Question about Sony NW-E507 MP3 Player
Broken IC my NW droped on hard surface and its IC got a crack , i shown it to sony service station they said new IC is required So please help me where i can find one for me. it is not available in india
    Sergeant:
  • 274 Answers
Did the Sony service station say they can fix it? I would have Sony fix it for you at what ever the cost. It will be cheaper than buying a new player. If it cost more than 50% buy a new player and throw the broken one away. What IC"? Are you talking about an Integrated Circuit? Unless you have the "exact" part number, we can not help you. Even if you have the correct part number, they might not be easy to get or find. Then how are you going to repair it? Do you have the correct soldering iron and equipment? This is not what you want to heard but I would do the first thing I suggested.
Posted on Sep 24, 2007
SOURCE:
Need a manual for an A-35
a MAKE is helpful :>)
Support for NW-A35 ' Downloads, Manuals, Tutorials and FAQs ' Sony ...
https://www.sony.co.uk/electronics/support/digital-music-players-nwa.../nw-a35
Walkman® with High-Resolution Audio. ... Firmware update 1.20 for NW-A35 / NW-A35HN / NW-A36HN / NW-A37HN (Mac) ... Firmware update 1.20 for NW-A35 / NW-A35HN / NW-A36HN / NW-A37HN (Windows)
NW-A35/A35HN/A36HN/A37HN ' Help Guide ' Walkman manuals and ...
helpguide.sony.net/dmp/nwa30/v1/en/contents/TP0001154009.html Sony provides the following manuals and information regarding the Walkman. The provided manuals explain the following operations and functions. Basic operations. Unique functions that require explanations. Complicated operations that require instructions.
[PDF]NW-A35/A35HN/A36HN/A37HN ' Help Guide ' Top - Sony
https://docs.sony.com/release//Help_4593956111.pdf NW-A35/A35HN/A36HN/A37HN. Use this manual when you have trouble or when you need to know how to use your WALKMAN®. The color of Walkman sold in some countries/regions may differ from those shown above. The contents of the Help Guide may be subject to change without notice due to updates to the ...
SONY SLT-A35 INSTRUCTION MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Sony Manuals > Digital Camera > SLT-A35 View and Download Sony SLT-A35 instruction manual online. Interchangeable Lens Digital Camera. SLT-A35 Digital Camera pdf manual download.
Mar 18, 2018 | Cameras
Hi my nokia 3110c was accidently droped in water by mom and after putting it in sunlight for few hours it started working but the memory card slot is not shown in my gallery the memory card is working in...
Because of water damage of your Mobile the Memory card IC has also got damaged so Please Replace the Memory card IC from Nokia Service center(Nokia Care)
If your an Technician so Please follow the Picture IC is highlighted over there.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 19, 2011 | Cell Phones
Solutions for "format error" problems
I'm sorry that the Network Player is displaying the error message. Usually, the error message appears if you use the Computer to format the player. In order to resolve the issue, please format the player using the format option from the Menu items on the Player.
Please follow the below steps to format the player using the Menu options.
If the issue persists, service may be required. Please click hear to locate your nearest service facility:
Thanks for understanding. Please let me know if you require further assistance.
Jun 10, 2011 | Sony NW-E003F MP3 Player
My Sony walkman NW-E003F showing Format error
May 30, 2011 | Sony NW-E003F MP3 Player
Sony NW E 505 discharge
check whether the memory is full if the memory is full too the battery will get down soon and if you have the change of signal to the battery will get down.
Sep 17, 2009 | Sony NW-E505 MP3 Player
My book was droped on the floor light come on it connects to pc but i cannot access it
depending how high and on what surface to the damage it could be a crack in the board to a loose internal wire to the worsed thing a broken harddrive
Jul 30, 2009 | Computers & Internet
Menu butoon of 6170 is not working
for your info, keypad ic for nokia 6170 fix to near of angle p.c.board assy, if you have drop before, as my experience before, i found so many keypad ic crack. if you see that sim ic likes chip off or crack on top of surface, change it with new one. This ic got 24 like solder ball bottom of ic, make sure all of solder ball joint to surface of pcb.
May 19, 2009 | Nokia 6170
Accessories!!
Click Sony Accessories, write model number in search box and all is available there what you required for NW-HD1
Thank you.
Oct 23, 2008 | Sony NW-HD1 MP3 Player
Volume is too low on my old Sony Trinitron KV-27S45
Volume is too low on my old Sony Trinitron KV-27S45 Can i fix it with out parts? no as it requires tech help as tv is high voltage device. would it be less expensive to just purchase a new tv? it would be less expensive. no need to purchase new tv. please get check 1 speaker paper cone might be hard or defective 2 loose contact in sound section 3 supply to sound might be absent. 4 connector loose. 5 any capscitor defective in sound section. 6 ic might be defective in sound section hope this will help.
Sep 25, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
USB plug thingy wont come out and slide cover broken
I had the same problem you can go to sony.com and get everything worked out you may need to lie but it will get fixed just don?t say weather or someone broke it or they will say not covered it is a bought $15-25 tops hope this helped. And you can use a small flat head screwdriver to release the USB.
Aug 04, 2006 | Sony Walkman Bean NW-E305 MP3 Player
Sony NW-E507 MP3 Player Logo
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
