I am getting this error Parse error: syntax
I am getting this error Parse error: syntax error, unexpected ')' in /home/bathgate/public_html/wp-content/themes/leadership/functions.php on line 29 here is line 29 - can you tell me what is wrong with it? $res = $wpdb->get_results($wpdb->prepare($sql)); After udpgrading Wordpress to 3.6.1 and 5 plugins Askimet Contact From 7 Sidebar Login WP Family Tree Next Gen Gallery Unfortunately my clone has an error but I can restore a June clone and database backup from yesterday but would like to know what the coding error is Thanks Trish
  • 2 more comments
  • Trish Findlay
    Trish Findlay Oct 12, 2013
    Add a Comment$res = $wpdb->get_results($sql);
  • Trish Findlay
    This problem is now resolved - the correct code is
  • Trish Findlay
  • Trish Findlay
    Thanks for looking
5 Suggested Answers
Sandy4u
  • 107 Answers
SOURCE: Scanning to WP 9
Hi this should be problem with Software u need to Install "HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch" for Scan Quality
please use below link for patch .select correct OS & download "HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch"
if this information is useful for u please Rate me......
Posted on Jun 16, 2008
  • 13433 Answers
SOURCE: printer driver
Hey,
Official Lexmark driver download page. directly from lexmark:
http://www.lexmark.com/lexmark/product/home/272/0,6970,204816596_653399443_243436816_en,00.html?tabId=7
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 21, 2009
KingDWS
  • 1606 Answers
SOURCE: I am getting error message
That is a programming error dealing with Word Press Analytic's.It is not a virus or malware problem so you don't have to worry about that. Usually you see these after something was updated or if a file gets corrupted. To try and fix this you may need to uninstall the plugin then re-install it. Since this is a fairly populaur blogging tool it will proably be updated fairly frequently as bugs and fixes occur. Worse case you may need to try again in a few days or when a new update for it becomes available.
This is one of those annoying things if you need it a lot but unfortunately you can;t do much about it other than the re-install and hope it fixes the bug.
Posted on Sep 24, 2011
  • 2861 Answers
SOURCE: How do I fix this Parse error: syntax error, unexpected '.', expecting ')' in /home1/ragtop23/public_html/wp-content/themes/twentyten/comments.php on line 78?
Change to another theme.
Delete the twentyten theme
download and install twentyten again. Done...
next time save a backup of the file before you start editing it.
Posted on Dec 21, 2014
Testimonial: "Thanks Jay for your comeback. I really wasn't all that happy with the twentyten theme anyway, so I did change to one I liked better."
Why am i getting Parse error: syntax error, unexpected end of file in C:\xampp\htdocs\conditionalssf.php on line 66
Google:
Error fix explained.
Feb 21, 2018 | Syntax Computers & Internet
Dec 20, 2014 | wordpress.org
Parse error: syntax error, unexpected T_FUNCTION
when are you gettting this error message ?????
Sep 26, 2013 | Apple MacBook Air
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
Parse error
A parse error is an mistake in a line of code, there is a missing charactor in the syntax of the code, ie a missing ( " ). You will need a registry repair program to correct the error try this free program from this site just copy and paste it to your text window in your browser :
http://www.snapfiles.com/get/winregrepair.html
Jan 28, 2010 | Acer Aspire One PC Notebook
Parse error: syntax error, unexpected '<' in /home/nicoc/public_html/file.php on line 15
Contact the owner of the 'nicoc' account on the web-site.
The 'file.php' page, written in the PHP scripting-language, has a "bug" in the programming.
Nov 16, 2009 | Microsoft Windows XP Professional
Parse error: syntax error, unexpected T_STRING in /home/a4491082/public_html/savefile_php/config.php on line 4
T_STRING is a string error. It usually means one of two things.
1. The string is formatted incorrectly. In your case check on line 4. Make sure if you have a ' that you close it with a '. Same with ". Close all " with another " somewhere. Make sure line 4 ends wth semi-colon ;
2. Usually this is the case. The line above the string it states doesn't have a semi-colon to complete the statement. In your case, check that line 3 ends with a ;
That is why it says unexpected T_STRING which means "unexpected string". The string on line 4 is unexpected because line 3 wasn't closed properly.
Aug 26, 2008 | Computers & Internet
Syntax error
go to this site and look under "error codes"
go to computer and system error codes
http://checkitright.spruz.net//main.asp?page=dp&dis=834222
Feb 07, 2008 | Computers & Internet
136 people viewed this question
k24674
jasbo
jasbo
