Question about Pioneer TS-W257D2 10" Champion Series Subwoofer with 1000 Watts Max. Power, TSW257D2,TS-W256DVC,TS-W256C
Need amplifier to Pioneer TS-W257D2 Car Subwoofer
    New Friend:
  • 28 Answers
Rockford Fosgate Prime R500-1, great quality, won't break your bank. 500wattsx1 at 2 ohms. 320wattsx1 at 4 ohms. But this amp is under rated. They come with a certificate that tells factory test output. Mine was 541wattsx1 at 2 ohms. Be carefull, and turn gain on amp to 3/4, and no more as the sub is 350rms. Never go by maxx wattage. 500 is safe at low gain levels.
Posted on Nov 08, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Any car audio amplifier will work.
Posted on Nov 15, 2013
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Wire 2ohm or 4 ohm
wiring depends on what amplifier you're using..
Dec 28, 2013 | Pioneer TS-W3004SPL Car Subwoofer
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How many amps will the pioneer ts-sw251 except continuosly
need some clarification on your question to see if i can help...
amps = amperes or amplifiers?
if you are referencing RMS or continuous power that will be on the spec sheet that came with the woofer or you can google "ts-sw251 spec" and find that information. really a woofer really only cares about power in watts and resistance in ohms.
Aug 17, 2009 | Pioneer TS-SW251 Car Subwoofer
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
Which terminals to use
if your amplifier is 2 ohm mono stable - you can wire them in parallel.
Put a piece of wire from one + terminal to the other + terminal on the subwoofer.
Then do the same to the -.
Now pick one pair of teminals from the subwoofer and wire it to the amplifier. (one set of subwoofer terminals will have 2 wires each).
If you reply with your amplifier make/model, I can tell you the best usage.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 30, 2009 | Pioneer TS-W307D4 Car Subwoofer
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
SUBWOOFER ENCLSURE FOR TWO PIONEER TSW307F 12" FREE AIR
Hi, i know its a long time since 2008.
but do you or enyone else know where to get specs to a pioneer ts-w307f???
im building a box for this sub but i cant find specs so i cant run it on winisd!
i konw this dont answer a qestion but since you did a graph on it in winisd i thought you might have the right specs?
Dec 24, 2008 | Alpine MRV-F307 Car Audio Amplifier
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Pioneer TS-W257D2 10" Champion Series Subwoofer with 1000 Watts Max. Power, TSW257D2,TS-W256DVC,TS-W256C Logo
142 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
