Question about Vehicle Parts & Accessories
Code alarm remote starter
When I use the remote to try to start my car, my horn sounds repeatedly and does not start
  • 364 Answers
, There is only two answer unfortunately, try changing the batteries in your key transponders or your transponders need to be reprogrammed, sorry for the bad news
Posted on Oct 20, 2013
  • 139 Answers
SOURCE: have a code alarm for car remote dont work and
Provided that your system is not programmed for coded override, the standard emergency override is as follows:
1. Enter the vehicle (the security system will trigger.)
2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
3. Turn the ignition key to the ON position.
4. Press and release the emergency override button (The security system will turn off).
Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
1. Enter the vehicle (the security system will trigger).
3. Turn the ignition switch to the ON position.
4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
5. Within 5 seconds turn the ignition key OFF, then ON.
6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
7. Within 5 seconds turn the ignition key OFF, then ON.
8. If entered correctly the security system will turn off.
9. Turn the ignition key to the OFF position.
If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
Posted on Nov 05, 2010
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
ltfrc
  • 227 Answers
SOURCE: viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Posted on Jan 17, 2009
  • 82 Answers
SOURCE: 2005 Grand Prix remote start causes alarm to sound.
remote start systems have a dis-arm alarm output wire ... this must be connected to the OEM alarm disarm wire ... your installer needs to service it.
Posted on May 12, 2009
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
Why does my remote start just make the car horn beep and security lights flash but doesnt start?
it sounds like security start relay malfunction ,check and or change out relay.
Sep 07, 2014 | 2007 Chevrolet Malibu
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
2000 stratus beeps twice, flashes twice, repeats untill stopped, but it drives
This is usually a good situation to bring to alarm shop and have them take it out and see if you can just keep the remote start or it might need a new brain on the alarm system
Dec 10, 2013 | 2002 Dodge Ram 3500 Truck
How do I activate the alarm on my Dodge
The 4103 is not an alarm. It's a remote starter with keyless entry! Do you want the horn to sound when locking and unlocking? First, make sure that the horn wire was connected. Press and hold the lock button on the remote. That should activate the panic/car finder. The horn will begin to sound. Press and release the lock button to turn it off.
If the horn is connected and, you want said horn to sound when locking and unlocking, open door, turn ignition on then off, press and hold programming switch until the horn chirps once. Release programming button, press and release programming one time then, press and hold programming button. While holding the programming button press and release unlock button on remote. You should hear two chirps from the unit. Release programming button, turn ignition on to exit programming, Test system.
Feb 13, 2013 | 4103LX Remote Start System with Two...
I recharge my battery and try to put it back conet and the horn keep blowing when try to start get nothing in side or out
It sounds like the car alarm is going off. Do you have an alarm remote that you can use to turn off the alarm? If the alarm is sounding, the anti-theft system will NOT let you start the car.
Dec 23, 2011 | 2004 Acura 3.5RL
Starter button did not work and when use key to
something is not hooked up properly with the remote starter, it sounds to me like the unlock wire on the remote is hooked to the factory arm wire on the alarm
Jan 03, 2010 | Excalibur RS-310-EDP Remote Start Keyless...
HORN DOES NOT WORK ON 1999 DODGE DURANGO
The horn is a simple circuit. Check your fuse, and see if you get power to the horn itself. The remote start and alarm are separate problems, and probably need a technician to straighten out.
Nov 15, 2008 | 1999 Dodge Durango
Dont know how to work it
do not lock doors with facory switch it is setting the factory alarm must shops dont get the factory disarm alarm wire to shut it off.this will always happen use the remote with the remote starter to lock and unlock doors and it should be fine
Mar 28, 2008 | Scytek 2000RS Remote Control
Vehicle Parts & Accessories Logo
457 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
