using Blackberry Desktop Manager available at www.blackberry.com but it still fails 90% of the time.
Posted on Oct 10, 2013
App error 532
Read the MANUAL and then operate have a good day .. thanks Vijaya
Mar 25, 2014 | RIM Blackberry Curve 8900 Smartphone
Hi there, I hope someone can assist me with this
Sometimes it helps to upgrade your OS ...from say (a)4.2.0.442 to say (b)5.0.0.1015. I was getting tons of uncaught applications on my 9550.I upgraded from (a) to (b) and the problem is gone.Along with battery issues.Can you try that?Your carrier must have OS upgrades for your device on their website.Good luck!
Aug 15, 2013 | RIM BlackBerry 7100G Smartphone
I try so many things how do i reset my blackberry i have an app error my blackberry doesnt go on
here's how to update your phone
1: download & install flash file HERE
2: Delete the vendor.xml file located in c:\program files\common files\research in motion\apploader
3: Download Flasher blackberry Tool HERE
4: Open flasher blackberry Tool like this pic.
5: Go Next like this pic.
6: You can see usb pin number if you phone connected to the PC. go next
7: This very important don't forget check the box all apps you need and Go next.
8: Wait the application loader finish flashing ...
9: wait for Your Phone software has been updated successfully ...
this my finish product from my customer BB 8900 ...
hope it helps...please rate me and ask testimonial too...thanks
Jun 03, 2011 | RIM BlackBerry Curve 8520 Smartphone
App error 523
start the blackberry in secure mode.This will fix app error 523
May 16, 2011 | T-Mobile Blackberry 8900CURVE Curve 8900...
Dear sir., i have blackberry 8900 curve model..but it shows error on screen as APP ERROR 523 RESET. PLS ADVICE US WHAT TO DO ?
if the app required internet. then
go options - advance option - TCP
type the APN ( access point name ) you can get it from your bb service provided. click option n save
restart n try . if still the same issue persists then remove n redownload the app .
its if a normal application with no internet support is required. simply del n reinstall the app . do confirm if there should be no software ver conflicts.
Feb 18, 2010 | AT&T Blackberry Curve 8300 Smartphone
Reload error:507 curve 8900
well you have done great so far. Error 507 means that JL-CMDER has done its job and wiped all applications off your phone. So just do the next step by connecting it to your 4.7 Blackberry Desktop and select App Loader and install the OS and Applications on the phone. Please write again if you need more help
Jun 20, 2009 | RIM BlackBerry 7290
Placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
What does app error 523 mean and and how can i fix it?
Hi your problem is solved
Error definition:
JVM 523:System process died
A critical Java process has terminated, and the device cannot continue to operate in a normal manner
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
Good Luck and do let me know
Feb 28, 2009 | RIM BlackBerry 7100G Smartphone
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
