Question about Samsung RF4287HA
We were gone on vacation so I turned the ice off and emptied the ice container. Now I can't get it to freeze ice. Water ok just no ice
    Top Expert:
  • Samsung Master
  • 9,472 Answers
The freezer has to get to a certain temp before it will make ice.
Posted on Oct 12, 2013
5 Suggested Answers
  • 1462 Answers
SOURCE: rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Posted on Jun 13, 2007
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
SOURCE: Having problems with ice maker. Was slowing down
I had the same problem and the Samsung customer service person told me to set freezer to -2 degrees, remove the ice bucket, press and hold test/reset button (look for arrow on top right of ice maker inside the fridge), replace the ice bucket and wait 24hrs.
Posted on Dec 28, 2010
  • 5370 Answers
SOURCE: Went on vacation without turning
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Posted on Jul 08, 2011
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
Went on vacation without turning the ice maker off was gone for to 2 weeks and the ice maker was full upon our return. I emptied all the ice and now the ice maker is not working (not making ice). I would...
Jul 08, 2011 | Samsung RSG257AARS (241 cu ft) Side by...
My maytag refrigerator will not drop ice cubes or crushed ice or water
OK, The most likely reason is the water control valve is defective for the ice maker or the ice maker thermostat is not working and will not tell the control valve to open for water. If ice is just sitting in the ice maker and it will not cycle then I believe the ice maker may be the problem. Now if you could tell me the model number of your Maytag I can send you a manual and tell you the part numbers. Try this, if the ice maker is empty and turned on fill with tap water and allow to freeze. If the water freezes and then dumps I will know that the water valve is not working. If the water just freezes and sits there then again it is the ice maker. Problem is I'm not sure if yours is the mechanical ice maker or has a control board in the front. They just made too may different models. Let me know and I will check back and if you find the model number the service manual I will upload to you.
Sep 07, 2009 | Maytag Refrigerators
Not producing ice
Did you by some chance put the ice maker in "vacation" mode. There's a little lever on it that turns it on and off. Check your owners manual - you do still have the manual don't you!
Aug 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a GE Profile refrigerator the does not produce ice cubes
the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer
I have a 15 year old sub zero refrigerator. The drain hole keeps freezing up and ice is building up under the produce drawers. There is also a smell that has accompanied this problem. We have melted the ice and forced warm water through the tube to clean out any blockage but it keeps freezing up. Can you help?????
Oct 30, 2008 | Refrigerators
Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Dec 03, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker
Check the power conection to the ice maker. If that's ok, then I would think the solenoid that controls the water flow has gone bad. Unfortunately, you will likely have to replace the whole ice maker, I don't think they are reparable.
Feb 11, 2007 | Kenmore 53632 / 53634 Side by Side...
Samsung RF4287HA Logo
76 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
