Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Rheem 71 30d
I have a Raheem 71 30d hot water heater, the water is extremely hot and I have turned both theta stats down as low as it can go. Every time I turn the hot water on it spits because it has so much air in it. The overflow valve is constantly overflowing and it stays wet under my manufactured home. Help
  • Mellony
    Mellony Oct 10, 2013
    It's not a tankless water heater
    Top Expert:
  • Rheem Master
  • 45,079 Answers
You should be able to control hot water temperature by adjusting the thermostats. Either or both may have failed, causing heating to increase to the maximum. The "spitting" is caused by boiling water. Likewise, the pressure relief valve is operating as it should resulting in the overflow you observe. You need to get your heater serviced immediately!!
Posted on Oct 10, 2013
Testimonial: "Thanks. So we probably need to replace both thermostats?"
  • Mellony
    We have a repair guy coming.
    New Friend:
Over heating possible bad gas control valve , relief valve bad or water pressure too high or overheating will cause it to leak also lack of thermal expansion tank
Posted on Oct 18, 2013
  • 2692 Answers
SOURCE: Hot Water Overflow
Do you have an expansion tank tank  in the line leading into water heater? If not what is happening is that the water is no longer allowed to go back into the city supply.  You said that you had turned it off while you left so the water heats up and has no place to go so the preasure/ temperature P/T valve  opens and lets out the excess water from the expanded supply (heater water) that has no where else to go. It used to be that the extra expanded water just backed up into the supply pipe and back into the main. That is no longer possible in most places by the  National Plumbing code.    The answer may be to install the expansion tank into the incoming line. You can see then now at  all hardware stores where water heaters are sold.
Posted on Jan 04, 2009
WonderTech
  • 268 Answers
SOURCE: have a rheem gas water heater for manufactured
First off, the repair man is right that it is the thermostat.I'm guessing his quote was the cost of part and labor to install it. You can buy a new one for around $300. to $350. ish.
Hope this helps.
Posted on Aug 14, 2009
  • 102 Answers
SOURCE: Rheem hot water heater problem
If by the hot water over flow valve you are refering to the T&P valve. It is activated by high temp. or high pressure. It is possible that when you flushed the lines it caused this to open. It is also common for these once open to get a little debris in them and cause them to continue to leak. Sometimes you can open and close them a few times and get them to reseal. Other times you have to replace them. Hope this helps.
Posted on May 10, 2010
  • 102 Answers
SOURCE: no hot water
If you checked the reset, then the next thing to check would be the breaker in your breaker box. If that doesnt work start checking the elements. The reset, the thermostat and the elements are pretty much all that can go wrong with an electric water heater, short of a leaky tank or faulty t&p valve. Hope this helps.
Posted on May 11, 2010
  • 760 Answers
SOURCE: I have a Rheem Steller natural gas hot water
Yes, Turn the knob on the gas valve to off. Turn off the incoming water line into the water heater. If you have a valve on the outlet turn it off too. Open the drain at the bottom of the heater to drain a little water from heater. You can then lift the lever on the temperature/pressusre relief valve to let a little air in to release the vacuum and let the tank drain. If the relief is in the side let it drain a bit longer so the water level is below the outlet. Be sure to re-install the down pipe on the relief valve on the new valve. You should drain the a few gallons of water at least once a year from your heater, and you should exercise your temperature relief valve once a year to be sure it will function. If your new valve leaks suspect your temperature control allowing the water to get too hot.
Posted on Oct 04, 2010
Testimonial: "thanks greatly"
Installed a new rheem water heater last night and still no hot water. It has power thermostat set at 130.
Turn off the heater then open the bleeder valve on top of the tank to let the air escape. Once all of the air has been bled off, faucets included then turn your heat back on.
Jun 14, 2017 | Rheem Water Heaters
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
The pilot light is ON, but we are not getting hot water...help!
There are a few issues that can cause this....
First... Is this a new installation??? If the hot and cold piping is reversed then you will not get much hot water...
Does the burner come on at all??? If you turn the thermostat up higher does the burner come on???
If the dip tube on the cold water inlet disintergrates or falls off... you will not get hot water but the tank will be warm-hot....
If the burner will not come on at all then the thermostat has gone bad and the t-sta/gas valve will need to be replaced...
To replace the t-stat and gas valve you will need to drain most of the water from the heater and turn out the old valve and then replace it with a new one...
Sometimes the onetime limit safety cutoff on the gas valve will burn out.. usually because of a gas valve/t-stat failure....
This should give you some ideas as to where to start looking...
Comment back to me if you have more questions...
heatman101
Feb 08, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Bioling hot water and stat turned down massive bills ?
people are saying the lower element is bad,this I know the lower element cant have anything to do with it.possibly the thermostat Ive seen a problem if you would have an energy blanket around it this sometimes goofs up the thermostat.Id have it looked at,if the relief valve isn't going off have that checked to.water that hot isn't good relief valve is set at 150lbs
Jan 17, 2011 | Rheem 81VP6S/430126 Water Heater
I think I need to drain/flush our hot water heater
hi first making sure not to burn yoursel switch of heater and drain down down water from taps this may result in causing an air lock dont worry ! at the base of the heater you have the stat and element housing first withdraw the stat then the element alowing any remaining water to drain when fully drained turn on your water supply to flush out and clean replace element and stat using plummers sealent or tape hope this helps
Nov 16, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a richmond tankless water heater and its been shutting down and showing a code c7 or c8
1/overheat stat 2/ fan 3/diaphrapm valve 4/ micro switch check area around fan very small hose pipe for pinhole best of luck
Oct 30, 2009 | Rheem Tankless Hot Water Heater...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
180 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
