Question about HP LaserJet 5200 Printer
Hp 5200 tray 3 won't lift paper - HP LaserJet 5200 Printer
  • 83 Answers
SOURCE: hp laserjet 8150. i have a problem, tray 3 empty,
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Posted on Nov 25, 2009
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
seeker5211
  • 1089 Answers
SOURCE: Hp Laserjet 8150.
Start by pulling out tray 2 and setting it on the floor. Next take out tray 3 and slide it into tray 2. Print from tray 2. If it works, take the tray on the floor and put it into the tray 3 slot. Print from tray 3. If it fails change the feed rollers.
Posted on Jan 24, 2010
  • 32 Answers
SOURCE: I have a HP 1320 laser printer. I have a paper
you must clean you printer
Posted on Feb 25, 2010
  • 217 Answers
SOURCE: Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Posted on Jul 29, 2010
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Cannot print legal paper in HP laserjet 5200
Try to set in printer setting.
Select Printer-->Properties-->Advanced-->Printing Preferences-->Paper/Quality
Set it A4 Paper...
Jun 08, 2012 | HP LaserJet 5200 Printer
I have 5200 hp laserjet printer is a problem 13.05.00 jam inside top cover tell me this problem
A jam has occurred in the registration
assembly area.
1. Press the 'down arrow' to see step-by-step
information.
2. Open the top cover and remove the print
cartridge.
3. Remove all media inside.
4. Lift the metal flap and remove any
remaining media.
5. Verify that the media size matches the
tray settings and the dial on the tray.
6. Reinstall the print cartridge and close
the top cover.
7. To exit, press ? .
Oct 27, 2011 | HP LaserJet 5200 Printer
13.20.00 JAM INSIDE TOP COVER
Without seeing the printer or knowing what you have already done....a "13.20 Jam inside top cover" error means that a jam occurred in the registration assembly area.
Remove the toner cartridge.
Remove all paper from inside printer.
You should see a metal flap. That's part of the "registration assembly".
Lift it up and make sure that all paper pieces are removed. Use a flashlight if you can.
Make sure that the media size that you are using matches the tray settings and the dial on the tray.
Reinstall the cartridge and try again.
May 18, 2011 | HP LaserJet 5200 Printer
I reloaded the paper tray. Now it says "no paper pick-up, even though I have 2 trays I can get neither to work. I have tried nv ram. The printer is only 3 months old and I can see nothing wrong with...
Check under the paper tray, paper lift has to be act with the help of "knoch"( a small plastic part along with the spring to lock the paper lift) while loading the tray. If its broken or nor functioning properly paper wont lift to pickup, result error shows reload the paper tay, if "knoch" is good chek under the tray there is a metal frame drives the "knoch" If its not connecting properly make the frame slight bend to ward to up side at the centre pont. load the tray and observe whether paper lift acting or not. .
Best of luck..
Vinay.Hyderabad.
vinay229229@yahoo.co.in.
Apr 18, 2011 | HP Laserjet M2727nf Multifunction Printer
I have got hp printer error 60.02 plz help me.
Tray 2 is not lifting the paper.
Open the tray and look for obstructions.
Remove and reseat the tray.
Try switching trays 2 and 3.
If that doesn't work, reply back to me.
Feb 28, 2011 | HP LaserJet 9050n Printer
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
Tray 3 empty
  2. Remove Tray 2.
Tray 4 empty
Nov 25, 2009 | HP LaserJet 8150n Printer
HP Color LaserJet 8550DN input device failure, check cables and cycle power | error code: 66.01.02
This error message indicates a lifter malfunction has occurred. When the 2000-sheet input tray (Tray 4) is closed, the paper deck lifts the paper stack until it is just below the feed rollers. Photosensor flag PS34, the paper surface photosensor, determines when the paper stack is lifted into the feed position. When PS34 does not detect paper in the expected time, the printer reports a 66 error. SOLUTION: Follow the steps below to troubleshoot and resolve the issue.
  1. Turn the printer off, open and close the tray, then turn the printer back on to see if the error clears.
  2. Open the drawer and check for extra paper or items stored on the left side of the tray. This will prevent the tray from lifting due to excess weight or blocking the lift of the tray.
  3. Remove all the paper from the tray. Remove the tray guides and reseat them. Verify the guides are not bent or broken.
  4. Lift the paper deck manually to verify there are no obstructions in the path.
  5. Pull the tray out as far as possible and observe the white bushing on the back right side of the tray. If the white bushing is broken, the tray will not lift properly.
Oct 23, 2009 | HP Digital Sender 9100C Multifunction...
HP Laser Jet 4350tn issue
open tray 2 and tray 3 and try it.
Dec 03, 2007 | HP LaserJet 4350TN Printer
108 people viewed this question
Seeker5211
Seeker5211
